03-14-2019, 08:49 AM | #793 |
Rep 40,733
PM sent.
05-20-2019, 03:36 PM | #794 |
Rep 442
Could I please get a link to the Lite version of the psdzdata?
Trying to get ISTA+ 4.15.32 working, and it's apparently missing the psdz/sdp info, and then erroring out after scanning the car. Only need lite for running diagnostics only. Thanks |
05-20-2019, 03:54 PM | #795 |
Rep 40,733
PM sent.
ggggbmw432.50 |
05-23-2019, 04:41 AM | #797 |
Rep 2,302
05-23-2019, 07:15 AM | #798 |
Rep 40,733
05-23-2019, 02:57 PM | #800 |
Rep 40,733
PM sent.
05-24-2019, 11:32 AM | #802 |
Rep 40,733
PM sent.
06-13-2019, 05:48 PM | #804 |
Rep 3
Hello
Can you send the OLD PSdzDatafor the Need for a BMW M5 F10 MY 2012 also if needed the right Esys Version Thanks Because the KOMBI ECU has to Factory Reset and now need FULL PSdzData for the BMW M5 F10 MY 2012 Now much problems how can fix only with Flash OLD PSdzdata to the ECU / KOMBI ECU or also any other method to fix ? Because Factory Reset of the KOMBI ECU , original factory condition made much problems now nothing work anymore right Kind Regards Last edited by XGamer; 06-13-2019 at 06:24 PM.. |
06-13-2019, 07:56 PM | #805 | |
Rep 40,733
06-14-2019, 02:02 AM | #806 | |
Rep 3
Because of the Button miss clicked with Code Default Values. Now much errors. So i read i need FULL PSdzdata do Flash the KOMBI ECU again with the OLD Software version to fix it . or you know a other way ? to fix it. Kind Regards |
06-14-2019, 02:30 AM | #807 | |
Rep 2,302
Siehst du das Kombi noch? Kannst du einen Screenshot machen? Man kann das Problem wohl inzwischen auch ohne die alten psdzdata lösen. |
06-14-2019, 07:00 AM | #808 |
Rep 40,733
Flash it with latest 4.17.30 PSdZdata Full. No need to use old version.
07-16-2019, 06:25 AM | #809 |
Rep 65
May I have the lastest lite version, please?
Also, My car got updated to 2018 i-step and on my Esys I have 2015 i-step. I VO coded some CPU's with the stock FA after the update, to delete custom FDL coding and return settings to stock. Everything went well and without errors. Did I do any harm by using older psdzdata than that loaded on my car? Thank you. |
07-16-2019, 06:37 AM | #810 | |
Rep 40,733
07-16-2019, 07:22 AM | #811 |
Rep 65
07-23-2019, 05:02 PM | #813 |
Rep 40,733
If you have Full, there is Zero reason to also have Lite, and not that you would ever need it, but you could just make Lite from full. PM sent.
