08-19-2020, 04:07 PM | #1 |
Rep 177
Lightweight 19s for le$$
I had been searching pretty extensively for a new set of wheels for the F34. Really wanted to stay OEM due to build quality, but most OEMs are not light at all. Same thing with OEM reps. Also my car being xDrive makes tire size selections limited... so couldn't really go with M2/M3/M4 take-offs.
Thankfully the aftermarket scene for BMW is huge. After scouring through vendor sites, eBay, Amazon, Google Shopping etc., finally landed on these. Aodhan AFF7 19x8.5/9.5 They seem to be a fairly new brand and use a tech called SPF (single phase forging) on couple of their wheel designs, including the AFF7s. Most likely this is similar to 'rotary forged' or 'flow forged' wheels. The weights listed for the 19s are ~20.5 lbs each! I was skeptical about this and put these on the scale as soon as I got them, and sure enough that's accurate. I also weighed them with my new tires mounted (see pics), and look like they will be way lighter than my 400m + RFT combo. The centerbore size is the same as BMW's, so no hubcentric rings are needed. Really looking forward to putting these on after the car is back from the shop and shedding some unsprung weight. Front 19x8.5 et35 225/45 Rear 19x9.5 et35 255/40 w/ Vredestein Quatrac Pro mounted |
08-21-2020, 02:19 PM | #3 |
Rep 1,909
Interested in these. Im assuming they dont accept the oem size center caps? They fit w/ no rubbing without the use of spacers?
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
08-21-2020, 05:26 PM | #4 |
Rep 177
Should have some 'on car' pics/ impressions by the weekend.
The centercaps are 60mm, so not OEM size. I've ordered these metal stickers from Portugal of all places... so they may take a while to show up, given the poor state of USPS. https://www.etsy.com/transaction/2007575952 Last edited by Torquey; 08-21-2020 at 05:31 PM.. |
08-23-2020, 01:08 PM | #5 |
Rep 177
Put these on yesterday... fitment is nice! The fronts wheels are almost flush with the fenders... but because of the 225s on them being slightly stretched, they don't quite look like it. I bet with some 245s, they would be, but then it may get too close to the struts under 'full lock'. The rears are pretty aggressive... prefect IMO! And again the 255s are a little stretched on 9.5s, which helps with no rubbing on the fenders lips whatsoever (on stock xDrive suspension). There's also a bit of a difference in the amount of concave between the 8.5" and 9.5" sizes of these wheels. This is by design and you can notice the spokes of the rear wheels having more of an inward angle than the fronts. Both clear the 335i grey Brembos just fine.
I've driven for about 50 miles or so both highway and city streets... mixture of dips, pot holes, surface irregularities, expansion joints etc. and at 34 psi all around, it feels firm but confident. I've had Vredesteins before and they are one of the best UHP All Seasons you can get... check out their 9.5/10 ratings on Tirerack. Car definitely feels 'lighter on it's feet' during acceleration, turn-in and braking... but I need more time behind the wheels to fully experience it. The stock 18" 400M & RFT combo were 54.5 lbs each... so total amount of unsprung weight shed was 36 lbs... and this is going from 18s to 19s! I did get them "Road Force" balanced... no vibrations or shakiness all the way up to 80mph so far. Lastly the TPMS reset is getting hung at 49%... probably due to the aftermarket TPMS that I put in Last edited by Torquey; 08-25-2020 at 03:44 PM.. |
08-23-2020, 04:51 PM | #7 | |
Rep 177
Pussiwillow521.00 |
08-24-2020, 09:39 PM | #9 |
Rep 77
Wow this is actually exactly what I'm looking for -- down to color, style, price, weight... great find Torquey
Please give us another update once you've gotten a chance to break them in. I'll probably see a similar improvement from 54lbs --> 46lbs. If you haven't run into any issues I might have to cop these myself |
Torquey92.00 |
08-25-2020, 01:27 PM | #10 | |
Rep 177
08-25-2020, 03:15 PM | #11 | |
Rep 77
How's the quality of the finish? I wasn't able to tell if it was painted or powdercoated. Almost worried it's too good to be true |
08-25-2020, 07:48 PM | #12 | |
Rep 177
The finish seems to be paint and not powder coat. They offer 1-year structural warranty for some peace of mind. My biggest goal was to achieve 'lightness' in 19" within particular offset range, then came design, color etc. ... all in all for this price I doubt if I could've done better. |
BAKKI18.50 |
08-27-2020, 10:24 PM | #13 |
Rep 1,288
Your running 45f/40r sidewall ratio? .... it's not to bad... @ 60mph your only doing 58mph...
08-27-2020, 10:39 PM | #14 |
Rep 483
08-27-2020, 11:10 PM | #15 |
Rep 1,288
Tirerack says 225/45/18 is standard... hmmmm....
He's running 8.5 in the front... he could go 255/35/19 in the front and 285/30/19 in the rear I think... I'm looking for 18 x 8.5" x 30 offset... I want to run 255/40/18 square.... I have 255/40/18 in the back now which are the staggered stock... Last edited by FastF30; 08-28-2020 at 01:11 AM.. |
08-28-2020, 05:36 AM | #16 | |
Rep 483
08-28-2020, 01:30 PM | #17 |
Rep 177
Yes, the F34 Gran Turismo is a bigger and taller car... so the recommended tire profile is +1 compared to F30/32/36. On top of that being xDrive makes you stay within 1% variance in diameter between front and back. I'd love to put 275/35s in the back, but then the front will have to come within 1% of that diameter, which could be tricky.
So I kept the tire sizes the same as 19s that came stock in some GTs. For a daily driver that is more than enough, plus the tire tread width being a little narrower than the wheel width is supposed to improve steering response. Last edited by Torquey; 08-28-2020 at 01:39 PM.. |
FastF30521.00 |
08-28-2020, 09:23 PM | #18 | |
Rep 483
08-29-2020, 11:03 AM | #19 |
Rep 111
Looks like these replaced the cast version (LS007) that I was looking at earlier this year. I probably would have went with the AFF7 if available, but I'll stick with my 437M take offs at this point.
08-29-2020, 03:11 PM | #20 |
Rep 177
I got the tires from Tirerack as I've always preferred their service (brand/size selection, fast free shipping & 2-yr road hazard incl.). I was looking at wheels there too as a package.. but couldn't find any that met all my criterias. So the wheels, tires and TPMS came from three different places. Somehow I managed to fit them all in my E60 and take it to Firestone (rare 'fold down' rear seat option FTW). Later I put them on the F34 myself and hand torqued the lugs.
09-04-2020, 01:00 PM | #21 |
Rep 694
Looks great, I got a set of these off Ebay back in November b/c Im cheap and the price was right!
I cracked one during COVID going to see my parents but there was a drain cover in the middle of the road and I didnt see it. You def have more sidewall on yours so I think youll be fine. Heres the silver for anyone else toying with the idea |
Torquey92.00 |
