01-27-2018, 04:11 PM | #23 |
Rep 3,211
Well you mentioned your Dinan tune, if BMW won't cover it then shoot over to those guys
Hopefully it was the Dinan elite where they cover your warranty.. does Dinan tune play well with DP? I think you were taking alil risk there.. like the others said if you wanted a DP I'd have gone with JB4. BTW you should remove the CG DP because its not legal to remove the stock DP on a functioning new car and I bet California is even more strict about that Personally I dont think a DP gives you enough of a bump to warrant the additional risk in legality, warranty, and operationals but thats me. At best you may have a blown gasket.. at worst you may have a crack in the block If you didnt get any engine codes thats a good omen but I'd expect you got something..did you not notice any codes? You gotta pray u dont have a crack and to replace the engine cause thats around 20k for a B58 I believe .. I dont have all my data in front of me but I recall its shy of 20k BTW what octane were u runnin Sorry this all happening to you.. keep your spirits up..at the end of the day a lesson is learnt and yer still alive and healthy |
01-27-2018, 04:26 PM | #24 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
01-27-2018, 04:57 PM | #25 |
Rep 127
You sound awfully confident... unfortunately Im not so sure about that. Corporate will easily take the easy way out, unless you know the right people or truly get lucky. Particularly, if they can prove that the engine had a tune on it - in this case, a Dinan piggyback that does not carry warranty.
His only option then would be to lawyer up and go to court, and that isnt going to be a cheap process that far from guarantees a successful outcome. Best of luck, OP. |
01-27-2018, 05:32 PM | #26 | |
Rep 1,348
Years ago I had a car with mods and started the car one day(had 34k miles) the motor threw a rod out the block. Did not even drive it. The dealer replaced the motor under warranty. Had cat back exhaust and CAI still on the car. I had removed the piggy back. Later on it was discovered that the model I had was prone to a factory defect known as crankshaft walk. It happens! Im hoping for the best for the OP as well.
01-27-2018, 07:09 PM | #27 | |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
AW F30 I don't think you should worry about them "screwing you over". Being an engineer myself, I'd trust the engineer's analysis of the situation and data logs from the ECU - it's their job to find the root cause of the failure, that's all they care about. BMW NA cannot and will not ignore the engineer's findings in making their decision. If they do deny warranty, they should give you a clear reason for it - demand to see the report, although I don't know if they'd share it with you. That's when I'd involve Dinan as a next step if possible. Unfortunately, our instincts will want to keep us guessing what happens next but all you can do now is sit tight and wait for the report. Sorry to hear about the situation but stay persistent and I'm sure you'll get through it.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
ceedawg467.50 |
01-27-2018, 08:01 PM | #28 | |
Rep 1,348
Regardless I feel you and I are on the same page concerning BMW and their findings on this poor guys issue.
01-27-2018, 08:16 PM | #29 |
Rep 5,995
Maybe you can do a claim through your car insurance, not sure if it covers damage from mods though. Maybe if you broke down and someone rear ended you intentionally lol.
01-27-2018, 08:31 PM | #30 | |
Rep 1,055
01-28-2018, 04:06 AM | #31 | |
Rep 1,348
DrifterX514.00 |
01-28-2018, 05:12 AM | #32 | ||
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
01-28-2018, 06:50 AM | #33 |
Rep 1,348
A flash yes but a piggy back that does not exist no! Unless the gun is found there is no weapons charge!!] And at this point this is all speculation till we see what BMW does.
01-28-2018, 07:46 AM | #34 | |
Rep 3,211
They are not showing their cards but they are clearly detecting piggybacks like JB4 and denying warranty when the $ is high There is always lawyers and the court system but who has the money to risk to fight this esp when you are guilty and not sure what evidence they have in their ECU logs? They have a hand theyre daring you to up the ante.. your move.. u gonna call? think their bluffing on a 20k engine replacement? I wouldnt spread false confidence regarding this topic |
kern4174446.50 |
01-28-2018, 08:52 AM | #35 | ||
Rep 703
01-28-2018, 11:16 AM | #36 |
Rep 1,454
That engineer gets his checks signed by BMW. He works for BMW. It's in his best interest to help BMW.
That's like you asking your company HR to help you against the company. No. Your HR works for the company, not you lol.
2022 CT4-V Blackwing 6-speed
kern4174446.50 |
01-28-2018, 12:07 PM | #37 | |
Rep 127
The whole thing about them having to prove the the part caused a failure is a moot point. You got 10-15k to even start the legal process by engaging attorney, hiring independent parties to do due diligence and issue independent reports etc. Bmw has got full legal departments to deal with precisely these types of cases. His only shot is for a 'goodwill' warranty, where they cover it due to him being a good customer / in spite of being able to deny coverage. |
Beek707.00 |
01-28-2018, 12:39 PM | #38 | |
That Libertarian Guy
4039
Rep 6,363
01-28-2018, 03:47 PM | #39 | |
Rep 1,170
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. Last edited by Beek; 01-28-2018 at 03:56 PM.. |
01-28-2018, 04:07 PM | #40 | |
Rep 1,170
Hope you get good news soon, good luck!
'09 Outback for a beater and grocery getter. |
DG20966.50 |
01-28-2018, 06:08 PM | #41 | |
Rep 3,211
BMW service does do engine work.. they dont replace the engine unless its major.. thats a joke.. they dont replace a 20k part unless the servicing costs approach some % of that which indicates major complex issue not worth the time-work either way it'd be nice if they at least tell you exactly what they found was wrong with it to let the indy know.. they kind of owe that to you anyway if they are denying warranty pray for goodwill warranty like beek said.. be real nice and ask for mercy.. admit little but be real nice |
01-29-2018, 11:07 AM | #42 |
Cheapskate
4447
Rep 4,993
Some of you are way too confident. How a situation *should* work in your head rarely matches how it actually works in this sort of scenario, especially when dealing with a major company.
If OP gets lucky, good for him. But any field engineer can call a non-oem component of your car a cause for voiding your warranty. And not only is it not oem, but it's an illegal component. It doesn't matter how common the mod is or how many people get away with it. BMWs responsibility is not to prove what mods work on your car. They gave you a factory warranty on factory parts. If you change that, even with an aftermarket intake, then they cannot guarantee the integrity of your car. I've said this in other threads and I get bashed for it, but I just don't trust tuning these cars yet. Operating at 14+ AFR in boost on the brink of throttle closures with piggy back tunes does not give me a warm fuzzy feeling. It's too easy for something to go wrong, and I'd rather have a safe setup that doesn't rely on the car's ecu to save me if I do hit a limit. OP, I do wish you luck because the situation sucks, but chances are that all that fighting will leave you without a car for weeks, and then still not have a warranty after it's all said and done. If they let you swap parts before the field engineer arrives, I'd jump all over that. |
01-29-2018, 11:16 AM | #43 |
Rep 5,369
AW F30 - Has your car had a history of loosing coolant?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
340i, b58, engine |
