BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY - F30 OEM Backup / reversing camera retrofit installed!
      09-18-2020, 12:32 PM   #639
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Originally Posted by Suprnowa View Post
I connected and coded as you wrote. I took the power of the camera from the reverse lamp
Unfortunately, the image from the camera is black and white, then some horizontal lines appear and then the image turns off everything is gray.
Previously, the same camera connected to Android worked Ok and the image was in color
Look into something like this...read the description on the listing. It may or may not fix your issue.
https://www.amazon.com/Dasaita-Capac.../dp/B074P35T3M
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      09-21-2020, 08:30 AM   #640
hugo325
Drives: 118i (M sport) [F20-2018]
Hi everyone,
I also have the same problem regarding the display of the "TRSVC" module in my SVT.
My FEM module does not have any default wire on the K_CAN 51/52 pins (A173*8B).
Once connected, I checked the voltage levels on the connector of my "TRSVC" module (A167*2B). All is OK
I have 12V on pin 7 (Supply, terminal 15)
1.8V on pin 6 (K-CAN_L)
3.3V on pin 5 (K_CAN_H)
Pin 1 is well connected to the ground plane.
I add "3AG" in my FA code.
Unfortunately I don't have a "TRSVC" module that appears in my SVT ...
I have the fault error :
E59449 No message (status, qualifier rear-view, 0x39B), REM receiver, TRSVC transmitter
My car model is : 118i (F20) LCI (04/2018), I-step 17-11-540.
The reference of my FEM is : 61358707677-01
ZB FEM LEAR V13
HW: D9.0, SW: 16.114.030
It's so strange because when I do a TAL calculating (with my Istep shipment), I get a TRSVC.
So normally my TRSVC module should be recognized ...
Only the hardware version is wrong between the TRSVC display by TAL calculating (HW: 10.003.000) and my TRVSC purchase (HW: 10.002.000).
Does anyone have an explanation to this ?
      09-21-2020, 10:52 AM   #641
atzebmw
Drives: Tesla Model 3
Originally Posted by hugo325 View Post
Hi everyone,
You can try to connect the 2 K_CAN wires with Pin 33/34 on A173*7B.
https://www.newtis.info/tisv2/a/en/f...-2v/1VnXT4PbeT
If you then have the same problem the TRSVC is defective i think.
      09-21-2020, 12:05 PM   #642
hugo325
I just checked, I don't have anything on pin 33/34 (A173*7B).
I try to connect the bus to these 2 pins anyway ?
The exacte wiring schematic is :
https://www.newtis.info/tisv2/a/en/f...-2v/1VnXgq8kBl
      09-21-2020, 12:42 PM   #643
atzebmw
But on pin 33/34 (A173 * 7B) the control unit for the air conditioning must have be connected. So the K_CAN must definitely be activated there. And that in any case.
You can anyway try connecting the 2 pins there.
      09-21-2020, 03:22 PM   #644
hugo325
No sorry on my car 118i, the air conditionning is connecting to K_CAN2 on the connector X20*1B.
I think my TRSVC module is dead, so I will change it in few day...
I hope I am right.
      10-08-2020, 01:32 AM   #645
Maxfusion
Drives: 320I XDrive
Originally Posted by Jaykob View Post
Hi guys!
I'm trying to figure out the best solution for my 6/2016 320d F31 with NBT EVO ID4.
I'm reading that mine doesn't support ICAM, is that correct?
However I've heard that there are special adapters (CAN-filters) that I could use? Like this one: http://carsystems.com.ua/bmw-product...fit-adapter-en
Quality-wise the ICAM should be preferred over the TRSVC solution, right?
I have the same question. 320I 06/2016 with retrofitted NBT Evo Touch ID6.
Can we install ICAM natively without special adapters and without changing FEM to a newer version?
      11-16-2020, 10:53 AM   #646
scoopy
Drives: f30 320d
I dont have can wires in pin51 and 52 then i saw these i tried using positap however i dont have any trsvc module showing up in esys and ista can someone help me?[IMG][/IMG]
Alsontried the yellow red anf yellow orange but not working
Adding the error in ista
      11-16-2020, 11:12 AM   #647
scoopy
Drives: f30 320d
quick question if you VO 3AG does that mean trsvc should be in ista? regardless if the ground and 12v is not connected or the can wires is wrong should it be in insta and should shaded red? or if there's not power or wrong can wires it will not show up in ista?
