06-18-2018, 03:28 PM | #1 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Stopping the blue Brembo's from squealing. Possible?
Like many others, mine are squealing as I come to a halt when they're warm. It's doing my absolute head in.
So far I've sanded the BMW pads, Greased the back of the pads and sanded down the lips on the discs. This helped to begin with, but it didn't last long. I'm looking at trying new pads and getting the discs skimmed. Has anyone tried either to find that one works, or should I try both? Also, which pads should I try. I've read that Ferrodo pads squeal, but EBC Yellow Stuff DP42130R may be ok, although at £150 for the fronts it's quite a punt.
06-18-2018, 03:35 PM | #2 |
Rep 541
Mine have not squealed once in 18 months.
I dont get a lip on the disc because I have taken mine apart twice and made sure the surfaces where the pads need to be free to move are free of hardened gunge and greased, including the pins which I keep polished. Done this with all my cars since I was 18 and still never had brakes that squeal. This may be just a co-incidence, but it worked for me. |
06-18-2018, 04:03 PM | #3 |
Rep 32,881
Mine have always squealed, with the oem pads, pagid pads and the Ferodo DS Performance pads. The Ferodo’s have been far far better than the other two and only squeal a bit some days and nothing at all other days!
I’ve bought some proper ceratec brake grease to try on them next time I have time to take them apart to clean them, apparently copper grease is advisable on brakes. |
06-18-2018, 04:40 PM | #5 |
Rep 1,060
I stripped my brakes down cleaned and greased with Ceratec and had no squeals in over 10k previously from new I had the terrible squealing on coming to a stop. I have now had the M performance discs fitted all round along with standard BMW pads again with Ceratec on the pad backing and sides before inserting back into callipers. The car has now done over 700 miles and went through some very warm weather temperatures with no signs of squealing.
G15, 840i M Sport
06-18-2018, 04:40 PM | #6 |
Rep 32,881
06-18-2018, 04:47 PM | #7 |
Rep 7,032
Drives: 335xd Msport +
Mine have recently started squealing after 3yrs of quiet service.
Funnily enough was advised pads were down to 3k about 4k miles ago ( still got 3k to go on the I drive ) and apparently a lip was developing. Wonder if that’s the cause.
06-18-2018, 04:48 PM | #8 | |
Rep 7,032
Is that demon driving , mileage or just playing?
06-18-2018, 04:53 PM | #9 |
Rep 32,881
06-18-2018, 04:58 PM | #10 | |
Rep 7,032
Blimey that’s some rate of brake consumption. I’m on 43k and original pads with a bit left!
06-18-2018, 04:58 PM | #11 |
Rep 1,060
As previous post had original pads that squealed coming to a stand stripped and had 10k of silence once cleaned and greased. Front pads were changed with 3k left on idrive but pad measuring 3mm no sensor trigger, rears were just a little more at 4mm idrive showing 12k. Overall pads covered 35k and once reset fronts went to 35k and rears 40k.
G15, 840i M Sport
06-18-2018, 05:44 PM | #13 |
Rep 784
Drives: 2018 F80 M3 CP YMB
68k on mine now - no squeals from new... Changed all round at 40k for Zimmermann drilled & slotted due to a warped rear disc with Pagid pads all round, copious use of copper grease and all has continued to be fine since. I do lots of motorway miles so perhaps more high speed heavy braking than some may help?
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
06-18-2018, 11:20 PM | #14 | |
Rep 2,271
How accurate is the sensor?
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
06-19-2018, 03:13 AM | #15 |
Rep 475
06-19-2018, 07:15 AM | #16 |
Rep 32,881
Strange, I've never heard of that on oem pads. If i were you i'd fit some ebc shims.
06-19-2018, 11:15 AM | #18 | |
Rep 460
06-19-2018, 01:46 PM | #19 | |
Regular user
224
Rep 965
06-19-2018, 05:04 PM | #20 | |
Rep 7,032
Re the sensors accuracy no idea but I guess I know a man who does. Turn on the teaston light.
06-19-2018, 05:17 PM | #21 | |
Rep 32,881
Really is best to check all four pads visually. |
Junebug851615.00 |
06-19-2018, 05:22 PM | #22 | |
Rep 7,032
Didn’t know that about the sensor. Mines reading 3k miles so better keep an eye on things. Thanks for the info !!!
teaston10994.50 |
