BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Sensor replacements & Computer detection
      10-18-2024, 07:48 PM   #1
christophevhl
Drives: 330i GT XDrive
Hi all. Have a 2018 330i GT and car was throwing a bad camshaft sensor (exhaust) code, and code to replace the MAF sensor, and running lean code, idling a bit rough, a gas mileage decreased a good bit over the last few months. As of this Monday, I got 360 miles range on a full tank.
This Tuesday, I changed the MAF sensor, filled the tank, and within about 5-10 miles on the freeway, the range increased to 410 miles. The idle improved a bit, too.
I changed the camshaft exhaust sensor yesterday (Wednesday), filled up the tank, and topped off the fuel. It was above 3/4 full before filling, and showing range of 360 miles. After the replaced the camshaft sensor, and topped off the fuel, I drove for about 20-30 miles, and the fuel range remained between 357-161 the entire time.
Today, I turned on the car, and the range was at 356 still. I drove 20 miles up the road and back, and it now says the range is 297 miles.
This feels "off." Does it take a few days or cold starts for the car's computer to adjust to the new sensors? Note: I'm no mechanic.
Car has 123k miles.
      10-19-2024, 11:15 PM   #2
SupremeF34
I make content for all things BMW F34 & E34
SupremeF34's Avatar
99
Drives: E34 540i & F34 340i GT
I’m not sure of the code/sensor issue, but I’m pretty sure the range on the instrument cluster adjusts to your driving style and is only an estimate. I would more so rely on your MPG readings + calculate your actual miles driven via the odometer to see what your full tank range is after the fact. But again, it will change depending on driving style/highway city driving, etc, so I doubt it will be the exact same range estimate every fill up.
'94 E34 540iA (M62B44NV swapped)—SSSquid Chip
'17 F34 340i GT (B58B30M0)—Factory MSP, MPPSK Retrofit, BM3 Stage 2 93
youtube.com/@supremegt
Instagram: @SupremeF34
linktr.ee/supremef34
