BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > BMW Brake Torque Specifications
      11-04-2019, 09:10 PM   #1
mportd.f32
mportd.f32's Avatar
Drives: 2016 BMW 435i xDrive
Hi,
I own a 2016 435i xDrive and am looking to replace the brake discs. If you have a service manual for the F32, and willing to lend me the values for job, please let me know.
Thanks!
      11-04-2019, 10:47 PM   #2
johnung
Originally Posted by mportd.f32 View Post
Hi,
Thanks!
Attached are brake torque specs for F3x.
I highly recommend upgrading the four brake rotor hold screws to stainless steel so that they will never rust and seize. Both Turner & ECS sell them for ~$15/set of four.
Also recommend Zimmermann rotors. High quality German rotors better than OEM because they are zinc coated against rust. Very reasonably priced.
Best replacement street pad is Hawk 5.0. Superior in every way to stock pads. More reasonably priced than inferior pads that others taught.
Replace brake fluid every two years for safety. At same time upgrade to StopTech stainless steel brake lines for ~$106/set of four. There are other stainless lines that cost more. Much more solid brake pedal feel.
Hope this helps!
      11-05-2019, 11:53 AM   #3
therealm3
Drives: F30 340 MSport
great info for us DIY'rs. Thanks!
      11-05-2019, 09:20 PM   #4
johnung
Here are some Hawk 5.0 brake pad part numbers that I forgot to attach
      11-06-2019, 07:35 PM   #5
mportd.f32
mportd.f32's Avatar
Hope this helps!
Thank you for the help, but do you mind elaborating on what those terms mean for the first three tightening torques? Sorry but I'm pretty new to working on my own car.
      11-07-2019, 05:27 PM   #6
johnung
Hope this helps!
If you are new to this car a great resource would be to buy a Bentley manual for your model. Attached is a photo example of a Bentley manual for 3-Series 2012-2015. There are a bunch of online resources out there too. I'm just used to grabbing a shop manual like a Bentley.
The first line of the torque specs is just the single screw that holds the brake rotor onto the hub. It's the part that I said likes to rust on so replace it with a stainless steel screw.
I'll see if I can find diagrams to illustrate the other two.
      11-07-2019, 05:38 PM   #7
johnung
Hope this helps!
Couldn't find diagrams that I liked. #2 and #3 are torques for the bolts that hold the calipers onto the hubs. It'll be obvious when you get the wheels off and get a good look at it.
      11-07-2019, 07:37 PM   #8
mportd.f32
mportd.f32's Avatar
Currently my car is in for window tints and will be back tomorrow. Once I get it back I will be able to look at it and see. I also know there is a service manual for my car I'm trying to save the $120, though. And thank you for all the help,
- Mike
      11-07-2019, 08:43 PM   #9
johnung
- Mike
The prices of the shop manuals has gotten high. Keep an eye on the Black Friday sales coming up. A while back I spotted my Bentley manual on sale for 1/2 off somewhere and bought it immediately
      11-07-2019, 08:53 PM   #10
mportd.f32
mportd.f32's Avatar
Do you ever stop helping me? Lmao thanks so much
#435i, #brakes, #f32, #xdrive
