BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY Paddle Shift F30
Studio RSR
      08-06-2015, 08:52 AM   #23
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Originally Posted by jondaman View Post
If your horn was activated for several seconds, I would suggest first of all, you take the negative terminal of the battery off first, the potential of having something explode on your face at around 200MPH is not something you want to risk. ER is very expensive and you may not even need the ER at the worse case scenario.
Secondly you may not be going into the correct slot. In between the metal plates, there are two openings on each side of the steering wheel designed for the release of airbags.
All you need is push harder if you are in the right slot. There is only one place for the right size of Allen key to go between the metal plates. If you are felling the resistance and the airbag didn't come off and you are sure your allen key went through the opening correctly, you probably just need a longer Allen key to push harder and get it all the way in. Make sure your allen key is thick enough so it can't go anywhere else besides the designed openings, something around 1/4" inch think and about 6" long should do the trick. Remember, these pins have to hold the airbag when it is going off at 200MPH for that split second, there will be some resistance.
The side of the airbags have a metal casing, you can't really damage the side of the airbag unless you have the strength of Superman.
ABSOLUTELY DISCONNECT THE BATTERY WHEN YOU'RE MESSING WITH THE AIRBAG!!
If you're pushing in the hole as pictured and you feel resistance but nothing happens, use a bigger allen key.
2019 M5C Matte MBB / Tartufo
      09-20-2015, 03:34 PM   #24
BigBaller
Egypt
Drives: F30 316i Tanzanite Blue
Originally Posted by IancoleTX View Post
Super helpful. I will add a bit of info here to save the next guy some trouble.
Use an allen key for this, and make sure it's a medium thickness allen key. You will push into one hole until you feel resistance from metal clips - keep pushing and half the airbag will pop out. If you push and feel the clips and bottom out the allen key without the airbag popping out, chances are the allen key is too small. I wasted about 30 minutes trying to figure this out - it's not that complicated. Push in and it pops out. Once you do one side, do the other side in the same way. It really is about 10 seconds once you figure it out.
Allen Key , Allen Key , Allen Key
Thanks to both of you !
Current: F30 316i Tanzanite Blue
Sold: E90 LCI 320i Black Sapphire
      09-20-2015, 05:34 PM   #25
mdai245
Drives: 440i XDrive
It looks like my szl 2TB connector has 5 wires connected to it. From the pinout diagram for this, it looks as though this means it is prewired for shift paddles vs 4 wires for no paddles. Can anyone confirm?
      09-24-2015, 09:55 PM   #26
mdai245
Drives: 440i XDrive
Success! coded paddles verbaut activ and 2TB in VO and it worked without added wiring.
Looks like the wheel isnt heated so I will have to tranfer the paddles from this wheel to another m sport wheel I have that is heated but doesnt have paddles.
Any tips on how to drill the screwholes? what size drill? placement etc....
Thanks
      09-25-2015, 08:51 AM   #27
cshawkeye
cshawkeye's Avatar
Drives: 2020 X3M
Subscribing to this as I am looking to do this myself.
      11-03-2015, 01:27 PM   #28
Kfc2
Drives: 14 335ix; 12 328I; 87 325IS
Mdai245,
Is your car pre-wired by the BMW? May I ask what year and model is yours?
Thanks
      11-07-2015, 06:50 PM   #29
DLag30
Drives: F80M3 & F36
Thanks for posting this DIY . This is one feature that I really regret not getting. Ordered all my parts, hoping I can figure out the coding after installing.
      11-14-2015, 07:35 PM   #30
mdai245
Drives: 440i XDrive
Originally Posted by Kfc2 View Post
Mdai245,
Thanks
2013 AH3
Fully loaded lux line except for forward collision, park assist, and lane departure
      11-21-2015, 12:37 AM   #31
Kfc2
mdai245,
Thanks! I also have the luxury line like yours but mine is 2012.
I took apart the steering column tonight and found the car is already pre-wired for the shift paddles. Replaced the sport line steering wheel with the M sport steering wheel. Since I already added 2TB to the car, the shift paddles are working now!
      01-28-2016, 08:36 AM   #32
Sniper101
Sniper101's Avatar
Drives: 2013 328i F30
for some reason those links wont work for me
      02-04-2016, 06:25 PM   #33
DLag30
Drives: F80M3 & F36
I got a copy at home, send me a pm if you still need a copy.
