BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Does this sound bad? F30 328i timing chain. New f30 owner
      03-31-2026, 10:06 AM   #1
CARP3_DM
SIDEWAYS
Drives: 07 335i e90 6MT
2007 bmw 335i 392  [0.00]
2007 BMW 335i  [0.00]
[ATTACH]undefined[/ATTACH]Hey all, I just got my first f30! It’s a 2015 328i m-sport with 180,860mi and I changed out the turbo inlet pipe last night because it was separated at the turbo. But I started down a YouTube rabbit hole and am now worried the timing chain in mine might be suspect. Like on webMD, self diagnosing always ends up with cancer, here I’m not sure if the motor is about to puke or it’s just loud direct injectors.
I’ve had a few BMW’s (e30/e46/e90/e92/e64) but this is my first one with the n20 so I’m not sure what they’re supposed to sound like and not supposed to sound like. My car has a 2/15 build date and some info I found says that is when they’re good and other info suggests that was the last of the “bad ones”.
So if anyone has experience with the n20 in the f30 328i and can listen to this video, please advise.
Thank you to any and all who can help with this! I’m in the Houston area also if anyone is local and/or knows where to go for this diagnosis, I’m happy to have a professional opinion as well.
      03-31-2026, 10:21 AM   #2
CARP3_DM
SIDEWAYS
Video won’t upload
      03-31-2026, 10:38 AM   #3
CARP3_DM
SIDEWAYS
https://youtube.com/shorts/40Ks_TZfZ...eG2ZIqXLFM2iJX
Got it on the YouTube
      03-31-2026, 02:24 PM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Sounds normal, so far as it goes. Timing chain noise is a high pitched whine that increases in intensity when you rev the engine. It's still a good idea to have the chain tensioner replaced, it was upgraded late 2016. It's not too expensive.
      03-31-2026, 03:42 PM   #5
CARP3_DM
SIDEWAYS
Thank you Billfitz! I’ll get that sorted out asap as I do want to keep this one for awhile. I’m going to investigate the difficulty/cost and see if it’s not too much for me to handle as compared to the cost of a local independent shop to do it.
I greatly appreciate your response and advice.
      03-31-2026, 10:08 PM   #6
Billfitz
Billfitz's Avatar
The tensioner is less than $100. Changing it is a bit of a PITA, as it's hard to get at. It might be worthwhile to have it done by a shop that's experienced with it.
