11-27-2020, 06:17 PM | #1 |
Rep 67
Weird transmission fault codes / gas pedal stops responding, please help
Recently bought a 2013 335i automatic that seemed to be in immaculate condition. Lot of maintenance, guy took detailed notes on what he did / at what mileage, which parts had been replaced, etc etc. All seemed good.
Couple times now the gas pedal stopped responding while on the freeway while in sport shifting mode, until I switched back to regular / or switched out then back into sport shifting. When it happens, I hear the gas let off, and pressing the pedal down further does nothing (no revving of rpms, no acceleration). Thought I would scan for fault codes to see whats up (first time doing this). I got a few codes, and I've been googling, but I still don't really know what I'm looking at here. DME active codes 1D2008 - map thermostat: clamped open (seems like it may be a temp sensor issue? needs replacing?) Transmission active codes 421722 - unknown (Google says: "DME/DDE interface: Forced upshift due to thermal engine protection request or signal invalid (switch status, warm-up, powertrain, 0x3FB)" Also, this one went away after clearing codes, but shouldnt that mean it should now show up under inactive? it just disappeared altogether. maybe it will pop up again, but my understanding was that inactive codes were past problems, so wouldnt this still show up as an inactive code now? my other "inactive" codes still show up after a clear using MHD. CF2DE2 - unknown (Google has 3 diff results for "signal invalid, transmitter DME / DDE" with it either being drive motor temp, drivetrain data, or drivetrain data 2) I googled these two, but basically didn't understand what I was reading... What should I do about this? What should I look out for going forward? I'll have to find some time to take the car into the shop, but it would put myself at ease in the mean time to know what I'm working with here, how serious it is, and whether it's related to my intermittent gas pedal issue. I don't need to worry about inactive codes right? I cleared the codes and then these active codes came back up, but side question: if I cleared the codes, why would the inactive codes resurface? Last edited by alexjustdoit; 11-27-2020 at 06:25 PM.. |
11-30-2020, 11:57 AM | #2 | |
Rep 7,597
When you clear a code it does not go to inactive code, it gets cleared completely until it is triggered to come back. Just because a code is inactive doesnt mean you don't need to worry about it. If its inactive you can think of it as just that - not actively causing a problem, but you still shouldn't ignore it. If all was well, you would have no codes at all. |
07-01-2021, 10:58 AM | #3 | |
Rep 369
07-01-2021, 11:18 AM | #4 |
Rep 142
You may want to check the coolant level, as I just had my car go into limp mode due to that and it had the code about the thermostat being stuck open. I also replaced the coolant temp sensor just to be on the safe side.
07-26-2021, 02:50 AM | #5 |
Rep 67
Yeah, I took it to another shop for a second opinion and they found a pretty bad coolant leak. First shop said thermostat was bad and wanted me to replace it (at an absurd cost too) and said something about because I had topped up the coolant with water that I had adjusted the boiling point way lower and therefore it was boiling off super fast but I wasn't convinced. After fixing coolant leak and making sure to keep it topped up has fixed this issue. Now if only I could fix the other issues. Great car, but constant weird problems.
'13 335i - 450whp / 450wtq @ 93 oct
BigBoost stage 3.3 turbo - FBOs / catless - DV+ - bm3 custom tune - xHP - Dinan springs - M Perf LSD - Borla ATAK |
01-19-2022, 02:43 PM | #6 | |
Maximus Decimus Meridius
1130
Rep 4,584
Thanks! |
01-19-2022, 07:19 PM | #7 |
Rep 765
Perhaps diagnosing the problem with the codes, instead of clearing them, will get you through this.
02-09-2022, 12:20 PM | #8 |
Rep 67
It was fixed as part of the coolant issue.
02-09-2022, 12:21 PM | #9 |
Rep 67
That's what I was doing - I was taking it to shops and showing them the codes, but I had to clear them so that I could actually drive it to the shop.
03-27-2022, 08:07 AM | #10 |
1130
Rep 4,584
Ironically, mine was fixed as well in regards to a coolant issue. It was just slightly low in the overflow tank, so I topped it off and that seems to have resolved that issue. Weird..
F30 335i Melbourne Red Metallic M-Sport Package |
10-24-2022, 04:41 PM | #11 |
Rep 1
theromast
hey i was having the same issue with my car i was wondering if you changed out the whole thermostat and did that fix your issue with the power loss and no throttle response
10-28-2022, 06:46 AM | #12 |
1296
Rep 3,532
Yes that's what it usually is
