01-27-2022, 10:42 PM | #155 | |
Rep 63
fortythirtyfive639.50 |
01-27-2022, 10:51 PM | #156 |
Rep 1,791
If you buy in bulk at least 100 pieces you can get a custom color combination lol. Yeah hopefully they start offering different combinations without having to do so.
01-27-2022, 11:27 PM | #157 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Probably because all the China clone ones are blue orange.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
01-27-2022, 11:37 PM | #158 |
Rep 1,791
01-28-2022, 05:55 AM | #159 | |
Rep 332
01-31-2022, 03:44 AM | #161 |
Schmollbraten
12512
Rep 1,985
Blue/green is an awesome combo, would second the need of this
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
01-31-2022, 07:13 AM | #162 | |
Rep 1,381
Pair of tweezers and a heatgun with a nozzle adapter on it, I used to do it when making Frankenstein led boards lol. Just slowly heat them from the back and don't blast them with a ton of air to save ruining the chips.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
02-04-2022, 02:08 PM | #163 |
Rep 1,381
Managed to unsolder the OEM orange led and reattach it onto the aftermarket board. Took a lot of fiddling as the aftermarket boards need a hot air solution rather than a soldering iron. In the process I managed to loose the middle pin, the solder they use is sh*t.. I had to trace the track and resolder it back on down the line. In total I now have blue/orange |
02-04-2022, 09:26 PM | #164 |
Rep 376
Finally got door card ambient light, climate panel, and footwell all switched out with the new led modules! Here are some pics. The orange 605 is slightly brighter than OEM, but the white is TONS brighter than OEM. The white is almost too bright for night driving, but that's ok since I mostly keep it on orange.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
02-05-2022, 11:16 AM | #165 | |
Rep 1,381
02-05-2022, 11:21 AM | #166 |
Rep 1,791
You're probably going to have to get the orange LEDs from the Benzinfabrik modules. Sorry to hear the OEM LEDs burned out.
02-05-2022, 12:13 PM | #167 | ||
Rep 208
02-05-2022, 12:50 PM | #168 |
Rep 376
Yeah, honestly I might just switch the footwell LEDs back to the OEM ones. It's a bummer cause I do like the brightness of the orange there, but that's the main area where the brightness of white color is way too bright at night. The door cards and climate panel I can manage.
02-05-2022, 01:03 PM | #169 | |
Rep 1,381
I suspected they may eventually burn out just not that fast ha, with there being no information about them I couldn't guess. Luckily the other 3 took me 15 minutes to desolder and resolder as I found the perfect temperature to warm the boards up to, they came out super clean too.. I'm not overly bothered about just having blue though as I really didn't like the white. I'll probably wait until benzfabrik release an orange 405 / blue combo. I can't be bothered stripping the doorcards off again to test a DIY project
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 02-05-2022 at 01:09 PM.. |
02-07-2022, 01:31 PM | #170 |
Rep 1,381
Spoke to Benzinfrabrik, orange 405 / blue will be in stock within 12-14 weeks
2015 435i - 401whp
02-07-2022, 08:34 PM | #171 |
Rep 376
Darn, wish I knew this before I just swapped everything out lol… that would've been my ideal combo. Now I'm too lazy to do it all again haha, esp the door cards.
02-07-2022, 09:01 PM | #172 |
Rep 1,791
Same here lol even once they offer other color combos, I'm not messing with what's already installed! Too much work! I'm happy with blue so it's all good.
chuckles01188.50 |
02-08-2022, 04:28 AM | #173 |
Schmollbraten
12512
Rep 1,985
Same here also, the white is way too bright and I wouldnt use it. On the flipside Im also not a big fan of that old fashioned red/amber/orange whatsoever, into the newer cars (so my former RS5 has it already) a variable ambient light is very handy and suitable, but I refuse to install RGB light strips.
02-08-2022, 06:55 AM | #174 |
Rep 1,381
I'm always a bit skeptical about removing door cards too many times, the plugs become brittle eventually and don't hold tension, one of mine already buzzes/rattles because of the material scrubbing the actual metal door whilst driving.
2015 435i - 401whp
02-08-2022, 11:20 AM | #175 |
Rep 376
I actually already broke 4-5 of the plastic pins. I had to order replacement pins cause without those pins in place the door def buzzes and rattles over bumps.
02-08-2022, 11:48 AM | #176 | |
Rep 1,381
I have maybe two or three broken pins for sure so its gotta be that
2015 435i - 401whp
