01-19-2020, 06:15 AM | #1 |
Rep 7
What to get for a puncture now that I have non run flats?
Hi all
New to this forum. Got a 335d X-drive which had RFTs when I got it. Had a puncture that was terminal after hitting a pot hole (could not even drive after despite it being RFT). Finally have made a jump to non Run flats. Was very dubious to go away from RFTs but it has changed the car's handling completely and in a good way. So now, I need something in the boot for future punctures. No space for spare since need the boot space on a daily basis, so looking at a compressor and what else? Looking at slime or puncture kit (realise need to get a jack as well if I get a puncture kit), so any recommendation particularly with anyone who has had the unfortunate scenario of a puncture and had to do something by the road side themselves? Very grateful for any advice. Thank you |
01-19-2020, 07:52 AM | #3 |
Rep 5,201
i got an airman tyre goo(18) and flyina air pump(27) of Amazon
on xmas day car hit a pothole and immediately the pressure went from 2.6 to 0 .4psi! the goo n air pump did nothing for me as tyre had taken the full impact and had been wrecked. A 24hr mobile tyre came out and put a budget tyre on a week lster later on i got rid of it once the michelins were ordered in by my tyre fitter. Total expense £360. so with the goo n inflator do keep a couple of local 24hr fitters numbers to hand.(i learnt this at short notice the hard way) ps i don't want to carry any spare wheel as i need the space for prams bags etc The inconvenience of the above is a small price to pay for the transformation in ride and comfort the non runflat provides. |
01-19-2020, 07:58 AM | #4 |
Rep 5,681
I carry a mobility kit in the boot (comprises some tyre weld type stuff plus a compressor to get it into the tyre if it goes down). I think M-cars with conventional tyres come with something similar from the factory (or at least my old E46 M3 did) but I've no idea how effective they are in practice as thankfully I've never had to use one!
01-19-2020, 07:59 AM | #5 |
Rep 644
I use a compressor and sealant kit and I also carry a Femor puncture kit to plug a hole if needs be. I haven't had to use it on my own car yet but it worked a treat recently when I used it to help a women who was stranded with a puncture. The fiber strip plugged the hole perfectly and the tyre held pressure to get her home
Techno 9000518.00 sspade2464.50 |
01-19-2020, 08:05 AM | #6 |
Rep 7
Thank you all.
Wills2- spare including a space saver is a non starter since I need the boot everyday and there is no space for the tyre apart from in the boot itself. KRS_SN- RAC towed me last week and got the mobile tyre fitters to fit the new tyres next day since it was late night and they couldn't do it. Have ordered a compressor from Amazon today. Just deciding if goo or puncture kit since reading through the forums, there is positive and negative for both since some people are saying goo does not work at all and some tyre fitter won't repair a tyre if goo is used, which is a worry!!! |
01-19-2020, 08:06 AM | #7 | |
Rep 7
01-19-2020, 08:27 AM | #8 | ||
Rep 644
01-19-2020, 08:49 AM | #9 |
Rep 7
01-19-2020, 09:01 AM | #10 | |
Rep 644
01-19-2020, 09:19 AM | #11 | |
Rep 8,493
I haven't had a puncture for the past 60K miles but have used one of the strips to repair a puncture on a family member's Macan. It held pressure for a week's driving over several hundred miles - no psi loss at all. If it was my car I'd have left it as a permanent repair for the life of the tyre.
Hugrov423.00 |
01-19-2020, 09:28 AM | #12 | |
Rep 5,393
Slime is the preferred sealant and it's supposed to wipe right out without damaging TPMS sensors. They sell many products but their "8-Minute" compressor kit seems best for our needs. (Available at Walmart in US) The compressor also comes in handy to adjust tire air pressures. Slime also sells a small inexpensive kit to fix a nail hole type of flat with a plug the old fashioned way. (Also at Walmart) Suggest carrying some pliers too. If you spot a nail which often cause such leaks you'll have to be able to pull the nail out before you can plug the hole. A cheap pair of mechanics, or even gardeners, gloves help if you are on the side of the road. Carry a 21"-24" breaker bar (1/2" driver preferred) and a matching 17" long socket for wheel bolts. There are inexpensive scissor jacks with a rectangular piece on top that fits perfectly inside the BMW plastic jack point. (Available at Harbor Freight in the US.) It helps to carry a small piece of 3/4" thick plywood to fit under the scissor jack on soft ground. Sometimes if a tire is completely deflated it won't hold air because it leaks out between the wheel and the tire bead. Being able to jack the car up to relieve the pressure often allows the Slime compressor to fill the tire with air even if the hole can be patched without filling the tire with Slime. I bought an inexpensive used 400M wheel to mount an older tire that I use as a spare. I carry this with me on trips. An emergency spare with its its 50 mile limit would force me to alter my trip schedule to find a tire replacement. A full size spare is the least disruptive especially when I'm traveling hundreds of miles. I keep the spare inside a nylon tire bag so I can easily place it in the back seat if I need to hide luggage in the rear. Hope this helps! |
Machinebuilder278.50 |
01-19-2020, 09:57 AM | #13 |
Rep 7
Thank you all. A separate compressor, tyreweld and femor repair kit ordered. Just holding fire on the jack since need to see how much space I have left in the boot. Appreciate all the advice.
01-19-2020, 10:39 AM | #14 |
Rep 151
01-19-2020, 02:55 PM | #17 |
Rep 5,393
01-19-2020, 02:59 PM | #18 |
Rep 5,393
FYI- all of the things that I listed including the scissor jack in its box, fit easily in the the underfloor storage compartment of my '15 335ix with room to spare.
01-20-2020, 09:29 AM | #19 |
Rep 7
Have got written confirmation from the tyreweld people that it won't damage the TPMS. If it does, I will use that for them to reimburse my cost of the TPMS. Hopefully won't come to that and I never have to use the stuff!!!!
01-20-2020, 09:31 AM | #20 |
Rep 7
Just got all the stuff today apart from the jack and it all fits neatly into the underfloor storage compartment and still some space for the jack left. Have some stuff already in there like defrosting spray and gloves etc, so will be a tight fit!!!
johnung4528.00 |
01-21-2020, 06:58 AM | #21 |
Rep 403
i got this type of thing with mushroom shaped plugs to (hopefully) seal the hole more securely.
https://www.amazon.co.uk/Spring-Infl...omotive&sr=1-3
Old flames: S3, M235i, E92 335d, Alpina B3, E46 M3
01-21-2020, 07:11 AM | #22 |
Rep 152
Drives: '21 M340xi
I skip the slime and hassle of roadside kits and just get a tow to a repair spot from roadside assist ( AAA, BMW Roadside or Roadside included with a lot of Amex/Chase credit cards).
non runflats, puncture repair |
