05-06-2018, 08:12 PM | #23 | |
Rep 43
Second, the cable set with the 2 extra connectors needed. Third, the back plastic cover for your steering wheel, either the basic line or the M Sport option. And finally 2 screws to catch the paddles to the steering wheel's body. That were the parts needed. After all you need coding. |
MoeRahman2.50 |
05-06-2018, 09:02 PM | #24 |
Rep 14
05-06-2018, 09:07 PM | #25 | ||
Rep 40
05-06-2018, 09:59 PM | #26 | ||
Rep 40
Would these be compatible? |
05-07-2018, 12:39 AM | #27 | |
Rep 1,953
Drives: 2013 328i xDrive
MoeRahman2.50 |
08-27-2018, 06:00 AM | #28 |
Rep 25
11-08-2018, 09:48 PM | #30 |
Rep 740
I have the sportline and the back of the steering wheel doesn't have the cutout for the paddle's. I'm not really worried about cutting out the leather but does anyone know if the holes are there for the paddles to screw on to?
Thanks!
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
11-09-2018, 07:53 AM | #32 |
Rep 740
Thanks, Kailec. Are there dimples or a mark on where to drill by any chance?
11-09-2018, 08:35 AM | #33 | |
Rep 1,953
Check that out. It's not the same wheel but I'm sure the concept is the same. |
11-09-2018, 09:13 AM | #34 | |
Rep 27
On the sport line wheel, there are no visible dimples or holes. There is rubber material over the metal area where the paddles would be screwed in. Keep in mind that you also need a hole for the wires to come through to connect the paddles to the wiring harness. After pricing out paddles and the wiring harness, I ended up purchasing a complete wheel. I'm really glad I didn't cut up and drill my existing wheel. I'll PM you where I purchased my wheel. There is one for sale that I think you could get a good deal on. |
11-12-2018, 06:59 AM | #35 | |
Rep 740
12-05-2018, 12:34 PM | #36 |
Rep 3
I had the same symptoms when I removed the SZL and then (after some modifications) put it back. The problem turned out to be the switch connector at the back (the one with the grey locking lever). If this isn't fully snapped in, then none of the switches on the cluster work, but the wipers stay on.
01-27-2019, 03:45 AM | #37 | |
Always on track!
Rep 90
Drives: 328i
01-27-2019, 01:18 PM | #38 | ||
Rep 55
01-28-2019, 12:11 AM | #39 |
Always on track!
Rep 90
Drives: 328i
Thank you so much. So the easiest way to make sure I have pre-wired paddles is check out under passenger footrest.
01-28-2019, 01:49 PM | #41 |
Always on track!
Rep 90
Drives: 328i
My is a 2013 sport line, i wish is pre-wired. With 2 babies i'll check when i can
EDIT: Check today, i don't have wire n. 5 under footrest, so i must wire in my car. I think, it could be present if there is some other optional? Last edited by omorzo; 02-08-2019 at 04:26 AM.. Reason: Check for pre-wired. |
02-25-2019, 07:28 AM | #42 |
Rep 2
Hi,
quick question, if you got the 428i - with the M steering wheel, do the 3-series have the same M steering wheel as the 4-series? Meaning, I only need the paddles + back piece? and if so - does anyone by coincidence know what parts I need to buy? Coding I can do myself. Tx, Tim |
02-25-2019, 01:04 PM | #43 | |
dad bod
387
Rep 382
I'd suggest taking your wheel apart, taking a good picture of the harness, and using that as a reference for which replacement to buy (the new one should look exactly the same as yours but with two blue connectors for the paddles). I didn't check and ended up ordering the wrong harness |
02-26-2019, 02:47 PM | #44 |
Modder of everything I own
147
Rep 491
You will have to add the wire yourself, it isn't hard.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
