12-28-2020, 08:50 PM | #1 |
Rep 25
Cracked wheel, will these new ones fit?
Hey I'm not the best with fitments and I've read up as much as I can. I cracked one of my stock wheels and I'd rather buy a new set but I'm trying to get them ASAP but this is the setup I'm looking for. Not sure on what tire/sizes yet, still looking at options so any recommendations are appreciated. It's an F32 xDrive. Thanks for any insight.
12-28-2020, 09:29 PM | #2 |
Rep 3,185
I'm not sure if the fronts would fit, might hit the shock. At et 40 it is 10mm closer to the shock than stock. So you can take a look and see if you have that much room to be safe.
12-29-2020, 06:41 AM | #3 |
A family of bimmers
2745
Rep 7,741
I run that exact wheel in 18x8.5 et40 for winter on my f30. It is really close to the strut but fits. you may want a 10mm spacer depending on the width of the tires you choose
I hope this helps.
12-29-2020, 01:02 PM | #5 |
A family of bimmers
2745
Rep 7,741
et35 would fit perfectly in that wheel size. I have that for my summer setup up front with a 19x9.5 et45 out back.
this is at stock xdrive height with 235/265 tire sizes and no spacers
alohasurftoad3069.00 |
01-02-2021, 08:05 PM | #6 |
Rep 25
Love the setup. Unfortunately they don't make the wheel I posted in et35 anymore just et40, which to my understanding now still fits fine
01-03-2021, 06:36 AM | #7 |
Rep 611
It will poke 2 mm more than stock 19x8 ET36. Considering that, I second the suggestion of adding a 10 mm spacer for the flush fitment, as it improves the wheel appearance a lot.
01-03-2021, 08:58 AM | #8 |
Rep 4,314
Consider a different model or different brand offering desired width and offset and flow formed/rotary forged barrels.
What is your budget for wheels, tires, tpms? 18" or 19"? Square or staggered? |
