BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > F34 brake discs - replacement and wear OEM
      03-17-2019, 09:52 AM   #1
smithie
Drives: F34 GT Msport
Hi All,
Its time to do the discs, have the option of OEM parts but not sure which brand people prefer.
Pagid and Textar seem to be the cheap end and Brembo and ATE the better ones?
The other main question is, BMW discs are 22mm when new and min 20.4mm (the 300mm diameter ones - taken from Bentley). However the OEM's seem to start at 20mm and have a minimum of 18.4mm. Logically, the same wear allowed in mm but slightly thinner on the OEM's, presumably no one has had a real issue with the difference?
Also I've lost the lock nut key for the wheels, anyone hazard a guess at replacement nut key, I've read about removing them with a socket set so may go down that route....
Smithie
