01-24-2021, 07:26 PM | #1 |
Rep 17
Will F8X axles fit F3X?
Hello all,
I am currently in the process of upgrading my engine and turbo setup and looking to put significantly more power down than my previous setup. I am in the process of gathering parts for LSD and I'll be doing a 15" wheel conversion in the rear. With the kind of power I'll be putting down, and the hard launches that will be taking place in a drag race setting, axles and driveshaft are a concern of mine. I was curious if anyone has upgraded the rear axles on their F3X. Will the F8X axles be a direct replacement? I was also curious to see if anyone has upgraded their driveshaft to a one piece driveshaft? Any insight is welcome. Thank you! |
01-24-2021, 09:06 PM | #2 |
Car Hypochondriac
335
Rep 901
F8X axles will not fit. But I have basically not heard anyone complain of broken axles in high HP F3X.
Edit: you could consider checking if raxles makes a set for the F3X. |
JeffNotSoSlow2.50 |
01-24-2021, 09:35 PM | #3 | |
Rep 17
I appreciate the input! |
01-26-2021, 09:43 PM | #5 | |
Rep 17
I'm chasing a 10 second pass, so at this point I know it's inevitable. |
01-27-2021, 12:47 AM | #6 |
Rep 3,538
I'd look at the axles/drive train components from the 3/435dx. 465lb-ft of torque vs 443lb-ft in the M4 GTS.
JeffNotSoSlow2.50 |
01-27-2021, 10:58 PM | #7 |
Rep 17
01-27-2021, 11:16 PM | #8 |
Car Hypochondriac
335
Rep 901
Just checked, the diesel axles are actually 27mm thick, while the 335's are 35mm. No idea on length or anything. Maybe the diesel ones are solid rather than hollow?
Would be very easy to grab some for cheap from lkq or something similar. |
01-27-2021, 11:18 PM | #9 |
Car Hypochondriac
335
Rep 901
For reference,
335i axle left/right: 33207597685/33207597686 335dx left/right: 33207597689/33207597690 |
01-30-2021, 12:13 AM | #11 | |
@_sunbish
282
Rep 609
JeffNotSoSlow2.50 |
01-30-2021, 03:34 PM | #12 | |
Rep 833
Drives: BMW F36, E36, E93
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required Last edited by BWbimmer; 01-31-2021 at 11:11 AM.. |
02-01-2021, 02:38 AM | #13 | ||
Rep 17
