Drives: BMW M4
Coding Ethernet timeout. PLEASE HELP
My REM is having an issue where parking sensors kept intermittently working, I tried to reuse a backup via Bimmercode which failed. Now the sensors don't work at all and it's causing the rear lights to flicker. I am now trying to flash using E-SYS but get the following issue.
Read SVT before TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated.
<run()-> Value of 'httpServerActivation': true>
<run()-> Value of 'isDeactivateHttp': false>
<ExecutionID=2023/08/26-14:06:14.148>
<[] prepareTALExecution started [PROGRESS]>
<[] prepareTALExecution finished [PROGRESS]>
<[] prepareVehicleForCoding started [PROGRESS]>
<[] prepareVehicleForCoding finished [PROGRESS]>
<MCDDiagService<id=46900, job=com.bmw.psdz.jobs.uds.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=REM_72_ETHERNET> [DIAGSERVICE]>
<[REM - 72] prepareECUforCoding started [PROGRESS]>
<MCDDiagService<id=14900, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforCoding , service=SA_RSD - SecurityAccessRequestSeed, description=error: timeout, link=REM_72_ETHERNET> [DIAGSERVICE]>
<[REM - 72] prepareECUforCoding finished [PROGRESS]>
<[REM - 72] authenticateECUforCoding started [PROGRESS]>
<MCDDiagService<id=16900, job=com.bmw.psdz.jobs.uds.MCD3_AuthenticateECUforC oding, service=SA_SK - SecurityAccessSendKey, description=error: timeout, link=REM_72_ETHERNET> [DIAGSERVICE]>
<[REM - 72] authenticateECUforCoding finished [PROGRESS]>
<[REM - 72 - cafd_000007a1-005_044_018] Transaction type: cdDeploy; Message: TA started [TRANSACTION]>
<MCDDiagService<id=62651, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : securityAccessDenied, link=REM_72_ETHERNET> [DIAGSERVICE]>
<[] job failed with negative response error:
code: repeat job
description: Service WDBI_PLAIN returned a negative response with response code securityAccessDenied; LinkName: REM_72_ETHERNET
severity: ERROR
[THROWABLE]>
<[REM - 72 - cafd_000007a1-005_044_018] Transaction type: cdDeploy; Message: TA finished [TRANSACTION]>
<[REM - 72] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
code: repeat job
severity: ERROR
[WARN]>
<[REM - 72] - [Exception - REM - 72] job failed with negative response error:
code: repeat job
severity: ERROR
<MCDDiagService<id=84900, job=com.bmw.psdz.jobs.uds.MCD3_AuthenticateECUforC oding, service=RDBI_FTP - ReadDataByIdentifier FlashTimingParameter, description=error: timeout, link=REM_72_ETHERNET> [DIAGSERVICE]>
<MCDDiagService<id=36900, job=com.bmw.psdz.jobs.uds.MCD3_AuthenticateECUforC oding, service=RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession, description=error: timeout, link=REM_72_ETHERNET> [DIAGSERVICE]>
<MCDDiagService<id=62900, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: timeout, link=REM_72_ETHERNET> [DIAGSERVICE]>
<[] null [THROWABLE]>
<[REM - 72] There was an error during TAL execution, please check the log files. [WARN]>
<[REM - 72] - [Exception - REM - 72] negative response error:
code: TIMEOUT P2/T2 occurred
description: P2 timeout on Service WDBI_PLAIN has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: REM_72_ETHERNET
severity: ERROR
<[REM - 72] finalizeECUCoding started [PROGRESS]>
<[REM - 72] finalizeECUCoding finished [PROGRESS]>
<[] There was an error, please check the log files. [WARN]>
<[] - [Exception - REM - 72] negative response error:
severity: ERROR
<[] finalizeVehicleCoding started [PROGRESS]>
<[] finalizeVehicleCoding finished [PROGRESS]>
<[] finalizeTALExecution started [PROGRESS]>
<MCDDiagService<id=464637, job=com.bmw.psdz.jobs.common.MCD3_FinalizeTALExecu tion, service=RC_TAS_ROUTING - Routine Control for TAS, description=error: negative response : NoResponseFromSubnetComponent, link=TAS_F0_ETHERNET> [DIAGSERVICE]>
<[] finalizeTALExecution finished [PROGRESS]>
<TAL execution finished [TAL_EXECUTION_FINISHED]>
TAL-Execution finished with status: "FinishedWithError".
TAL execution finished. Duration: "49s".
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
Please help
