01-28-2023, 05:09 PM | #23 | |
Rep 19
I upgraded taillights from preLCI to OLED and before it was ok, but now I have issue with the fog lights. Left tail light is working correct. But on the right tail light, when I turn on fog lights, fog light and reverse both light up. Meanwhile on the left one only fog light is on. What exactly did you do on BimmerCode to reset this? |
01-30-2023, 01:22 AM | #25 | |
Rep 19
Is it possible to do it also via BimmerCode? Or just esys? I read my values for fog lights and they are nsl_l = 0x1c for left and nsl_r = 0x1d. Are they good or should I do something about the right one? |
01-30-2023, 06:15 AM | #26 |
Schmollbraten
12512
Rep 1,985
Im not entirely sure that the replacement units holds fog lights on both sides or as it is enabled into most countries just the r/h side (driving direction).
If you had coded to have both active at activation, the signal will override the gear selector for reverse and both are on, as you had described.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
01-30-2023, 06:33 AM | #27 |
Rep 2,047
Use esys to VO code. Not possbile with bimmercode.
01-15-2024, 07:01 PM | #28 | |
Rep 71
As a side note, is it normal to have the headlights and tail lights turn on at the press of the rear fog light button as well? |
01-17-2024, 12:51 AM | #30 |
Rep 584
Drives: 2018 F48 X1 xDrive 18D
Yes BMW have like bad weather mode.
If the wiper is turned on and/or fog lights then it goes in bad weather mode |
