05-14-2018, 08:37 PM | #67 | |
Rep 1,953
Drives: 2013 328i xDrive
Edit: Nevermind you said that you have the non M Sport wheel. Might have been the way you connected it then? |
05-14-2018, 08:45 PM | #68 | ||
335i F30
68
Rep 252
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
05-14-2018, 08:48 PM | #69 |
Rep 1,953
05-14-2018, 08:50 PM | #70 | |
335i F30
68
Rep 252
What would be the remedy if that did cause an issue?
05-14-2018, 08:54 PM | #71 |
Rep 1,953
Eh? You did it with a BMW tech? As in someone who works at a shop/dealership? And they couldn't find the cause of the error? I don't know if that's the cause, but it just seems strange that a tech would tell you not to disconnect the battery considering the airbag needs to be removed. But regardless what did they say was the cause? If there was a short circuit I don't think there's anything that can be done other than to swap out the part because it's fried.
05-14-2018, 08:59 PM | #72 | |
335i F30
68
Rep 252
Yeah he thought maybe it was a different harness needed or that once I code the paddles the car will recognize the new harness and the code would go away. I don't see another harness available. But he didn't have a clear answer. They don't retrofit paddle shifters so this was his first. It's not a very common thing at the dealership. Most cars come with shifters.
05-14-2018, 09:05 PM | #73 | |
Rep 1,953
05-14-2018, 09:09 PM | #74 | ||
335i F30
68
Rep 252
You got me trippn about the battery lol. I just don't get how my lane assist could not work.... I get loosing the vibration but not the entire function. We scanned it and it said the harness wasn't connected which it true but the new harness is connected. It replaced two of the same connections. This is puzzling
05-14-2018, 09:11 PM | #75 | |
Rep 1,953
05-14-2018, 09:14 PM | #76 | ||
335i F30
68
Rep 252
05-14-2018, 09:15 PM | #77 |
Rep 1,953
03-16-2019, 03:00 PM | #78 |
Rep 2
428i - confirmed wired
Hi there,
after getting all 3 pieces (the back, the flipflops and the new cable) I managed to install + code the flipflops on the steering wheel. It all works Thx for the forum !!! |
04-12-2022, 06:30 PM | #80 | |
Rep 706
the culprit could be one of these three, the paddle, the cruise control, and the wiring. i am suspecting the wiring to be the problem, but i have few questions 1. what would happen if you use 37 wire on a non heater/lane departure wheel option? The price for 37 and 35 is only few bucks difference, i m thinking of buying 37 just for future proofing even though my car does not have the lane departure/driving assistant/heater options right now. 2. how often can the paddle or the cruise control broken? i believe these are just buttons with no electronics circuits behind it? 3. Also what's the difference between part number 61319242983 and 61317847210 for the paddle shifter? Thanks. thanks. |
02-13-2023, 09:52 AM | #81 |
Rep 31
Hello! I have M-sport steering wheel with heating and WO paddles.
Is there a way to determine if steering wheel is ready for paddles retrofit, without getting it off? The thing is if steering wheel already have special holes for paddle shifts, so I won't have to drill them, as it looks kinda hard. Thanks! |
03-10-2024, 04:32 PM | #82 |
Rep 25
Drives: BMW 218i Coupe
My retrofit attempt. No luck yet.
Hi!
My shifters retrofit on my M-sport steering wheel is still unsuccesful. I almost tried everything: installed the shifters, harness cable and back plate from ali express. The car was pre-wired and coded with Bimmercode (FEM 3190/Paddles_Verbaut = aktiv. However, I am suspecting that my harness cable is still corrupt. During my first installation attempt I realized that the black-blue-red cable plug were in the wrong order, since I got errors and no possibility to use any of the steering buttons. 1. Can someone please confirm that the paddleshifter are really meant for the F30? See image of SND resistors on the printboard. 2. There is a 6 pin plug that goes into the SZL.Would anyone know if I would cause the system any harm if I switch the 2 cables inside the plug that are meant for the shifters? I am suspecting that they don't get any power. Let me know if you have any other thoughts. https://ibb.co/pn3mkMG https://ibb.co/GVgyC0y https://ibb.co/gw4VJGP https://ibb.co/KjvDBWX |
03-12-2024, 08:20 AM | #83 | |
Rep 25
Drilling the holes is actually the most easy part of this retrofit. You just need to make sure that the paddle can fit nicely on the back frame of the steering wheel. Let me know if you need more info. |
04-04-2024, 05:34 AM | #84 | |
Rep 4
I have bought paddle shifters from ebay, and want to measure them before going to drill hole process. My idea is install them in my normal sport wheel, not M. Can you give some idea on how to dissassembly the paddles? I'm afraid to force and broke someting. Thanks! |
04-06-2024, 02:52 AM | #85 | |
Rep 25
04-09-2024, 08:35 AM | #86 | |
Rep 4
04-09-2024, 09:32 AM | #87 | |
Rep 25
