01-11-2021, 03:53 PM | #1 |
Rep 62
best brake pads (no squealing) + discs
...2016 335d xdrive
what brake pads do you guys recommend? my current brake pads make a squeeking/squealing noise when brakes are applied which is so annoying ?? also what brake discs??
JayAr FTHIRTY
01-11-2021, 04:19 PM | #2 |
Rep 1,686
Drives: 2014 428i and 2018 X5
This question has been asked and answered dozens of times already. I suggest you just browse the forum for the other threads.
01-12-2021, 08:08 PM | #4 |
Rep 10,256
What brakes - rotors and pads - does your car have? OEM, aftermarket? How many miles since the last brake service?
01-13-2021, 07:11 AM | #5 | |
Rep 62
rear brake pads have been just before i purchased the car about 3000 miles...ive been told cheap pads can cause this? fronts are due in april...
JayAr FTHIRTY
01-13-2021, 07:22 AM | #7 |
Rep 62
01-16-2021, 08:35 PM | #8 |
1 expensive toy
41
Rep 275
it depends on what you'll be doing with the car.
foe daily driving, definitely go with zinc coating or a rust free guarantee rotor. most ceramic pads are good. I always put a little crc disc brake quiet on the back of the pads and really never have issues with squeal. also make sure you burn in the brakes if they require it.
2016 F30 340i M-Sport
01-24-2021, 03:26 AM | #9 |
Rep 126
02-22-2022, 07:31 AM | #10 |
Rep 10
Hi All
I had the same problem. BMW F30 LCI. Large blue brake system (370mm front brake disc, 345mm rear brake disc). It has a factory brake disc. I tried several brake pads. Factory, TRW, ATE Ceramic, Quaro Ceramic brake pads. Unfortunately, none of them provided a solution. A car mechanic has successfully used the EBC Yellowstuff insert on several cars (BMW M8, BMW X6M). I also bought one for the front brake and so far I have used over 1200km without any problems. |
