BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Fixing front license plate holes and transport damage
      03-18-2019, 11:11 PM   #1
F3085258
Drives: 2016 X5M
I dont need a front plate in Alberta, so I wish the previous owner of my Ontario sourced 2016 340i used the tow hook mount for the front plate...
I have bought 3 previous cars from states that had front plates and they weren't as noticeable as my new 340i. They used 4 screws. My E90 M3, Cayenne and CTS-V all only had 2 holes and the edges around the holes didnt stick out from the bumper. I simply put the 3M/Rock Guard on bumper and it didnt bother me.
These holes are a little more noticeable. See pics.
The transport company also damaged the right side of the bumper. I did not notice in my walk around when picking up the car as it was filthy dirty, so I am pissed at myself for that. I washed the car right away and have left Hauling co a message and before/after pics. Good thing the they forgot the credit card machine when I picked up the car and I have not paid yet. See third pic.
Short of repainting the entire bumper, thoughts on how to fix this damage?
      03-18-2019, 11:17 PM   #2
skyline408
skyline408's Avatar
1574
Drives: 2023 G80 M3 2022 F95 X5M
Looks like the paint is rubbed off and the black part is the bumper plastic itself, right? Unfortunately only correct fix is a respray of the bumper. Some bumper repair guys can spot touch up spray that part only, but quality can be iffy.
If I was in your shoes, I'd respray the whole bumper and get those bumper holes filled as well.
      03-19-2019, 08:23 AM   #3
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
The right way would be a full bumper cover respray.
I was in a similar situation and used a razor blade to carefully cut off any protruding plastic from each hole... then I filled each hole with silicone caulking... then I touched up each hole with factory touch up paint.
Im fine with this set up while my bumper gets pelted with other road debris. Eventually, I will get a respray and PPF to prevent it from happening again.
      03-19-2019, 12:33 PM   #4
F3085258
Drives: 2016 X5M
If I can get the transport damage fixed with out a full respray, i like your razor blade abs culking idea.
sspade2464.50
      03-19-2019, 01:29 PM   #5
sspade
sspade's Avatar
Drives: F30
Sounds ghetto but it's honestly not bad looking and barely noticeable from a few feet.
Couple pics from very recently. To me its a thousand times better than a front plate... which is required by law in my state
      03-19-2019, 01:56 PM   #6
_tlink
Guy with a car
_tlink's Avatar
98
Drives: 15' 435i Msport
Couple pics from up very recently. To be its s thousand times better than a front plate... which is required by law in my state.
On my E90 I used plastic wall mollys and fit a set of tight ones into the holes. I then plasti dipped them black to "match" the paint!
Sounds horrible, but no one ever noticed unless I pointed it out! Happy to have a mint bumper now with no holes pre drilled
15' 435i BSM on CR // BM3 Stage 2 93 OTS // NGK Plugs Gapped 0.023" // VRSF Catless DP // CTS Turbo Intake, CP, FMIC // AWE Tuning w/ Perf. Midpipe // BC Racing BR Coilovers // Apex EC-7 // Michelin PS4S // Plus a shit load of carbon
      03-20-2019, 02:23 PM   #7
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
It's definitely not worth doing a full respray for just those. Any decent body shop can fill those and blend the paint to look decent enough for a couple hundred bucks. Or you can do it yourself like sspade has done. That looks good enough, IMO.
sspade2464.50
