BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Rounding up AH3 for BM3 or MHD?
      12-12-2018, 09:24 AM   #309
vigilante
Drives: Activehybrid 3 M sport
Originally Posted by afranke View Post
Sweet, it just happened to me again today so I was literally about to open a ticket and link to this thread, but it sounds like you got it covered this time. Any chance he gave an estimate on when OTS maps would be updated?
EDIT: Random additional question, does anyone else still see a 201101 DME tamper code?
Halim said he will update all the OTS maps before the week ends
I will revert regarding the DME tamper code tomorrow.
      12-14-2018, 12:43 AM   #310
Lancelot
France
573
Drives: 2017 m550i
Cool
Yep still getting DME tamper code too.
And absolutely no burbles, but that's not a big point, not looking forward to being pulled over by police.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      12-14-2018, 01:34 AM   #311
vigilante
Originally Posted by Lancelot View Post
Cool
The perfect solution for burbles is to get a valvetronic exhaust.. If you see the police go into the silent mode and no burbles
2013 M5, Bootmod 3 stage 2 91 octane, Evolve Catless downpipes
2013 Activehybrid 3, Pure stage 2 turbo with High flow inlet and Dv upgrade, Wagner Evo 2 comp intercooler, ER charge pipes, BMS JB4, BMS intake, BMS Meth kit with a single cm7 nozzle, Fuel it Port injection in 550cc injectors platinum kit with Ethanol analyzer, Fuel it stage 2 LPFP, ER oil cooler kit, Mach v Valvetronic exhaust, Bootmod 3 and running E20
      12-14-2018, 03:22 PM   #312
afranke
Drives: 2013 ActiveHybrid 3
Cool
Odd, I get lots and lots of burbles. And they can be quite loud given my exhaust setup. I think if it weren't for the hybrid motor my neighbors would have killed me by now.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
      12-16-2018, 02:22 AM   #313
Lancelot
France
573
Drives: 2017 m550i
Must be a difference btw EWG and PWG I guess, i'm not looking for anything loud (no gunshots!), just nice crackle like M2 stock would be fine, but it's really absolutely zero in my case.
EDIT: we want video
      12-16-2018, 02:25 AM   #314
Lancelot
France
573
Drives: 2017 m550i
Cool
V2 map is mostly fine so far on my side, having a bit of fun with sideways action thanks to the increased torque
Still feels a bit hesitant at very slow speed sometimes (when you let the car roll forward in D mode with zero throttle)
To be confirmed but it also seems to have got rid of half-throttle hesitations I had with previous version, where there would be micro-traction cuts at 3-5k rpm, though full throttle seemed fine, could have sth to do with the gearbox torque limit that was removed.
That hard limp mode happened to me once with the V1 map, totally unexpectedly, and indeed you must have some place to pull over otherwise can be a saftey risk, wouldn't like this to happen in a tunnel, on a bridge, or any kind of dense traffic. I found myself flashing back to stock+online recode on the side of the road, not an easy moment.
      12-16-2018, 02:38 AM   #315
Lancelot
France
573
Drives: 2017 m550i
Originally Posted by nucl1 View Post
Yes, everytime I, you know, tamper with the DME Haven't checked if it stays there after I go back to stock, but it's definitely there with the OTS maps.
It does go away when you flash back to stock and lock at least.
      12-16-2018, 07:20 AM   #316
nucl1
nucl1's Avatar
Drives: 2013 ActiveHybrid3
[QUOTE=Lancelot;24120708]
Could it be the difference between 91 and 93OCT ? I was only running 93OCT so far as I have access to "racing" gas on regular gas stations.
I had to revert back to stock as I don't trust the car to not fail when I want to push it a bit ( 3 hard limp modes with 60-70% throttle).
Also, it did not happen with the v1 map in the summer - maybe it's the cold weather now ?
2013 ActiveHybrid 3 Mineral Grey Bootmod3 Stage1 93Oct
      12-17-2018, 07:57 PM   #317
afranke
Looks like the maps were updated today, gonna flash tomorrow and see what we get.
      12-18-2018, 09:35 AM   #318
nucl1
nucl1's Avatar
I've flashed the v4 today and going back to stock tonight.
The torque limit exceeded seems to be fixed, but idle RPM is all over the place, jumping up 100-200 and accelerating by itself when in gear (!) from 1200 to easily 1400-1500 rpm. Car is all jerky and driving it is a pain (gentle steering in a narrow carpark almost impossible).
When I turned on the sport dials, the torque seems to be right around the 50 mark when idle.
