03-01-2018, 12:25 PM | #23 |
Rep 190,805
Nice
03-02-2018, 08:04 PM | #25 | |
Rep 115,980
Mike |
03-05-2018, 11:02 AM | #26 | |
Rep 20
That will definitely get you some nice reliable power and not to mention the amazing turbo spool you get with a catless downpipe. |
eluded3041.50 |
03-28-2018, 11:47 PM | #27 |
Sergeant First Class
87
Rep 150
When you replace the downpipe on the 340i do you need to replace either the upper/lower clamps like people say on the 335i? If so does anyone have a link to buy the clamp or clamp kit with gasket. I looked on ecs there website was kinda difficult to navigate.
05-18-2018, 12:04 PM | #28 |
Rep 77
I got the intake already installed. And just ordered the DP catless. I will call the guys to schedule a dyno before i install DP, and then run with DP, no jb4, and then DP with jb4.
05-18-2018, 01:14 PM | #29 |
Rep 190,805
05-18-2018, 01:17 PM | #30 |
Rep 2,964
06-25-2018, 10:32 PM | #33 |
Rep 1,369
This is B58 land. Our OEM charge pipe is stout.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
09-05-2018, 08:01 PM | #36 |
Rep 1,369
Just do it. The sound and quicker spool on their own are so worth it.
Here4MT3.00 |
09-08-2018, 09:58 PM | #38 |
Rep 95
biggest limitation with jb without EWG connector is that you cannot change / offset the waste gate position, therefore even if you ask for more boost the ECU limits the amount of waste gate and therefore you do not make your target boost
basically the ECU only allows the waste gate to vary in a tight range for boost control that limits what a simple piggy back can do in my experience DP is pretty effective in generating 3-5 PSI more boost at effectively the same waste gate position hence I would conclude that JB+ DP may be perfect combo...or at least will allow you to get more boost without adding the EWG wiring |
09-09-2018, 11:55 PM | #39 | ||
Rep 12
M Sport, Track Package, BMS intake, JB4, ER DP, 437M wheels with Super Sports.
09-20-2018, 11:51 AM | #40 |
Rep 20
I might add I have been running an o2 spacer that eliminates the CEL on a catless downpipe for the past 5k plus miles and no hiccups.. the JB+ with catless downpipe has been the perfect combo for my application. Absolutely flawless with no "drivetrain malfunctions" that some of my friends get while running a JB4.