For those who have performed this successfully, what coding was needed for the paddles to perform?
I have coded 2TB in FA already for sport transmission. It seems like some are only coding FA to enable the paddles..
thanks
EDIT; I attached another copy just incase others are having a hard time downloading the original one.
Also just confirmed, 2TB in FA was the only thing needed for everything to work with SAT
File Type: pdf DIY Paddle Shifters BMW F30 Rev. 3L.pdf (5.35 MB, 6170 views)
      02-10-2016, 02:41 AM   #34
DLag30
Drives: F80M3 & F36
Just finished this DIY. A few things that will make this easier; adjust both front seats to their farthest setting to obtain more space and open the moon roof to let light in. Note; the steering wheel can be rotated easily with the battery disconnected. Another issue I ran into is I ordered the wiring harness for a NON-HEATED steering wheel. I ended up just taking the connector for the paddle shifter and incorporating it to the harness that came with the car(Pin 2 and Ground of the steering wheel harness).
Also, I've attached pictures of connector A83*2B (SZL) and A173*7B (FEM). To my surprise, my vehicle was pre-wired for paddle shifter(maybe because its a sportline). In the pictures it's the Green/white wire. The last two pictures shows how the steering wheel harness needs to be routed so it doesn't interfere with the horn. Before installing the complete steering wheel onto the car, I installed the airbag onto the steering wheel and made sure the wiring harness doesn't interfered with the horn mechanism.
Lastly, the Steering wheel BOLT needs to be torque down to 46 ft-lbs.
      02-19-2016, 08:54 AM   #35
Sniper101
Sniper101's Avatar
can paddle shifters be added to the base steering wheel ?
      06-16-2016, 07:16 AM   #36
cshawkeye
cshawkeye's Avatar
Drives: 2020 X3M
Bumping this up. Since I have a 2013 F30 M sport 335, do you guys think its already pre-wired for paddles?
      06-16-2016, 07:44 AM   #37
Montaxx
Montaxx's Avatar
Drives: F30 328i
Thanks for your work!
If you're ok with it, I added your PDF to https://Bimmer.Space - The free BMW Coding Archive
      06-17-2016, 06:30 AM   #38
thejackyltm
Drives: 2013 335MSport
This is exactly what I am wondering, I also have a 13 335 MSport and cant find a how to for paddle shifters...
      06-17-2016, 02:53 PM   #39
cshawkeye
cshawkeye's Avatar
Drives: 2020 X3M
Yeah I hear from some people it should be just install and then you have to code.
      09-10-2016, 07:55 PM   #40
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
So I installed a new M Sport steering wheel with paddle shifters, replacing my sportline wheel without paddles. I had already previously coded 2TB and when I checked FEM BODY, it showed that 3190 PADDLES_VERBAUT was already set to aktiv so I assumed that the paddles would work plug and play.
However, I get no feedback in the instrument cluster and nothing happens when pulling either of the paddles. I already changed PADDLES_VERBAUT from aktiv to nichtaktiv and back to aktiv to see if that would fix the issue, but it still doesn't work. Would that mean that my car isn't pre-wired for paddles?
      09-15-2016, 03:03 AM   #41
DLag30
Drives: F80M3 & F36
In my previous experience, coding 2TB was enough to activate the paddle shifter function. Just curious did you check if you have a wire running from the A83*2B (SZL) connector to A173*7B (FEM) connector? That single wire is what sends the signal for the paddle shifter function. Hope that helps.
      09-15-2016, 09:48 AM   #42
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
I haven't had the time to check yet as I had assumed that having the paddles folder in FEM_BODY meant that my car already had the wire
      10-08-2016, 04:28 PM   #43
gyrotuner
Drives: 320i
Just tackled this today, but am having an issue with everything back together. Horn no longer works, wipers are stuck on (stalk is non responsive), no horn, and im getting a "cruise control malfunction error. Does anyone have any insight as to where to start with this? I was missing one of the connections inside the steering wheel to the multifunction button, but that is now connected, and still no improvement.
Anyone have any ideas?
      10-11-2016, 11:35 AM   #44
Blacktan
Blacktan's Avatar
Greece
49
Drives: BMW f32 428i mpack
If your car production date is up to mid 13's i am afraid that you aren'tprewired ...
