01-16-2018, 08:54 AM | #68 | |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Is it bare, or with harness and connectors? I might rock one of these eventually. I suspect sooner or later my PS2 will melt the cat in my UR catted downpipe. At that point, I'll remove the cat substrate, plug in a plug and play catsim and still be able to pass visual and OBD inspection!
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
01-17-2018, 12:02 PM | #69 | |
Rep 1,499
Bare. Never been used or hooked up. I'll snap a pic of it tonight if you are interested.
Also @Jadar, if you know the manufacturer and MF part number you can probably find the connectors on something like Digikey.com Quote:
01-18-2018, 09:20 PM | #70 | |
Rep 262
Drives: 2013 BMW 335i M-Sport
01-22-2018, 11:14 PM | #71 | |
Rep 160
01-25-2018, 05:26 PM | #73 |
Rep 1,499
Can you please explain to me what this means? Are you saying that a tuner can switch off lambda control via "ori cat off" setting? What does "do VMAX" mean and isn't the ECU hidden so why the need to cover the ECU?
01-25-2018, 05:42 PM | #74 |
Rep 1,499
Has anyone ever tried anything like this...
Evidently is a mini catalytic converter that the O2 sensor screws into to fool the sensor into thinking the DP is catted. https://www.amazon.com/LEDAUT-Degree...sensor+cel+fix
terryd5150507.00 |
01-26-2018, 03:46 PM | #75 | |
Rep 19
I can do it by coding via esys, but i need dme data before coding. VMAX - maximum speed. |
01-27-2018, 09:35 AM | #78 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
02-03-2018, 09:49 AM | #79 |
Rep 152
Drives: 2015 435i Gran Coupe
05-21-2018, 02:19 AM | #81 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
To date A74 hasn't stepped up in answering anything about EWG cars N55 or S55. They always come back with send a pic of wiring and when sent they don't reply or say wiring is prob faulty. Vague.
Also only one EWG car has passed emissions in Texas that used a sim and plug harness we tried several combinations and it would always leave 2 not ready. But his county allowed for two monitors to not be ready so it's just his case and luck. Technically the sim still does not work for EWG. I doubt there will ever be a solution just my honest opinion.
FBO-PS1 and stuff
05-21-2018, 01:51 PM | #82 | |
Rep 89
2015 335i xDrive mpack
JB4, BMS intake, MPE, ER DP, ER CP |
05-21-2018, 01:53 PM | #83 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
05-22-2018, 04:16 PM | #84 | |
Rep 124
stock
05-22-2018, 04:19 PM | #85 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
wildacex18713.00 |
05-22-2018, 06:30 PM | #86 |
Rep 124
sorry to keep bothering you but can you recommend one please?
stock
05-22-2018, 08:32 PM | #87 |
Dejan
1753
Rep 4,197
I have an ER200cel but for 300cel I'd go with the Wagner or Fabspeed.
FBO-PS1 and stuff
wildacex18713.00 |
07-18-2018, 11:51 PM | #88 | |
Rep 77
I'm running a 2014 EWG N55, FBO with catless downpipes and JB4. Set JB4 to Map 0, set CEL clear to "off", and unplugged the OBD connector, then proceeded to install the catsim using exact wiring following the above. The downpipe fix that arrived from VRSF looks nothing like their displayed image on the VRSF site, but looks exactly like the catsim from Area 74. Confirmed that install following instructions using Positaps work, blue LED stays on when car is on. Also used Autel MS309 to erase all codes, then proceeded to drive cycle the car. First cycle complete, got P2271 error - "O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 2". Strange thing is, all other monitors were showing "OK" / "Ready" when this CEL showed up. I erased the code, though now that I think about it I shouldn't have. It's late now - will drive cycle it again tomorrow and report back. |
