01-30-2015, 02:31 AM | #1 |
Rep 34
Driver modes
Hello everybody,
I'm new to this forum and I want to buy a BMW 3 series. But I still have a question. Imagine I buy a BMW without servotronic/variable sport steering, without adaptive suspension and with a manual gearbox. What will the different drivemodes (eco/comfort/sport and sport+) change? Because it can't change the shift points (since it's a manual), it can't change the suspension and it can't change the weighting of the steering wheel. |
01-30-2015, 02:36 AM | #2 |
Rep 5,316
Drives: G80 M3 6MT
The weight of the steering wheel should still change, it just won't automatically get heavier depending on your speed. For you it will change throttle response and steering weight.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
01-30-2015, 09:02 AM | #6 |
Rep 5,316
Drives: G80 M3 6MT
No, thats variable sport steering. Servotronic is based on speed.
Scott, Partner
01-30-2015, 09:07 AM | #7 |
Rep 1,267
01-30-2015, 09:11 AM | #8 |
Rep 5,316
Drives: G80 M3 6MT
I believe Servotronic is standard on all US-Spec cars, but in other markets it is its own option. For Example, if you go on BMW Hungary you will have the option of choosing Servotronic or Variable Sport Steering. If you choose neither you get "base" steering. I have a screenshot but its hard to understand because it illustrates them the same even though they are not.
Scott, Partner
01-30-2015, 09:14 AM | #9 |
Rep 5,316
Drives: G80 M3 6MT
Here it is anyway;
Ignore the illustration, suggesting that it also changes the ratio at lower speeds is wrong. Servotronic does lighten at lower speeds but the actual lock to lock ratio does not change.
Scott, Partner
01-30-2015, 09:16 AM | #10 |
Rep 15,858
In the UK some cars come with base steering, other models further up the range have servotronic as standard, VSS is an option.
Then we do have VSS as a stand alone option, not just as part of DHP as in the States. HighlandPete |
01-30-2015, 11:59 AM | #11 |
ghey
483
Rep 2,041
I had a loaner the other day [MY15] and in the options where you can now configure the modes there was an option in sport mode to modify the chassis and steering, or turn one or the other off. It still doesn't make sense, because the car obviously did not have DHP. Perhaps BMW thinks remapping the accelerator is "chassis tuning"?
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
01-30-2015, 01:35 PM | #12 |
Rep 10,509
sport+ will also still put the stability control into DTC mode, and in the 335 it changes when the flaps in the exhaust open up (i.e. there is a bit of a burble noise on overrun)
01-30-2015, 01:42 PM | #13 |
Rep 1,063
Even with a manual, the eco mode's dulling of the throttle response is very handy in some situations, namely city driving and in winter weather.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
01-30-2015, 01:51 PM | #14 |
Rep 5,316
Drives: G80 M3 6MT
Very true. I get great city mileage on Eco Pro on my 8AT. I'm sure the throttle limiting will help greatly on the 6MT also.
Scott, Partner
driver, manual, modes |
