01-16-2020, 01:02 PM | #1 |
Rep 210
Are you running 255/40/18 on Style 397 18x8 wheels
Was thinking of giving my 18x8 sportline wheels a wider stance in the rear only. Anyone run 255/40/18 on a square rim setup? Was going to leave the front alone at 225/45/18 and just change the tire on the back. I am curious if people have done this and opinions. I love the look of these wheels, but need more traction in the back.
M Performance Suspension
01-16-2020, 01:41 PM | #2 |
A family of bimmers
2745
Rep 7,741
i dont think you can do a 255 on an 8" rim. widest recommended is a 245
01-16-2020, 02:50 PM | #3 | |
Rep 7,598
Also, are you saying that your wheels are 18x8 all around? I thought even the 18s were staggered 8 and 8.5 wide. |
01-16-2020, 03:13 PM | #4 |
Rep 210
Style 397 18x8 wheels are square
All are 18x8 225/45/18 is exactly the same diameter as 255/40/18. Guess I could do 245/40/18 which is really close
01-16-2020, 03:25 PM | #5 | |
Rep 7,598
Also, for traction, stickier tires helps more so than adding section width (especially after a point). The jump from 225 to 245 should be noticeable though. I spin 1st from a dig and 2nd from a roll with FBO, MHD 2+ tune, and summer tires on a clean dry road. |
01-28-2020, 10:30 AM | #6 |
Rep 210
Anyone run 245/40/18 or 245/45/18
Any opinion on running a slightly wider tire on the rear with a square wheel setup?
01-28-2020, 11:01 AM | #7 |
Rep 4,325
https://f30.bimmerpost.com/forums/sh...MMMM+new+tires
https://f30.bimmerpost.com/forums/sh...F45%2F18+dummy 245/40/18 square or 235/45/18 square, Michelin Pilot Sport 4S. in addition to widening, the brand, model, category of tire you choose is just as important especially if you're looking for more traction. |
MacklinUSOB518.00 |
02-10-2020, 10:23 PM | #8 |
Rep 426
I've been running 255/40's for 3 years with no issues. It's a square setup on the 397's. I love the look. It was their identical diameter to the 225s which made me choose 255s instead of 245s.
02-10-2020, 10:28 PM | #9 |
Rep 426
One more to give you more of an idea on how they'll end up. Although, I am using some 3mm spacers all around.
Since it's a square setup, I'm getting more life out of the tires since I can rotate every 3K. Otherwise the rear tires need to be replaced way to quickly. |
04-07-2021, 08:13 AM | #10 | |
Rep 45
Was wondering if that’s the same setup your running and if there is any rubbing etc! Sean |
04-11-2021, 08:51 AM | #12 | ||
Rep 426
