BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport+ Coding
      12-05-2013, 12:27 PM   #23
marcoac14
Drives: E90 M3
I just told you above.
For F10, it is Steering Wheel with paddles and different GWS Gear Shift.
For F30, I don't know if it is Steering Wheel with Paddles only, or also a different GWS Gear Shift.
I see. It may not be necessary to replace the GWS but what's the benefit of replacing it? None?
      12-05-2013, 01:07 PM   #24
shawnsheridan
shawnsheridan's Avatar
That would depend on whether it is different or not, and as I wrote, for F30, I don't know if it is different or not.
      12-10-2013, 07:24 PM   #25
Kospir
Drives: F30 320i
is it possible to retrofit f10 sport automatic gear shifter to f30 320i ?
      12-10-2013, 09:02 PM   #26
shawnsheridan
According to ETK, they are different.
F3x has it's own SAT Gear Shift though, so why would you want one from an F10?
      12-10-2013, 09:48 PM   #27
Kospir
Drives: F30 320i
I let my friend buy it for me on ebay and now i understand shifter not for f30. So i have to buy another one for my f30 now
      12-11-2013, 05:29 AM   #28
shawnsheridan
Throw it back up on ebay, it will sell.
      01-18-2014, 12:56 PM   #29
kapkanimd
Drives: 2020 M8 Competition Gran Coupe
I added the SAT to my car and it is a pretty significant difference, especially in manual mode. I am still in the process of adding in Launch control. In order to get it to work, I upgrade the I-step level on the EGS ecu which was a pretty scary experience. The option is now available for FA coding, and I added it. I just drove a few miles (instructions said it had to be warm) and couldn't get it to come up. I realized I forgot to recode in the SAT when I updated the ecu so I just did that and will try it again next time I drive in the chance that SAT is required for it to work.
      01-18-2014, 03:12 PM   #30
carzaddict
Drives: 2015 Cadillac Escalade ESV
Originally Posted by Timur View Post
It is possible . I have done on on my 320i.
Do the following:
Kombi => 300C ECO_FDS =>Function
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
ICM/IcmKod_B_S2TBA -> verbaut
It will activate sport+ and sport transmission )))
Or you also could add 2TB option and delete 205 in salapa element
which part of this is for sports automatic transmission only?
i did
and got a Chassis stabilization error, althought it went away when i restarted the car. I dont feel a difference in the shifts
2015i Cadillac Escalade ESV
      01-18-2014, 04:38 PM   #31
Zulbat
Drives: F20 120D
Is it possible to code SAT shifting behavior on F30 318 or F20 118 which usually are not available with sport auto from factory?
      01-18-2014, 05:46 PM   #32
Timur
Russian Federation
Drives: BMW 320
i did
Do not worry abt. "Chassis stabilization error" - it always pops up
You did everything right . When you put your shifter to DS - do you see S1 indication on dash board ?
This is how it supposed to look (flag is LC)
      01-18-2014, 05:48 PM   #33
Timur
Russian Federation
Drives: BMW 320
No, its not possible in general.
Some people say that they were able to code launch control and sport tranny, but I have not seen it personally.
Try it out.
      01-18-2014, 06:29 PM   #34
carzaddict
no i did not see any gear numbers in DS. I wonder if theres a difference between the US and Russian versions
      01-18-2014, 06:31 PM   #35
Frogman
Drives: 2012 F30 328i
If you code both Sportschalter and Sportschalter_alt to aktiv, you will.
These are in EGS (or GKEB) / 3000.
      01-18-2014, 07:27 PM   #36
carzaddict
I just double checked and it seems that i forgot to set Sportschalter to active, only Sportschalter_alt was
i just did it now, ill be going out in a little bit and ill test to see if it works
      01-18-2014, 10:22 PM   #37
kapkanimd
I just tested mine! I went from the no-line with only sport mode to now having sport+, sport automatic transmission, and now launch control !!!!
Coding is awesome!! I love launch control!!
      01-18-2014, 10:27 PM   #38
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
Just quick question.
For the people who coded SAT, did you guys also buy the SAT Gear shift or just code those values?
      01-18-2014, 10:29 PM   #39
kapkanimd
Just the coding.. I don't see a need to spent $600+ on a shifter that only changes looks AFIK...
      01-18-2014, 10:35 PM   #40
Tim@codemybimmer
Just checking.
Makes me want to code in the SAT. Don't know why the 12-13 MY 328s didn't get the 2TB option but gets it in 14 for Canadian models.
*Should have also asked my advisor if they could order the Sport Steering Wheel with Paddles instead of the same replacement since I'm getting the wheel replaced under warranty anyways*
Does the transmission shift any better in just the normal Comfort/Sport modes?
      01-19-2014, 02:39 AM   #41
Timur
Russian Federation
Drives: BMW 320
Just checking.
Yes, definitely better and sportier in my opinion
You can also buy yourself a new steering wheel with shifters, and sell yours. If you code stated above values shifters gonna work
You can also retrofit shifters to the sport steering wheel (some cuttings will be required)
      01-19-2014, 09:47 AM   #42
carzaddict
so after recoding Sportschalter to aktiv, i can confirm I have SAT and it works.
I notice it more on the 1-2-3 shifts...not so much in the higher gears. never the less its cool and I see what gears I am in in DS mode
      01-19-2014, 12:10 PM   #43
Timur
Russian Federation
Drives: BMW 320
Good job
Did you code LC as well ?
      01-19-2014, 12:28 PM   #44
marcoac14
Drives: E90 M3
How does launch control work?
What I usually do is turn DSC fully off, hold brake, press the throttle pedal and release brake pedal.
Is it any better than "my launch control"?
