05-28-2021, 03:35 PM | #1 |
Rep 87
Pure Stage 2 Dyno N55 335i
Finally got my pure turbos in,
It was tuned for 94 Catless DP BMS intake Charge pipe upgrade XHP stage 4 Straight pipe Stage 2 LPFP Pure Turbo Inlet Turbo Smart+ DV It was a custom tune straight to the ecu, no bm3 or mhd Was hoping to break 500whp but with port injection and planning to use a different tuner rather than the tuner my shop uses. Dyno was also done in X Delete mode do let me know if there’s anything else Incan do to better these numbers Last edited by Shadysu; 05-30-2021 at 09:44 AM.. |
05-28-2021, 03:58 PM | #2 |
Rep 7,591
What software did the tuner use? Typically its only MHD, BM3, or ECUTek. Also, any datalog?
I assume you have stock HPFP was well. You are probably just out of octane to push higher, but we can't tell without a datalog since we have no idea what boost or timing you are running. Port injection wont do anything if you are out of octane, that would only help if you are out of fuel (quantity) or wanted to switch to E85. |
n55david1295.50 |
05-28-2021, 04:09 PM | #3 | |
Rep 87
05-28-2021, 04:35 PM | #4 | |
Rep 7,591
Let's see a log though when you get one. |
05-28-2021, 04:43 PM | #5 |
Rep 87
I wanted to go with the port injection kit by snow performance, since it would cover the meth and as well cover the HPFP upgrade, and the FX-180 is 1800 CAD, and the 2.5 PI kit would be 1600 CAD from my local shops
05-28-2021, 05:05 PM | #6 |
Rep 7,591
PI can be used to spray meth, but then why did you upgrade the LPFP?
05-28-2021, 07:05 PM | #7 |
Rep 87
05-28-2021, 07:07 PM | #8 | |
Rep 87
05-28-2021, 07:27 PM | #9 | |
Rep 7,591
Then if you add PI, you will need a LPFP, and you will also likely need a EKP upgrade if you are going to be putting the LPFP under any significant strain. If you add meth spray via PI, you will have a dedicated meth tank/pump, so you also wont need a upgraded LPFP. |
05-28-2021, 08:02 PM | #10 | |
Rep 87
Interesting, When I first inquired about my turbo upgrade to my shop, they suggestion I'd do just LPFP Inlet upgrades and I should be good to go around 500whp So lets say I just want to add meth, would it just be better to just get a meth kit alone, if I don't plan to run E85 and wouldn't need PI either? my end goal I"m trying to reach is 520-550WHP. What would warrant me to upgrade my HPFP? Sorry to sound like a newbie, I thought I did my research all this time, only have been on this platform since september haha, appreciate the responses in advance. |
05-28-2021, 09:53 PM | #11 |
Rep 462
470 seems about right for your mods and fuel. Maybe a bit on the high side.
You are hitting the octane ceiling for your fuel. Your shop is mistaken about the lpfp. You will be hard put to get 550 out of the ps2. Maybe for a glory run on the dyno, but not something to run daily. If you are willing to plan around your e85 supply then hpfp stage 2 should enable you to get close to or max out the ps2. Stage 1 probably not. If you don't have e85 easily available a meth kit is what you will need. Charge pipe meth should get you to the 500ish mark maybe a little more. If you plan to get all that is possible out of the turbo then direct port meth injection would be a preferred set up. With a small nozzle in the charge pipe to cool iats. Its certainly more complicated, but if done right it gets you the octane and fuel you need delivered evenly to each cylinder. If I were you and going down the meth path, I would start with the charge pipe meth and see if you are happy before incurring the additional expenses of direct port. Last edited by 435gc; 05-28-2021 at 10:08 PM.. |
05-28-2021, 10:13 PM | #12 | |
Rep 87
A few friends have suggested to go with a FX-150 and a meth injection kit which I think I'll pull the trigger on it. I'll be happy if I get 530, I was really hoping to get 500 before meth. Appriciate the response, I get so confused when it comes to fueling I guess my shop was just under the wrong impression about the LPFP, they still did a beautiful job on the installs. |
05-29-2021, 02:53 AM | #14 | ||
1296
Rep 3,529
05-29-2021, 08:49 AM | #15 |
Rep 87
05-29-2021, 10:58 AM | #16 | |
Rep 7,591
05-29-2021, 04:40 PM | #17 | |
Rep 87
Yep got that, but I would acutally be interested to run E85/blends sometimes One more question... so if the tune they used wasn't MHD or BM3, EcuTek? and if so would I be able to remove to tune myself? or only they would be able to, as I want to switch to MHD and have multiple maps rather than just the single flame map ill be on with the current tune. |
05-30-2021, 01:30 AM | #18 |
Rep 4,129
Where is the upgraded turbo inlet and diverter valve? Go back to the stock intake with a drop in filter, or at least get a better one like the CTS. I’ll also second the comments on the HPFP/LPFP. Meth will help, and/or E85
05-30-2021, 08:20 AM | #19 | |
Rep 2,354
(A Dane in China) |
05-30-2021, 09:44 AM | #20 | |
Rep 87
I have the pure Inlet upgrade as well, and the Turbo Smart DV I was planning to upgrade to the CTS intake very soon, just ran out of money during the turbo upgrade |
05-30-2021, 01:07 PM | #21 | |
Rep 462
Keep in mind that you will need a separate map if you plan on running meth with pump and occasionally running an emix with pump and meth. |
05-30-2021, 03:38 PM | #22 |
Rep 87
Yep i’m aware, another reason why i wasn’t happy with this tune, i’m on a single map only, and that happens to be a flame map as well, before i’d run one for flames for burbles and then one for just performence which i enjoyed a lot. hoping i can work that out with my next tuner
