09-04-2013, 04:26 PM | #1 |
Rep 199
Just wondering if anyone has a quick write up or would mind doing one real quick.
I will be doing the led angel eye upgrade soon and was just wondering if anyone has dissembled them before. I have done a few sets of headlight disassembly for angel eyes and housing painting and am pretty familiar with the usual process usually needed but have not had a chance to disassemble these yet so any hints/tips ect are more than welcome. Thanks -Joseph |
09-05-2013, 03:06 PM | #2 |
2136
Rep 1,834
Drives: Many, BMW.
These headlights are permanently sealed, they wont be as easy to open as the traditional headlights open.
What rings are you planning to install? |
09-10-2013, 04:15 PM | #3 | |
Rep 199
I have done a few non bmw's as well which use the heat based adhessive. I bought your style 1's |
09-11-2013, 04:43 PM | #5 |
Rep 376
One retrofit company told me that the whole clear plastic housing had to be cut out to open then glued/resealed back together.. I decided not to try it... If you find a way please post.
09-11-2013, 04:54 PM | #6 | ||
2136
Rep 1,834
Drives: Many, BMW.
Most companies choose the easy way out and simply cut the lens off. We've done that several times and no longer do it that way. It leaves no room for error & looks messy and unprofessional. To open these headlights the "traditional way" without cutting them open requires about a total of 1 hour oven time per headlight, and prying the seal open with some muscle. It's prone to damaging the channel of the housing but its repairable, and to seal the headlight, we completely clean out the old silicone and use OEM headlight sealant that can be purchased from theretrofitsource.com. Hope that helps. Last edited by Igor_M5; 09-11-2013 at 05:22 PM.. |
