08-12-2021, 04:31 PM | #23 | |
Rep 15,858
You won't be the first that has a misaligned steering wheel that can't be sorted on a rig. Requires the human touch to correct. BTW, I can illustrate with experience and no long term issues, or odd tire wear. |
Wgosma806.00 |
08-12-2021, 04:37 PM | #24 | |
Rep 48
08-12-2021, 04:39 PM | #25 | |
Rep 15,858
08-13-2021, 06:36 PM | #26 |
Rep 48
So I contacted belle tire and they said they don’t hold on to paperwork…. Absurd if you ask me. So unfortunately I won’t be getting those papers… what is interesting is that the steering wheel goes back to dead center when I come to a complete stop.
08-14-2021, 09:06 AM | #27 |
Rep 1,905
Odd response from Belle tire….drop that shop off your list going forward. I'm not that familiar with this electronic steering setup, hopefully others chime in with advice for you.
Your car has quite low/modest mileage, seems a little hard to believe component wear is the issue, but one never knows. Good luck/Bill |
08-14-2021, 09:27 AM | #28 | |
Rep 48
Wgosma806.00 |
08-14-2021, 09:36 AM | #29 |
Rep 1,905
sounds like car is running along and tracking properly, keep an eye on tire wear down the road, even subtle mis-alignment can often cause visible irregular tire wear pattern.
08-14-2021, 09:46 AM | #30 |
Rep 109
I’ve owned 2 2017 330i and both my steering wheel was slightly turned to the left. I was told the road crown (I live in Florida) could cause this but the cars where aligned. I have a friend who has an 2018 340i and he said his is slightly left also. Could be a characteristic of the car. Yes this drives me nuts but I guess I’ll have to just deal.
08-14-2021, 10:38 AM | #31 |
Rep 48
This is really bothering me. The car does drift slightly to the right, that’s how the steering wheel is tilted as well. Going to go get an “alignment” done so I can get the damn read outs. I’m thinking it may be as simple as adjusting tie rods… but this is seriously bothering me.
08-14-2021, 11:59 AM | #32 | |
Rep 15,858
Don't be mislead by the fact many examples do have an offset steering wheel.
The key factor is, does the car track straight on the crown of the road (flat surface) without pull? Camber drift should be equal both ways. I wrote the following, years back in another discussion topic on wheel position. Quote:
Wgosma806.00 |
08-14-2021, 01:15 PM | #33 | |
Rep 48
08-14-2021, 04:55 PM | #34 | ||
Rep 1,905
08-14-2021, 06:20 PM | #35 | ||
Rep 500
08-14-2021, 07:17 PM | #36 |
Rep 48
08-14-2021, 08:01 PM | #38 |
Rep 500
08-14-2021, 08:26 PM | #39 |
Rep 48
Wheels are new as of a few days ago… do you think I could have bent a rim? I mean as soon as I hit the pothole I previously mentioned, I pulled over got out of the car, checked everything and have checked pretty much every morning since, lol.
08-14-2021, 08:35 PM | #40 | |
Rep 500
08-14-2021, 09:21 PM | #41 |
Rep 48
08-14-2021, 10:50 PM | #42 |
Rep 48
I’m going to actually get under the car hopefully Wednesday or Thursday, see if I can spot something myself. I don’t see how my inspection would be different than the dealers but let’s find out
08-15-2021, 04:38 AM | #43 |
Rep 332
Does the car pull when you don't touch the steering wheel or does it not go straight when you have the steering wheel straight?
I had a similar issue and it was the steering angle sensor. When I reset it through ISTA it was perfect afterwards. I took it to BMW and even they didn't do this step. |
08-15-2021, 07:15 AM | #44 | |
Rep 48
alignment, bmw, steering, tire |
