| 03-07-2026, 04:29 AM | #1 |
Rep 19
Am I too late?
My 2015 435i is on 134,000 miles and has not had the transmission fluid changed. I’ve read/watched a lot about changing or not changing the transmission fluid on high-mileage ZF 8HP due to causing more harm than good. The gear changes feel fine, no harsh changes, no slippage that I’ve felt.
I’m wondering if there is a cut-off point, after which I should just leave the old oil in, or if there are any signs I can look for to determine if I should change it? Also, I recently changed the HPFP, so I took the opportunity to get a look in the air intakes. Looking at the photo below, do you think I’m due a walnut blast or can I hold off? |
| 03-07-2026, 07:22 AM | #2 |
Rep 18,346
Don't believe everything you read, especially on line. You won't hurt the tranny with a fluid change, provided it's done correctly. You valves aren't that bad, use this to clean them up. https://www.crcindustries.com/gdi-iv...valve-cleaner/
Yoully6.00 |
| 03-07-2026, 11:44 AM | #3 | |
![]() ![]() ![]() ![]() 565
Rep 954
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
| 03-07-2026, 11:52 AM | #4 | |
Rep 954
Yoully6.00 |
| 03-10-2026, 07:53 AM | #6 |
![]() ![]() ![]() 7553
Rep 11,530
ZF recommends fluid changes every 8 years or 50K miles whichever comes first.
Since there are no apparent symptoms of transmission wear (slippage, harsh shifts), changing transmission fluid + pan + filter would my recommendation. Use Lifeguard 8 transmission fluid. However, who performs the fluid change and how makes all the difference. Keep in mind that changing the transmission fluid does not mean that all fluid will be replaced. It takes 3 drain-and-fill cycles to replace about 80-85% of transmission fluid. There are persistent myths which suggest that changing the transmission fluid can make things worse in a high mileage transmission. What is more likely instead: an improper fluid change leading to air pockets and component failure. Last edited by cfm56d7b; 03-10-2026 at 08:42 AM.. |
| 03-10-2026, 08:45 AM | #7 |
Rep 19
cfm56d7b I’m glad you’re pointing this out! I was under the impression that I could simply drain off the old fluid by removing the plug(s) remove and replace the filter cover and refill the though the filling port.
| 03-10-2026, 11:22 AM | #9 |
Rep 11,530
Although this topic has been discussed extensively in many forums, it's helpful to share why BMW suggests that transmission fluid lasts a lifetime while ZF - the actual manufacturer of the transmission - suggests that transmission fluid has to be replaced at a certain interval.
ZF sends to BMW ready-to-install, fully assembled, sealed transmissions with all the fluid inside. BMW just installs it. So why a difference in guidelines? - In BMW speak, lifetime means around 100K miles - Many cars are leased - Most cars are sold prior to reaching 100K miles - if BMW indicated that transmission will require services at 50K-60K miles, the consumer will see it as a future, potentially expensive required maintenance item - BMW does not want to include transmission fluid change in service packages - Warranty cost control: the transmission has to survive the warranty period or an average lease / ownership cycle ZF transmissions have very tight clutch tolerances. The fluid will degrade with age and heat. So it has to be changed. If you plan to keep you car beyond 100K miles, simply change the transmission fluid and find a shop that knows how to perform this procedure correctly. |
| 03-10-2026, 04:38 PM | #10 |
Rep 19
ZF 8HP Service Guid
Having looked through the service guide it seems strait forward. Unless there are any steps missing from this guide? |
| 03-11-2026, 07:58 PM | #11 | |
Rep 954
Zf has a video somewhere on YouTube demonstrating the service; might be helpful to watch them do it.
LAGWAGN1001.50 |
| Bookmarks |
| Thread Tools | |
