09-02-2019, 03:58 PM | #353 | |
Rep 282
the highpressure fuel pipe tweak is only minor , but the pipe itself is quite hard , cant bend it by hand . the connector has to be trimmed and the intake manifold also like in the pictures otherwise you might damage the connector . in terms of percentages i would be very cautious with estimates , evo is only marginally better compared to oem , hdp6 is waaay better . when i get a ethanol map from wedge we'll see how far it will stretch .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
09-02-2019, 07:02 PM | #354 | |
Rep 128
09-02-2019, 09:09 PM | #355 | |
Gettin It Figured Out
1818
Rep 2,669
Bump for updates....any word from Spool Performance? .
09-03-2019, 02:55 AM | #356 |
Rep 282
for some reason they are hard to find , while they are produced in bmw's for two years now :s
09-03-2019, 04:04 AM | #357 |
Rep 2,351
It is a bit strange indeed as these pumps sit in everything from B38B to B58D. Mini and BMWs... I thought I had a good source until I found my spareparts lady tried to sell me the EVO pumps. She though a B58 pump is just a B58.
(A Dane in China) |
09-05-2019, 06:52 AM | #359 |
Rep 282
got the first revision of E30 map in for a test ,
hdp6 holds up pretty well https://datazap.me/u/thomas/e30-v1?l...ata=4-19-20-21
09-05-2019, 08:00 AM | #360 |
Rep 1,467
Seems like there is quite a bit if modification required with the hdp6. Id rather hold out for an aft pump or just go with the xdi which you now will drop right in. Bending the connections doesnt seem like something id do or id trust a shop to do.
We need a plug and play solution for this! |
09-05-2019, 08:14 AM | #361 | |
Rep 282
you dont need extra coding and dont need to modify your Lp fuel line aswell . all in all its about the same amount of job compared to xdi or else .
09-05-2019, 05:34 PM | #362 | |
Rep 1,105
Seems like your targeted boost is off by about 2psi around 6000rpms and then by 4psi by 6700rpms. The results do look promising though!! Keep up the good work my friend
09-08-2019, 05:17 AM | #365 |
Rep 282
good luck with the swap , pls post some pictures while doing it
Pray for Mojo429.50 |
09-08-2019, 06:28 AM | #366 |
Rep 1,105
09-08-2019, 07:59 AM | #367 | |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Looking at WGDC and the overall boost curve, I wouldn't say it's a boost leak. I'd say that it's part of the tune. Scaling up WGDC and lowering requested torque should bring the two closer together, I think.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
harkes1071.50 |
09-08-2019, 08:37 AM | #368 | |
Rep 1,105
Thanks for the input |
09-08-2019, 10:11 PM | #369 |
Rep 928
Price is going to be just a little north of 850 and their getting really close, but not there yet. I'll update here as soon as I know more.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
09-08-2019, 11:02 PM | #370 | |
1818
Rep 2,669
Welll North of $850...but South of $1600 . .
09-09-2019, 09:43 AM | #371 |
Rep 1,115
09-09-2019, 12:25 PM | #372 | |
Rep 500
Drives: BMW 330e F30 M-sport
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
09-09-2019, 03:21 PM | #373 |
Rep 1,115
You worried about the issues MP had with this pump on their B58s? Apparently they cooked a B58 DME running full E85 and had to write custom firmware for the pump. Your early results seem promising with no coding changes.
09-09-2019, 03:22 PM | #374 |
Rep 1,115
