10-19-2016, 08:38 AM | #1 |
Rep 1,418
Dinan Springs and Bump Stops + Michelin PSS on a 340i xDrive
Car: 2016 340i xDrive, 6MT (FTW!), M Sport Package, Track Handling Package, etc.
Just thought to share a few quick snaps of my new setup which is actually how an xDrive should come stock from the factory. Dinan Performance Springs and Supplemental Ride Quality & Handling Kit with Michelin Pilot Super Sport tires. 1” drop in the front and 1.125” in the rear. I’ve had a few M3s in the past and thought the xDrive’s standard suspension coupled with its higher ride height made the car too floaty for my taste, even with VSS and Adaptive M Dampers. The S001 run-flats weren’t terrible but figured I’m getting an alignment anyway so I may as well get new tires. After install, there’s a distinct improvement on all aspects of handling. I must say that I can’t decide whether I love the springs or tires more since both add equally to the improved driving dynamics. It feels closer to the e92 M3 in normal mode. The slight reverse rake of the springs also helps eliminate the rear from squatting under heavy acceleration. I immediately realized how unnoticeable the difference in the lower ride height was over bumps in the road but certainly there was a huge improvement in sharp cornering on the twisty rural roads around me. The car also feels lighter and more nimble on top of looking way better without the four-finger wheel gap. This car should have come like this from the factory... Last edited by MomoM3; 10-19-2016 at 11:25 AM.. |
10-19-2016, 09:11 AM | #4 |
Rep 140
I couldn't agree more. Ditching the run flats and adding Dinan drop springs is a huge improvement! Your car looks awesome by the way! Altitude sets the attitude
10-19-2016, 09:25 AM | #5 | |
Rep 1,418
I think I will skip Dinan Shockware too - I like it exactly where it is. |
10-19-2016, 10:18 AM | #6 |
Rep 27
Your car looks great. My '16 is nearly identical in its stock form, and the squatting & floatiness of the car is beginning to drive me nuts. First world problems.
I agree with your statement, post-mod, that's how the xDrive's with M Sport/Track should have came from the factory. Where'd you have the work done? The LCI steering feedback is noticeably better, but did the tires/springs improve upon it further? |
10-19-2016, 11:17 AM | #7 | |
Rep 1,418
Steering on the LCI with VSS is already fantastic. As many others have said the non RFTs unequivocally eliminates the dead center feel. The springs make the car feel more planted and certainly improves steering response. I forgot to add I've noticed a HUGE improvement in high-speed stability too. 100+ mph feels so much more stable with zero floatiness. I've never modded any of my previous 4 BMWs but I highly recommend this setup. Basically zero cons in doing this. |
10-19-2016, 12:59 PM | #8 |
Rep 190,805
Looks good
10-20-2016, 08:48 AM | #10 |
Rep 820
Why the reverse rake? Simply to avoid squatting under acceleration?
You intentionally chose to do that? Do xDrives have a reverse rake from the factory as stock? It just looks slightly unusual... (sorry for all of the questions, but I'll be ordering an Msport xDrive soon, w/ adaptive, and would also like to do a similar drop) Car is GORGEOUS btw |
10-20-2016, 09:56 AM | #11 | |
Rep 584
10-20-2016, 10:42 AM | #12 | |
Rep 84
That said, I decided to just go full bore and do springs, bumpstops, Shockware, and sways all at the same time (going to do MPSS when I get closer to the end of the treadlife on the runflats), and I'm a little worried based on your comments that it might end up being overkill. Think that setup might end up being too harsh? |
10-20-2016, 12:19 PM | #13 | |
Rep 1,418
That's the way Dinan springs are made (likely for a reason) and I went Dinan for two reasons: 1) I keep my warranty and 2) it can still be CPO by BMW with Dinan parts. Coilovers would be a waste of money for me since the Dinan springs and bumpstops brought me to exactly where I wanted the car. I really don't need to tinker around with ride height either - it's no track car. |
10-20-2016, 12:27 PM | #14 | |
Rep 1,418
I wish I could tell you how the drop feels with the run-flats but I didn't want to take the chance and did it all in one shot. As for Shockware... I wanted to get it but the tech said pass and see how you like the drive first and I love it. Although I don't ever drive in Comfort I wouldn't want to lose that damper setting either and the Sport setting is just fine with me. |
10-20-2016, 12:28 PM | #15 |
Rep 418
I've read someone mention BMW designed the front fenders differently (larger opening) than the rears to prevent rubbing of the front wheels when turning.
I think that's what makes it look more reverse rake than it really is. Can't speak for Dinan personally but has a great reputation. I would've gotten them too if they weren't so expensive...relatively |
10-20-2016, 01:23 PM | #16 | |
Rep 521
10-20-2016, 02:54 PM | #17 |
Rep 1,418
Why? No good reason other than they're expensive! Also there's something ridiculous like 6+ hours of labor involved, presumably because they need to drop the front sub-frame.
10-20-2016, 03:30 PM | #20 |
Rep 84
10-20-2016, 06:34 PM | #21 |
Rep 521
Yeah, I understand that - one of the reasons I'm going to hold off and see if I really want it. I'm likely to either leave it stock or go all out and do LSD + springs + sways, and the LSD is even more labor than the sways I think.
10-20-2016, 09:57 PM | #22 |
Rep 2,639
Go to an indy performance shop, it's cheaper! I paid 400$ for Dinan springs+bumpstops and alignment at my local performance shop. I was quoted 550-600$ for sway bars installation.
