BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > zf 8 at fluid change AT 100K +
      12-07-2018, 04:51 AM   #1
Marlinman
Drives: 2013 335i xDrive
I've been reading all the different opinions on changing the AT fluid on the ZF 8HP and it seems most people are sub 100k when they discuss. I'm approaching 100k in the next few months and wanted to ask the group if anyone has bothered to change their AT fluid at this far of an interval AND if they are FBO, upgraded turbo, or not, etc. If so, do you now have tranny problems with slippage, shifting, etc. Any info or feedback is appreciated. I can't decide whether to leave it since I currently have no issues (knocks on wood) or just add it to the maintenance list for hitting 100K. thanks.
      12-07-2018, 08:02 AM   #2
IraHayes
Drives: 328i
If you plan on keeping the car long-term, definitely change it. 100k seems to be the longest you’d want to wait. ZF recommends changing between 50 and 80 thousand miles, but I’m “hearing” on this and other forums that some BMW dealerships and Indy shops are recommending 100k, so you’re right at the cusp. If you are going to do it, I would do it soon.
      12-07-2018, 12:16 PM   #3
Marlinman
Okay thank you, I'm ordering the kit from FCP euro as we speak.
      12-07-2018, 12:23 PM   #4
bavarianride
Drives: bimmer
"hearing", as in echo chambers from the a few posters?
The other thing heard recently from local mechanics that they saw E46/E39/E90/D60 with 150k+ miles and zero AT maintenance, and the AT still works fine. The new gen of ZF 8AT though can be more complicated than those previous gen trannies though.
      12-07-2018, 12:59 PM   #5
insanecoder
Drives: 340isDrive
imo there may be some risk in doing so now
however regarding the intervals of transmission fluid changes
back in the day, I used to change mine every 15,000 miles or so
yea synthetics and all that but synthetics does not extend oil lifetime from 15,000 to never!
      12-07-2018, 03:17 PM   #6
CarlosC
Drives: 2012 BMW 328i
I changed mine at around 100k...no issues whatsoever. Stock 2012 328i (F30).
      12-08-2018, 07:15 AM   #7
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
What do you mean by risk?
Also back in the day you'd change tranny oil about every year?
Hi
      12-08-2018, 07:35 AM   #8
jh_f30
jh_f30's Avatar
1306
Drives: 2013 335i Sportline Auto RWD
There is debate about whether doing an ATF change on high mileage cars is a good idea. Has been known to cause slipping after the fact, but I guess the debate is whether or not ZF has the same potential issues.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      12-08-2018, 11:18 AM   #9
IraHayes
Drives: 328i
I have experienced this slipping myself. I changed the trans fluid on my old Jeep at about 160k. I started experiencing a little slippage after that. Not too bad, most others couldn't notice, but I could tell since I drove the car on the daily.
      12-08-2018, 11:19 AM   #10
jh_f30
jh_f30's Avatar
1306
Was that with a drain & fill or a flush?
      12-08-2018, 11:47 AM   #11
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Oko ok hang on lol, an old jeep trans is I think a little different than our ZF trans. I wouldnt start saying that they're related even post fluid change.
Hi
      12-08-2018, 12:24 PM   #12
jh_f30
jh_f30's Avatar
1306
Just Google "ATF change problems". Knowledge is power.
      12-08-2018, 12:51 PM   #13
Marlinman
This is why I posted! in for info of guys changing at this high of mileage and experiencing slippage. Especially with the beating some cars have taken after mods/etc.
      12-08-2018, 12:58 PM   #14
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
All anecdotal my friend (and on 20 year old cars).
Wisdom is more powerful.
Hi
      12-08-2018, 04:34 PM   #15
jh_f30
jh_f30's Avatar
1306
True. Hence my point that "there is debate".
      12-10-2018, 05:05 AM   #16
Marlinman
any other takers
      12-29-2018, 03:01 PM   #17
bobalis
Drives: 2014 F33 N55
I emailed ZF a while ago about this and this is what the replied with:
Thanks for contacting us in regard to your 335i and transmission maintenance. There is a factory schedule included in your maintenance schedule, however it's basic and does not address driving style or climate only normal and severe driving. Severe can be classified as Stop and go city, aggressive driving, heavy loads or short trips. With these types of driving we recommend 60,000 miles. For light driving which would be driving several miles to fully heat the transmission or continuous highway driving we would recommend 80,000 miles. Also be sure to use either ZF Lifeguard Fluid 8 or BMW fluid. The software for ZF transmissions includes properties of the fluid and if an alternative fluid is used it may affect transmission adaptions and could cause a failsafe mode. Also be sure to use Genuine BMW or ZF pan assembly with filter as it is as important to remove any clutch material or other debris from the oil pan as it is to replace the fluid.
Now the SA I used to go to said that they recommend to never touch the ATF and that its a "lifetime fill". I even sent him this response and he still recommended against it. It is my inclination to follow the instructions from the manufacturer of the transmission, however, its ultimately your choice.
      12-30-2018, 08:35 AM   #18
switchman
Drives: '18 540i '15 X5 '03 530i
2015 BMW X5 35i  [0.00]
2018 MW 540i  [0.00]
I had '03 e39 at 80k and '06 e53 at 100k drain , filter change and refill. Both cars drive and shifted ok with no issues.
E39 was sold and still being driven by my friend, e53 drives well till I sold it at 128k miles.
These have different ZF tranny but both uses same fluid.
