BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Misfire cylinder 3
      06-17-2024, 09:07 AM   #1
SantiP
Drives: BMW 428i xDrive Grand Coupe
Misfire cylinder 3
Hello yall,
I have a bit of a problem. I have a BMW 428i Grand Coupe 2016 and I been getting a misfire in cylinder 3. I changed the sparks plug, coil, fuel injector and still getting the misfire. The misfire happens when I try to accelerate fast. When I drive in eco or slow, it doesn’t happen. Whenever I have the car on and open the tap for the coil, cylinder 1,2,4 react to the tap opening but 3 doesn’t. Need help
      03-09-2026, 02:03 PM   #2
JJReam
Drives: 2024 X7 4.0, 2014 428xi Conv.
Did you resolve your issue? I have a 2014 428xi convertible that's throwing the 303 code and misfiring under hard acceleration. Sounds like the same issue you had.