      11-16-2020, 11:07 PM   #648
scoopy
Drives: f30 320d
Soldered and added a line for pin 51 and 52. Started the car and check the voltage in the pin of the trsvc. Pin 1 and 7 i get 14.2v. Orange/green wire i get 3.5v. Green wire i get 1v. Does that mean wirings are all correct anfd the problem is my module might be broken?
      11-17-2020, 10:35 AM   #649
atzebmw
If the connection isn't correct it will not show in ISTA or E-Sys.
You can only measure the ground or 12V but not the KCAN lines.
After you connected to Pin 51 and 52 do you see the TRSVC now in ISTA or E-Sys?
      11-18-2020, 09:57 AM   #650
scoopy
Drives: f30 320d
yes i did. was able to connect it already and was able to install an 8.8" screen also. what i want to do next is to retrofit the pdc/camera button
      11-21-2020, 02:16 AM   #651
SniPro
Drives: BMW F30 320i LCI
Hi all,
Does anybody know if EntryNav2 head unit supports in general original rear view camera iCam (66 53 7 951 083) retrofit?
In case only some of EntryNav2 supports does HU with part number 65 12 8 720 702 supports it? I can not find any evidence that FBAS on it working and it supports option 3AG.
Thanks in advance
      12-30-2020, 06:28 AM   #652
DimitrisM3
e90 my big fat lady!
DimitrisM3's Avatar
Greece
49
Drives: e90
so i have e90 with nbt unit how possible is to install oem camera retrofit from f30?? i think can be done i am not very sure..
need small help guys !!
      01-06-2021, 03:21 PM   #653
alecs_1000rr
Romania
Drives: Bmw f30 328i
Hi guys and thx a lot for all the incredible info that i found here. I ve installed the camera like roxxor said and for the nbt evo, the navi pins are red21, shield 23 and white 24. I had the short cable, the one for the f10 so i ve mounted the module, in the place that other cars have the combox. I had to split the cables, so that i can keep the green in the back, to connect it to the fuse box beside the combox and the kcan to route them neer the idrive.
All in all, it works perfect. Thx a lot again, all of you are great!
      02-02-2021, 07:35 AM   #654
Queiroz
Drives: F31
Hello guys,
If someone can help me out.
I’ve installed a rvc in my 2013 f31
Coded fdl but can’t get picture in NBT
I have the menu option to select rvc but no image...
Just a black square where the video feed should be.
I’ve tryed different settings, icam, trsvc, and nothing seems to work.
It’s an emulator box, connected to pin 21, 23 and 24.
It’s also connected in quad lock to power, ground, can-H and can-L
Any thoughts?
      02-02-2021, 11:00 AM   #655
Queiroz
Drives: F31
[img]https://i.ibb.co/wN4vKS4/780220-CA-0...4-C3-A0862.jpg[/img]
This is what I get
      02-05-2021, 12:15 PM   #656
Queiroz
Drives: F31
[img]https://i.ibb.co/YLSQ6JF/B76296-F2-4...370-BCF284.jpg[/img]
Any opinions please?
      02-08-2021, 03:17 AM   #657
THE_AVIATOR
THE_AVIATOR's Avatar
Egypt
Drives: F30 320i LCI M-Sport
Originally Posted by Queiroz View Post
Do you receive any failure messages? i.e Camera fault, or something? Tell me your setup with the emulator, where is the camera connected? The emulator is replacing the control unit?
      02-15-2021, 01:16 PM   #658
Queiroz
Drives: F31
Hello,
I only have this error in ista.
Camera is connected to emulator box, seller is great, send a new box to see if that's the problem, I'm going to check tonight
      03-05-2021, 04:05 PM   #659
Queiroz
Drives: F31
[img]https://i.ibb.co/5RkQJ4N/4-D907196-A...57-E37-ED1.jpg[/img]
[img]https://i.ibb.co/Wpj5GyF/E9-C04-A56-...-CF7149-A9.jpg[/img]
Can someone share any opinions please?
      03-16-2021, 05:14 AM   #660
DLucian
Drives: E91 335i N55 | F20 125I B48
Looking into doing this retrofit and I have a question (sorry if it has been asked, did try and search through posts first).
I am looking into different TRSVC modules from scrappers. They are usually quite old (like 2010 - 2013). I see the part number has updated over time.
My main concern is having the moving guide lines available and the obstacle highlights. Do I need a TRSVC module upwards of a certain year (or part number) to have this available?
What I am missing is where are these features implemented. In the HU / PDC or in the TRSVC module? If they are not coming from the TRSVC then my guess will be that the age of the module doesn't matter. Am I correct?
Thanks in advance.
