01-20-2019, 11:46 AM | #1 |
///M SubDriver
1835
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
DIY: Hardwiring Aftermarket Accessories the OEM Way Using The Trunk Fuse Box
So I was doing a little recon of the trunk fuse box in preparation for installing a few aftermarket electronic accessories. Prior to the recon, I searched the net for info on the best fuses to tap for constant and switched 12V - and I found some decent info with most using the "add-a-fuse" method. Then I stumbled across a professional install where an unused fuse spot was used without an add-a-fuse or splicing into existing wiring. After a little more investigating I found out just how ridiculously easy it is to tap into power in the trunk fuse box the way the factory does it - very clean, no wire taps or add-a-fuse (and I was surprised my searches did not find much on this OEM method). Below is what I found out and should be applicable to hardwiring any aftermarket accessory.
So why do this instead of just using the very popular add-a-fuse method? Well for me, my OCD prefers an installation looking as OEM as possible - even the wiring. And fortunately, the rear fuse box makes it very easy to access the bottom of the fuse box and the individual terminals (easier than any other fuse box I have worked with in previous cars). Note: While this should be applicable to most F8X/F3X cars, there may be some differences based on installed options in different vehicles. However, once you take a look at your fuse box as I did below, it should become obvious how much flexibility you have to work with in the fuse box in your car. And of course, be sure to disconnect the negative terminal on the battery before you start messing around with the fuse box. This first pic is the rear fuse box. The yellow circle in the upper left are the fuses in question that have power going to them, but are not actually connected to any equipment in the car. Those three fuses, and the other three fuses that make up the group of six, are all on with ignition, and off when the ignition is off (these fuses do not stay on for ~10 min after the ignition is turned off). From top to bottom, these are fuses 143 thru 148 (143-145 are unused in my car even though there is a fuse installed in these spots). The next pic is the bottom side of the fuse box. Each of the fuse groups you see from the top are connected to the colored sockets you see here. The brown socket in the lower left is the one I will be working with, which houses the fuses I mentioned above. Here is a pic with a closeup of the brown socket removed. To remove the socket, you need to remove a red plastic "pin" which will release the socket (seen in the pic above). I removed this red plastic pin with a simple pick tool. You will notice that only three of the sockets have wires in them from the factory. After doing some parts research on RealOEM, I found the terminal plugs that are used inside the fuse box. It was difficult to know for sure that the ones I found would work, but I decided to take a chance since they were not that expensive. Part Number 61130007438 is the part number I chose. This is the one that has ~9 in of wire already crimped - I chose this one because it was more convenient. I say not that expensive, but they are not that cheap either for what they are. Expect to pay $2.50 - $4.00 each for these little puppies. I bought mine from FCP Euro. The terminal pin slides in and snaps into the socket. The pic below shows the new terminal pin with wire (blue/black wire) inserted, and the socket installed back in the bottom of the fuse box. This last pic is the fuse box re-installed, with the new wire (blue/black) routed under the fuse box and then around to the back of the fuse box temporarily. I routed the new wire via the same path as the bulk of the other wring under the fuse box. Since I did not want a "live" wire just sitting there until I install my accessory, I removed the fuse and put it in one of the spare fuse holder spots - it is the brown 5A fuse in the upper right. The beauty of this setup is that when I install my accessory, I will use a fuse that is the proper size for the accessory. I left the other two spots in that bank of six fuses open for now, but plan to use them for some other aftermarket accessories in the near future - each with their own circuit and appropriately sized fuse. The last thing I did during my fuse box recon mission was to find out which fuses were a true constant 12V with the ignition off AND the car is "asleep" (i.e. the ~10 min after the ignition is off when most of the circuits finally shutdown). You will need to refer to your fuse box diagram located in the trunk fuse box. Here is what I found (you should also double check with a voltmeter or circuit tester before you actually use a circuit): The following fuses are constant 12V: 100, 103, 104, 106-109, 112-114, 116, 117, 120, 123, 149, 150, 160, & 161 The following fuses are on AND off with ignition: 143-148, & 154 (143 is the one where I added the OEM terminal above) The remaining fuses are on with ignition and then remain on for ~10 min after the ignition is turned off, and then turn off. Other things I noticed while poking around: 1. Fuses 109, 112 & 125 are blank, meaning that there is no fuse installed in the spot, but a fuse could go there. There are other spots that don't have fuses, but these spots can't have a fuse installed since there is no terminal connection to the power bus inside the fuse box. 2. Fuses 112-117, and 136-142, do not have sockets installed. Presumably these are for special option equipment. In theory, you could purchase the applicable sockets and the corresponding terminal plugs to use these fuse locations to power other accessories. Hopefully you will find this info helpful. Especially for those with OCD like me who like to have clean, OEM-like installs - even with the stuff that is not actually seen when your accessory is installed .
