06-30-2021, 08:04 PM | #23 | |
Rep 221
here are the specific codes: 121530 boost pressure, plausibility: pressure too high 120408 Charge Pressure Control, shutdown: pressure build-locked 5th gear logs https://www.bootmod3.net/log?id=60dc...729b36a7e45e1d https://www.bootmod3.net/log?id=60dc...729b36a7e45e1e https://www.bootmod3.net/log?id=60dc...90c67aea378822 https://www.bootmod3.net/log?id=60dc...729b36a7e45e22 https://www.bootmod3.net/log?id=60dc...729b362aae101d 3rd Gear logs https://www.bootmod3.net/log?id=60dd...90c67aea378878 https://www.bootmod3.net/log?id=60dd...729b36a7e45eae 3rd and 4th Gear log (M2 Stage 0+ stock map for comparison) https://www.bootmod3.net/log?id=60dd...729b36a7e45ec3 https://www.bootmod3.net/log?id=60dd...90c67a5b47eee0 I must say car is more enjoyable to drive on the Stage 0+ map... am I going crazy or something? haha.... |
06-30-2021, 08:09 PM | #24 | |
Rep 221
VRSF https://www.vr-speed.com/vrsf-race-i...i-n20-n55.html Arm Motorsports (My current IC) https://www.armmotorsports.com/colle...tercooler-fmic |
06-30-2021, 09:19 PM | #25 | |
Rep 7,602
You aren't supposed to run a 3.5bar MAP in the manifold because there is no flash option for it, so you would need a custom tune for that to work properly. Right now the DME is probably getting an incorrect signal because it does not know its a 3.5bar sensor, it thinks its the stock one. That's also why its not reading over 22.8. |
06-30-2021, 09:38 PM | #26 | |
Rep 221
07-01-2021, 12:50 AM | #27 | |
Rep 7,602
07-01-2021, 08:02 AM | #28 | |
Rep 4,134
Mods: Yes.
07-01-2021, 08:38 AM | #29 | ||
1296
Rep 3,533
still trying to find a deal
07-01-2021, 09:15 AM | #30 |
Rep 4,134
There really aren't too many. You can message Mike@N54Tuning.com to see what he has as far as deals go.
ER is also a great option - but it does cost more.
Mods: Yes.
07-01-2021, 09:54 AM | #31 | |
@_sunbish
282
Rep 611
07-01-2021, 02:03 PM | #32 |
Rep 643
motivman, i use the 335is/550i clutch on my m235i, no slips with the stage 2+ tune. i recommend it. feels 100% like stock.
unless you have an ethanol sensor, there isn't any benefit for you to run the multimap over the regular stage 2+ e30 map. you can simply pull the newest stage 2+ map and it will already have been converted to 'customrom' which gives you antilag. and i agree with the m2 map.. i'm running it right now too and enjoy the car more . lets you have some fun revving it out. do you have any logs where you shift 3 to 4? if so, please share, im doing some research. thanks
M235i rwd 6mt
07-01-2021, 02:08 PM | #33 | |
Rep 221
https://www.bootmod3.net/log?id=60de...729b27d088f719 |
07-01-2021, 02:20 PM | #34 | |
Rep 221
https://www.fcpeuro.com/products/bmw...uk-21207603248 Did you keep your original DMFW or did you get a new one? my car only has 37K miles on it, and I want to keep my original flywheel, but the shop that is doing the work, recommends a new flywheel. The Luk flywheel looks to be out of stock, but I found another one, not sure if it will work. In stock OEM DMFW, not sure if this will work https://www.fcpeuro.com/products/bmw...uk-21207590942 Confirmed OEM DMFW that works, but seems to be Out of stock https://www.fcpeuro.com/products/bmw...uk-21207640733 what else did you replace when you had the transmission out? thinking of doing a cdv delete, and replacing my clutch master cylinder. Do you want a 3rd to 4th gear log on the m2 map? I can get that for you, once I take the car out later today. |
07-01-2021, 02:25 PM | #35 | |
Rep 4,134
Mods: Yes.
