Login
08-13-2015, 02:09 PM | #1 |
![]() ![]() 19
Rep 61
Dinan Stage 1 & Stage 2 install
Hey guys! I got two questions around Stage 1 and 2 with MPPK.
1. Has anyone installed Stage 1 or Stage 2 in Houston, TX? What was your out the door cost? 2. Dinan site is confusing me. See the attached screecapture. The site says the BMW factory torque measured is 365 and peak torque for Stage 1 is 417. So that is a gain of 417-365 = 52. The why does it say the max torque gain is 75! ![]() ![]() Couldn't upload the image. Here is the link, go to the specs tab http://www.dinancars.com/product/d44...ries&mid=1205/ Last edited by LUV335; 08-13-2015 at 02:13 PM.. Reason: Noimage |
08-13-2015, 02:16 PM | #2 | |
![]() 2065
Rep 2,307
Posts ![]() |
Ultimately Peak Power and Max gains very different as they happen at different RPM. |
08-13-2015, 04:40 PM | #3 | |
![]() ![]() 19
Rep 61
Thanks is much clear now
Also, Stage 2 plots show that they include the Dinan exhaust. Does the exhaust add power and TRQ? If so by how much? Thanks. |
08-13-2015, 05:16 PM | #4 | |
![]() 2065
Rep 2,307
Posts ![]() |
In general if you plan to just tune the car with no hard part upgrades I would just do the stage 1 tune. You can always upgrade later for just the difference in cost if you choose to do so. |
08-15-2015, 10:38 AM | #5 |
![]() ![]() 19
Rep 61
Thanks for the info Dinan..
Anyone like to share out the door cost in Houston, anyone? How hard is it to install this yourself? I am not a super DIY guy. The only work I have done on my car is to install the BAV sound speakers. I cant imagine this will be very hard? Can you screw the install easily? Oh and any warranty issues if its installed by yourself and not the Dinan shop? |
08-17-2015, 01:03 PM | #6 | |
![]() 2065
Rep 2,307
Posts ![]() |
Self install or 3rd party would still retain the Dinan warranty with the caveat that we would not warrant anything that occurs as a result of improper installation. If you jam a plug into the wrong ECU connection and start the car frying the DME that would be on you as an example. Given, something like that is pretty hard to do but it needs to be noted regardless. =) |
08-17-2015, 01:24 PM | #8 | |
![]() ![]() ![]() ![]() 126
Rep 755
08-17-2015, 06:15 PM | #9 | |
Gettin It Figured Out
![]() 1765
Rep 2,670
01-23-2021, 08:23 PM | #10 |
M435i
![]() 0
Rep 10
Hi Dinan engineering..question regarding the new n55 Stage 2 flash software. The big turbo change is super costly to do both in parts and labour. What would be the result of upgrading spark plugs, coils, intercooler, intake, charge pipe, downpipe and add the Dinan Stage 2 flash software, like any other tuning stage 2 and 2+, that is?
01-24-2021, 10:53 AM | #11 | |
![]() 260
Rep 841
2015 335i xDrive 11.76 on stock turbo. (dragy) uphill!
2015 X3 x35i 12.96 catless w/bm3 stage 2 flash IG: @N55David For pics and updates! Youtube: @ n55david For videos or Racing etc |
01-25-2021, 10:03 AM | #12 | |
![]() 2065
Rep 2,307
Posts ![]() |
As noted above its a bit different comparison as the supporting mods are geared differently. Our stage 1 flash on the N55 though is right in the mix, as far as power numbers go, with the rest of the market. Its also one of, if not the cheapest option on the market for F chassis N55 flashes. |
M435i0.00 |
01-25-2021, 11:02 AM | #13 | ||
![]() 260
Rep 841
in what world would I even give you guys a thought in regards to a tune? I'm not trying to be a dick or anything. I know you guys have a market but it just doesn't make sense to me when there appears to be more cost effective options that will get more power in the long run.
01-25-2021, 02:22 PM | #14 | |
![]() 2065
Rep 2,307
Posts ![]() |
Long story short Dinan is still heavily invested in the OEM+ side of things and that is a bit different market to cater to then others. I will say we are starting to depart from that a bit in some of the development currently underway so our appeal may spread out a bit in the not so distant future. At that point maybe there will be more value to others like yourself but until then --- competition and a multitude of options are friends of the marketplace. |
01-25-2021, 02:34 PM | #15 | ||
![]() 260
Rep 841
![]() honestly I am curious about the adaptive suspension flash. I know I'm interested in that.
01-25-2021, 02:49 PM | #16 |
![]() 2065
Rep 2,307
Posts ![]() |
If you have electronic shocks, Shockware is a no brainer. The flash is next to nothing in cost and the labor is minimal (half hour to hour depending on shop minimum). It is easily the most inexpensive and transformative suspension mod you will ever have. I like to think of it as putting springs on the car without changing any of the geometry. It just rides better/flatter and pretty much elimates the unnecessary floatiness of the stock suspension.
Phantom10R260.00 |
01-25-2021, 03:28 PM | #17 | |
![]() 1811
Rep 3,444
Phantom10R260.00 |
02-27-2021, 03:36 PM | #18 | ||
M435i
![]() 0
Rep 10
