| 06-27-2012, 10:27 AM | #1 |
#savethemanuals
2896
Rep 2,192
F30 xDrive suspension in Msport ?
When using the configuration tab, the car lowers when you add the adaptive M suspension ON THE XDrive. Please let this be true, does anyone know if this is correct?
| 07-01-2012, 01:27 PM | #4 |
![]() ![]() ![]() ![]() 97
Rep 857
don't think there is any lowering ( 10mm ) on X drive cars,whether M adaptive is chosen or not.
from another board--- Will sport suspension be offered on xDrive 328i/335i? Yes. You will be able to get sport suspension but it will not lower the ride height. Will M Adaptive Sport Suspension will variable dampers be available on xDrive 328i/335i? Yes. You will be able to add the M Adaptive dampers. If you accept the fact that the M adaptive is ONLY the damper control, then perhaps the X drive cars ride higher since M adaptive deletes 704 (sport supension) which then would require different ( non-sport) springs (not lowered). Very confusing... Last edited by emtrey; 07-01-2012 at 01:49 PM.. |
| 07-01-2012, 01:31 PM | #5 |
Dinosaur supervisor
3044
Rep 4,215
In the price list (in Sweden) it says Adaptive M suspension (incl. 10 mm lowering of the chassi), and that is available for all models including xDrive. Option 704 is not available for xDrive though so it isn't crystal clear.
| Bookmarks |
| Thread Tools | |