07-01-2021, 02:34 PM | #36 | |
Rep 643
clutch fork pivot https://www.fcpeuro.com/products/bmw...in-21511223328 crankshaft seal (did not replace since mine was not leaking.) https://www.fcpeuro.com/products/bmw...co-11117587168 e90 clutch slave cylinder to remove the clutch delay valve https://www.fcpeuro.com/products/bmw...te-21526785964 FCP sells bmw brake fluid pretty cheap, might as well pick that up too if you change the slave because you need to bleed clutch (same reservoir as brakes) pressure plate screws https://www.fcpeuro.com/products/bmw...ew-21207548052 [optional] OEM clutch release bearing because the mechanic claims that non-OEM units make noise. FYI, the clutch kit includes one, and by the looks of it, was really similar to the OEM one i bought.. https://www.fcpeuro.com/products/bmw...rm-21517564027 i did NOT replace my stock DMFW, it was in good condition. too expensive an item for me to replace if not needed. LOL i also dont do WOT 5th and 6th with a slipping clutch if you can return an unused dmfw.. then certainly go ahead and have it on hand. rumor has it that DMFW is supposed to be good for 2 clutches. for the 3-4 gear change log, i'd prefer it on the stage 2 or 2+ maps.
M235i rwd 6mt
07-01-2021, 03:40 PM | #37 | |
Rep 221
https://www.bootmod3.net/log?id=60de...729b27d088f797 NB: just noticed you want one for stage 2, I will try to do another one for you sometime later today or tomorrow. Do you want stage 2 e30 or stage 2 91 or 93? right now I have 93 in the tank (almost full tank), if you want e30, It will take a little more time, so I can run down my 93 gas. As of right now, my clutch does not slip on the stage 2 e30 map at all.... also, do you remember if your DMFW was resurfaced or just cleaned? Last edited by motivman; 07-01-2021 at 04:05 PM.. |
07-01-2021, 08:04 PM | #38 | |
Rep 221
https://www.bootmod3.net/log?id=60de...90c64b5bb3dc96 |
07-01-2021, 08:12 PM | #39 | |
Rep 7,602
07-01-2021, 09:04 PM | #40 |
Rep 643
Thanks for the logs. I was interested in the dme behavior post shift, so no need to Rev 4th all the way out!
I'm running the original vrsf 5 inch, and wmi. I'm pretty sure the new 5 inch have greater fin density. In regular driving, iat about 10 to 15 over ambient. If i get on it, wmi brings it down but if I do pulls, I'm still rising a few degrees
M235i rwd 6mt
07-08-2021, 01:35 PM | #41 |
Rep 221
Hey, So Arm motorsports sent me a "revised" intercooler... Apparently, they revised their intercooler right after I bought my original one. big improvement... I went from a 38F rise on a full 3rd to 4th gear pull, to only a 7C rise!!!!! My VRSF race intercooler just got delivered today, wondering if I would see an improvement with the VRSF? weather was about 94F outside during this pull.
https://www.bootmod3.net/log?id=60e7...729b3d56b4aceb thejeremyman9 , what do you think? should I keep the revised arm intercooler or pop in the VRSF race? |
07-08-2021, 02:02 PM | #42 | |
Rep 4,134
Then it goes from 111F to 125F in 4th - Which is not good. Can you show me the revised intercooler? How does it look and how many fins? How much does it weigh? I can conclusively say that based on what I'm seeing so far, the Race Intercooler would be better.
Mods: Yes.
07-08-2021, 02:29 PM | #43 | |
1296
Rep 3,533
I'll buy it maybe if you don't use it
07-08-2021, 02:49 PM | #44 | |
Rep 7,602
For example, one of my top speed run logs (sorry its long, logged the whole thing to make a video, but turn on accel position and you can see toward the end). I went WOT for 30 seconds and went from 93F to 113F, so about 20F rise in 30s, albeit it higher speeds (better to keep IC cooler). https://datazap.me/u/thejeremyman9/2...data=2-4-10-21 (Top speed this run 177 mph ) Another example, 5-6th gear pull, WOT 14 seconds, 14F rise in IATs: https://datazap.me/u/thejeremyman9/5...data=0-4-10-21 Another example, 1-4th gear pull from a dig. You can see that, because i was sitting stopped before the pull, IAT actually ends lower than it started (goes down and back up a little): https://datazap.me/u/thejeremyman9/1...0&data=4-10-21 So yeah, i have no doubt the 6.5'' will be better than your current IC. I even considered going to a 6.5'' myself but don't feel the need yet since im still on stock HPFP and mine is "good enough". |
AmuroRay2267.50 |
