04-25-2019, 04:41 AM | #45 |
Rep 99
I've had this problem My 328i.
So bad now can't drive It properly. Can't stop the car at a traffic light without violent vibration or stalling. Check: MAF seems clean Coils seem okay Replaced all spark plugs. One was particularly dirty None of that has fixed it. Any other suggestions? |
06-23-2019, 08:17 PM | #49 |
follow my instagram @bimmer_6uy
Rep 96
Im having issues with my 2013 92k bimmer. Did my tranny fluid, butt plugs, ignition remix coils, oil itself and my air filter. All jokes aside Im going for my injectors and if it still persists maf sensor you're next on the line!
06-24-2019, 12:43 PM | #50 | |
Rep 82
Drives: 2012 BMW 328i Luxury Line RWD
06-27-2019, 03:13 PM | #51 |
Rep 51
UPDATE:
Issue not resolved for me Happens mostly when car is warmed up (driving around) and then turned off for 5-30 minutes and on restart - bam! (loss of power, shuddering, and can die) only solution I've found is if I put it back into "Park", turn car off, wait for 20 sec, and restart. It does not happen very frequently (maybe 1-2 a month) So far I have: 1. changed spark plugs, 2. coolant/thermostat, 3. engine oil, 4. air filter, and 5. wiper blades haha. I plan to do transmission, differential and transfer case fluids in the coming months (that more preventative maintenance but who knows maybe this issue goes away too) |
11-07-2019, 04:15 PM | #52 |
Rep 51
Update2
Issue not resolved I did ATF change, diff and transfer case - no change in the issue though. And few days back - Check Engine light...P0171 (Bank1 too lean) Car runs fine for now and check engine light has disappeared (it was in memory) but I am suspecting a possible vacuum leak some place ... so here we are a few changes but no resolution yet. I'll keep you all posted |
11-14-2019, 02:41 PM | #54 | |
Rep 104
11-14-2019, 02:53 PM | #55 |
Rep 51
11-15-2019, 04:31 AM | #56 | |
Rep 446
Mod bug will bite you if you buy a BMW ================================= |
11-15-2019, 08:15 PM | #57 |
Rep 3,030
I may have missed it but are you running any mods?
I'm FBO with BM3 stg 2 and had it happening on occasion. Went to dealer while I was ok warranty still and they reprogrammed the car - still happened. I was starting to think it was the fuel filter, bad had it even the intake. Anyway I flashed to stock about a month ago and all of a sudden it's gone...my parts guy at the dealer suggested it. He had the same problem.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
12-16-2019, 03:28 PM | #58 |
Rep 51
Another update.
Did smoke test - found the smallest vacuum leak between 2 air intake tubes. I added padding between them - that leak is gone. cold starts still produce rough idle though and warm engine turning the car off and then on 30% of the time will cause a loss of throttle response (I can floor it and RPMs wont go above 1k and the car will start to hesitate) and fault codes (bank 1 lean and Cyl 2 misfire) - I will post a video soon. https://youtu.be/zqtJxCCGMb0 So I pulled the plugs - checked gap - all at 0.030 to 0.031 - and all relatively clean. Reinstalled but changed them around cyl2 plug and coil now in cyl3. Ok for a few days - then same codes again!!! - my love for this car is fading I am going to check the crankcase breather diaphragm and after that it looks like maybe injector time? Last edited by roma3; 12-16-2019 at 04:38 PM.. |
12-17-2019, 08:06 PM | #59 |
Rep 51
Well I checked the crankcase breather diaphragm and WHOAA!!! it has a crack in it! I just ordered a repair kit will keep you guys updated.
RMachuca3d723.50 |
12-17-2019, 08:20 PM | #60 |
Rep 2,046
what year is your car and how many miles on the car ? N20 or N26 engine ?
12-18-2019, 09:20 AM | #62 |
Rep 625
Have you looked at the color of the cat when it idled...? Had this on a friends car and car was glowing red
Found out it it was multiple leaking injectors that would only cause issue at idle / low rpm No codes were stored and issue fixed after replacing all of them |
12-20-2019, 09:03 AM | #63 |
Rep 51
SOLVED! (I think)
So turns out it was the crankcase diaphragm - I changed it and even at 27 degrees and a cold start the car ran beautifully ( I have not heard it run this smooth in a while) So we will see if it lasts. oh and the part was $26 on amazon - assoc link: https://amzn.to/3a7di9e (about the part - I will say it was a tighter fit than the OEM but eventually I got it on there) Last edited by roma3; 02-10-2021 at 11:41 AM.. |
12-20-2019, 10:37 AM | #64 | |
Rep 1,172
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
12-20-2019, 11:04 AM | #65 | |
Rep 51
Here is a screenshot of a video I took (low quality) with the engine cover and insulation off. [IMG]Crankcase breather diaphragm by Roman G, on Flickr[/IMG] hope this helps |
12-20-2019, 01:58 PM | #66 | ||
Rep 1,172
Huh I think I'll check that out see how mine is. Seems pretty easy to change
2020 X3 M40i