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
chr12.00 homeryen88129.50 M4NILA ICE26.00 erickonphoenix1722.00 Urbz8.00 LittleSamurai4.50 TouringM3619.50 psyki285.00 Friggin_Idiot1.50 |
01-21-2019, 02:28 AM | #2 |
Rep 1,141
That's an excellent write up
It's a shame you didn't post it sooner though. I've been through a similar process, and even bought a used rear fusebox to see exactly how things are connected. It's amazing how many of the installed fuses actually do nothing. We mush have similar OCD issues. I hate to see anything that doesn't look OE on my cars. |
01-21-2019, 07:36 AM | #3 | |
///M SubDriver
1835
Rep 2,782
01-21-2019, 07:44 AM | #4 |
Rep 1,141
You can see what does what here:
https://www.newtis.info/tisv2/a/en/f...-rear/KZX1sxlx 143 is only used on convertibles 144 & 145 are only used in Diesel powered cars. |
01-21-2019, 08:13 AM | #5 | |
///M SubDriver
1835
Rep 2,782
09-20-2020, 11:39 AM | #6 |
Rep 2
Really appreciate the effort of this post, thank you!
To add, I too wanted the OEM look and went about my work in a similar route. I purchased a 'used' rear fuse distribution board [which included its wiring loom plugs] from a well-known auction website [I paid £20 UK Pounds]. I needed a blue wiring loom plug to connect to the constant live fused ports numbered 112-117 for my F34. Each loom plug is unique to each port of the board 'however' by trimming the raised plastic keyway of the loom plug, they will fit elsewhere in similar shaped port. I also re-used the existing pins of my purchased blue wiring loom plug by carefully de-pinning the loom plug, soldering the new wire and re-pinning the loom plug. |
01-12-2021, 10:43 AM | #8 |
Rep 535
What a great write up! Many thanks!
I'm not sure the ALP or the Valentine would reach the trunk but the dashcams will definitely reach. I'd also like to get my police scanner hardwired this way as well. Thanks again. |
01-12-2021, 03:01 PM | #9 |
///M SubDriver
1835
Rep 2,782
Sure they could, just need to extend the wires as necessary and run them to the trunk - very easy to do. I needed to extend my dash cam wires as well (which I documented in another thread). I also did it with my V1 install, even though my V1 is installed in the rear headrest.
03-04-2021, 02:26 PM | #10 |
Rep 867
Drives: OG M2
Does anyone know where I could find replacement colored connectors? I'm currently looking for a teal colored 7 pin connector that would go into the top right slot...
03-04-2021, 07:53 PM | #11 |
///M SubDriver
1835
Rep 2,782
Check eBay for used F3x/F8x fuse boxes, or a local salvage yard...
05-06-2021, 09:47 AM | #12 | |
Rep 2
...If you are unable to source the port plug second hand, providing you have the part number [of the port plug] BWM will order it for you. From my initial post further up the thread, I purchased second hand the complete rear fuse board that included various port plugs [£20 UK pounds] |
05-07-2021, 04:58 PM | #13 | |
Rep 867
Drives: OG M2
05-09-2021, 04:04 AM | #14 | |
Rep 1,141
I don’t think you’ll get the port plugs for the fuse box. Those would probably only come as part of a complete loom or retrofit kit. They do sell the individual contacts for repairs though. As above, you’ll need to find a used one. |
05-25-2021, 06:27 PM | #15 |
Rep 498
Drives: '18 F80 6MT / '16 F31
Yo jmciver
I know i'm really raising this thread from the depths, but do you happen to know / recall if I could simply pop a 40A fuse into locations 109 or 112 and be in good shape - or are they only capable of certain amperages? Thanks!
05-26-2021, 05:55 AM | #16 |
///M SubDriver
1835
Rep 2,782
Difficult to say as amperage limits are not only based on the equipment being powered but also the thickness (or gauge) of the wiring connecting the equipment to power. The battery feeds the main bus bar inside the fuse box, with a thick cable, which can handle the total amperage draw of all components connected to the fuse box. So in theory, as long as you connect wiring from that fuse location (which should not have any wiring since IIRC that fuse is not connected to any components in the car), to your new component using appropriate gauge wire for 40A, you should be fine.
05-26-2021, 08:04 AM | #17 | |
Rep 498
Both of these gauge wires are largeish (4.0 / 2.5), so i'd be sure that the proper wire is still used. Images attached. 4.0 is the power tailgate, 2.5 is the active rear diff. So my game plan will be to slam a 40A fuse into 109 or 112, use the proper leaf-spring lead into the back of the fuse block, and prepare myself for locked-diff donuts while opening and lowering the power tailgate. (jk)
05-26-2021, 11:18 AM | #18 | ||
///M SubDriver
1835
Rep 2,782
05-26-2021, 11:46 AM | #19 | |
Rep 498
Turns out both the power liftgate in the F31 and the active rear diff in the F80 use the same fuse location, so when combining to make a fully functional F81, i need both to function with 40a fuses.
jmciver1834.50 |
06-26-2021, 12:16 PM | #20 |
Rep 625
Thanks for this. I’ve been using add-a-fuses on my F80 and G01 thinking they would only be temporary but could not find the right terminals. That part worked perfect for both cars.
08-17-2021, 08:34 PM | #21 |
Rep 37
Hi jmciver,
Based on your experience, is it possible to insert the wiring connector (Part Number 61130007438) into the socket without its removal (that whole thing secured by the red plastic "pin")? Thank you! |
08-17-2021, 08:54 PM | #22 |
///M SubDriver
1835
Rep 2,782
I never tried it like that as it is very easy to remove the plug. But it possibly could work that way.
mentbase7.00 |