      12-18-2018, 10:26 AM   #319
afranke
That was also a problem way back at the beginning of AH3+BM3. Sounds like someone reverted to an old map or something, these were problems that I already solved with them over a year ago (almost two years now).
My "maximum total torque exceeded" ticket was opened 11/Apr/17 and the driving itself thing was included in that ticket and reported 12/Apr/17. All of it fixed by 17/Apr/17. I wonder who did what to bring all these issues back.
Lancelot572.50
      12-18-2018, 04:11 PM   #320
afranke
Alright, flashed V4 took a 20 minute drive to lunch and 20 minute back. Had some minor stumbles immediately after the flash, but that's pretty normal in my experience. It went away after a minute or two of slow driving. No unintended acceleration that I could tell.
The first 20 minute drive was SOLID. Car felt great, felt like it had tons of power. The Sport gauges show me hitting 560+ ft. lb of torque and around 340HP when I'm at like 60% throttle which is were the max torque error was coming form before. Not sure if that's actually true, but it looks nasty and feels great.
On the 20 minute drive back, I hit some fuel system issues. 481B01 Fuel Pump motor voltage too low. To be clear, THIS IS UNRELATED TO THE TUNE ITSELF. This is a common issue in these cars, the EKP overheats. Mine is an EKPM2 and the recommendation I am seeing is to replace it with an EKPM3 which I now get to research.
      12-18-2018, 06:14 PM   #321
IK6SPEED
Drives: BMW M3 / AH3
Originally Posted by bradsm87 View Post
The LPFP is drawing right on the warning threshold for electrical current. Sometimes is exceeds it slightly. Sometimes it doesn't. On E series cars, custom coding can get rid of it. I'm not sure about F series as they don't use an EKP module any more but something under another name.
I searched for the term EKP (which includes EKPM2 and EKPM3) and only 6 threads, including this one, have it even as a passing issue.
Are you saying this is common?
      12-18-2018, 07:53 PM   #322
afranke
Talked with the Fuel-It guys to make sure it wasn't the LPFP and they said:
Sounds like a classic EKP overheat. You'll want to replace it with an EKPM3.
And also
Direct swap, you can try a used one for cheap off of ebay and then you don't even have to code it.
So I spent $30 on a decent looking eBay one and we'll see what we get. I'm gonna be away from the car for almost two weeks starting this weekend, so I can wait for it to show up.
I found a few threads on N54Tech about it (most notably this one: https://www.n54tech.com/forums/showthread.php?t=39023). It seems the upgraded LPFP pulls more current and overheats the fuel pump control module. Guess I'll find out for sure when I get back.
      12-18-2018, 08:01 PM   #323
IK6SPEED
And also
Hmmm. The only other person on forum to mention issue PabloK says the told him update to a stage 3 LPFP. He did and never mentions an issue again. His was on a 335i, btw, not AH3
https://f30.bimmerpost.com/forums/sh....php?t=1478682
I guess $30 is clearly cheaper than $900 though.
You have a link to eBay device?
      12-18-2018, 08:19 PM   #324
afranke
Dunno, but yeah I'm gonna try the $50 solution first. If it doesn't work, oh well. I grabbed this one, but if you search eBay for "EKPM3" you'll see a few dozen of them:
https://www.ebay.com/itm/14-15-BMW-F...M/183368286419
      12-18-2018, 08:22 PM   #325
PabloK
PabloK's Avatar
Got my stage 3 fuel pump installed and everything seems to be fixed... cars in storage for winter... I'll mess with it again in spring...
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      12-18-2018, 08:25 PM   #326
afranke
Do you have a 2014? Does that already have an EKPM3? The part number on RealOEM for my car says up to 10/2013 and is then superseded by another part number.
      12-18-2018, 08:27 PM   #327
PabloK
PabloK's Avatar
Yes mines a 2014
Not sure about that part.. how do I find out?
2017 Alpina B6
      12-18-2018, 08:31 PM   #328
afranke
Yes mines a 2014
Well, I just went out to the car and pulled off the passenger side rear bolster, and to throw a wrench in everything my module is labeled EKPM3 with part number 16147301554. Now, that PN has been superseded four times, so maybe it is just an old bad one. Welp, back to the drawing board I suppose. Still gonna try that $50 and see what we get.
      12-18-2018, 08:35 PM   #329
IK6SPEED
The link to eBay one says 2014-2015, yet that number appears to be an E9x version. So very confusing.
Looks like a new 16147411596 would be most logical.
Actually wonder if one of the newer B58 models would work.
      12-18-2018, 08:38 PM   #330
afranke
Yeah, after looking at my module and PN, I'm gonna cancel that one and look for a 16147411596.
