02-21-2018, 09:20 PM | #45 | |
Rep 40,730
02-22-2018, 08:41 AM | #46 | |
Rep 40
I have other question. I would update the ASD with psdzdata 54.0 which is not trimmed because the ASD does not working. I bought as used part. Such as the reason, I have been searching that file for 2 months. but it was hard to find it and download. the reason i want 54.0 verison is for hearing N57D and M3, M4 engine sound. I have decided to flash ASD ecu after reffed to your advice. [a few questions] ☞Which version needs for using the pdszdata 54.0 full? ☞I heard that Launcher Pro 3 is supported Esys version by 3.27.1 to 3.31.0. but I know that i need older 3.26.1 to use the pdszdata 54.0 full. I installed Launcher Pro 3 with Esys 3.27.1 Please let you know how to deal this for me and share me. Thank you for reading me. Best Regards |
02-22-2018, 09:09 AM | #47 | |
Rep 40,730
12-02-2018, 11:35 AM | #49 |
Rep 24
I have this error with kafas2 I am just doing the ugrade of kafas can help me.
please TAL execution started. ExecutionID=2018/12/02-17:09:25.348 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForFlash started MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [] prepareVehicleForFlash finished [KAFAS2 - 5D] There was an error during TAL execution, please check the log files. [KAFAS2 - 5D] - [Exception - KAFAS2 - 5d] SVK-Ist does not match expected SGBMIDs for ecu ECUId:KAFAS2_0x5D. Excpected (relevant process classes only): [hwel_00000fb7-000_010_001], Actual (relevant process classes only): [hwel_00000bd0-000_005_001], Missing SGBMID(s): [hwel_00000fb7-000_010_001], Surplus SGBMID(s): [hwel_00000bd0-000_005_001] [KAFAS2 - 5D] installECUBL started [KAFAS2 - 5D] installECUBL finished [KAFAS2 - 5D] finalizeECUBLUpdate started [KAFAS2 - 5D] finalizeECUBLUpdate finished [] finalizeVehicleFlash started [] finalizeVehicleFlash finished [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "1min 8s". [C206] |
12-02-2018, 11:54 AM | #50 |
Rep 40,730
Wrong I-Step Shipment. I replied to your same PM.
12-02-2018, 12:32 PM | #51 |
Rep 24
kafas2
12-02-2018, 12:35 PM | #52 |
Rep 40,730
I have no idea what you have going on with your Retrofit, but if you have CAFD with Green Dot, then CAFD is good.
12-02-2018, 12:42 PM | #53 |
Rep 24
12-02-2018, 12:48 PM | #54 |
Rep 40,730
KAFAS Camera supports HBA. New SZL Stalk is also needed, and proper coding.
12-02-2018, 12:51 PM | #55 |
Rep 24
12-02-2018, 12:55 PM | #56 |
Rep 40,730
No, sorry. I never retrofit neither SZL nor KAFAS myself.
12-02-2018, 01:09 PM | #58 |
Rep 40,730
12-02-2018, 03:16 PM | #59 | |
Rep 24
now I have the new one from 01/03/2017 with hba i have car 2015 Last edited by outubro; 12-02-2018 at 03:18 PM.. Reason: date |
12-02-2018, 03:20 PM | #60 | |
Rep 40,730
Anyway, good luck with retrofit.
12-02-2018, 03:25 PM | #61 |
Rep 24
kafas2
12-02-2018, 03:34 PM | #62 |
Rep 40,730
As I wrote above:
I have no idea why your HBA is not working.
03-14-2019, 02:12 AM | #63 |
Rep 22
I have an error on flashing retrofitted NBT Evo Touch.
Log: Read SVT before TAL execution started. TAL execution started. ExecutionID=2019/03/13-10:08:40.712 [] prepareTALExecution started [PROGRESS] [] prepareTALExecution finished [PROGRESS] [] prepareVehicleForFlash started [PROGRESS] MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=20600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=CC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] MCDDiagService<id=76600, job=com.bmw.psdz.jobs.common.MCD3_PrepareVehicleFo rFlash, service=RC_SEM, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] [] prepareVehicleForFlash finished [PROGRESS] MCDDiagService<id=230900, job=com.bmw.psdz.jobs.common.MCD3_ActivateProgMode Cascade, service=DSC - DiagnosticSessionControl, description=error: timeout, link=HU_ENTRYNAV_63_ETHERNET_63> [DIAGSERVICE] MCDDiagService<id=230900, job=com.bmw.psdz.jobs.common.MCD3_ActivateProgMode Cascade, service=DSC - DiagnosticSessionControl, description=error: timeout, link=HU_ENTRYNAV_63_ETHERNET_63> [DIAGSERVICE] MCDDiagService<id=230900, job=com.bmw.psdz.jobs.common.MCD3_ActivateProgMode Cascade, service=DSC - DiagnosticSessionControl, description=error: timeout, link=HU_ENTRYNAV_63_ETHERNET_63> [DIAGSERVICE] MCDDiagService<id=242900, job=com.bmw.psdz.jobs.common.MCD3_ActivateProgMode Cascade, service=RC_SDB - RoutineControl SetDefaultBus, description=error: timeout, link=HU_ENTRYNAV_63_ETHERNET_63> [DIAGSERVICE] [] Activate programming mode was not successful for: ECUId:HU_ENTRYNAV_0x63 [WARN] [] ECUId:HU_ENTRYNAV_0x63 not accessible cause could not be switched to parallel programming mode [WARN] [HU_ENTRYNAV - 63] ECUId:HU_ENTRYNAV_0x63 not accessible cause could not be switched to parallel programming mode [THROWABLE] [] ECUId:HU_ENTRYNAV_0x63 not accessible cause could not be switched to parallel programming mode [WARN] [] finalizeVehicleFlash started [PROGRESS] [] finalizeVehicleFlash finished [PROGRESS] [] prepareVehicleForCoding started [PROGRESS] [] prepareVehicleForCoding finished [PROGRESS] [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "2min 30s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished. Doing all with the ECU Flashing guide 1.01 E-sys 3.27 place this errors, E-sys 3.30 don`t allow to check boxes BlFlash, SwDeploy, CdDeploy, IbaDeploy. |
03-14-2019, 09:42 AM | #64 |
Rep 40,730
Assuming you are using ENET Cable, did you move Ethernet from Quadlock to OABR?
03-14-2019, 11:05 AM | #65 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
03-14-2019, 12:10 PM | #66 |
Rep 40,730
PM sent.
