02-28-2016, 08:36 AM | #1 |
Rep 14
SOLVED!!! HALO Brightness %100 with lowbeams F30LCI NON ADAPTIVE LED HEADLIGHT
THANKS TO dmnc02
I tried everything since my car delivered. And dmnc02 solved it. With non adaptive led headlights (adaptive ones could do the same im not sure) BOTH FLE MODULES POLI1_Idx POLI2_Idx POLI3_Idx Change the 05 to 04 in werte values ex: the default is like this 00, 00, 00, 00, 00, 00, 05, 00, 00, 00 after it should be like this 00, 00, 00, 00, 00, 00, 04, 00, 00, 00 and please share the photos with %100 halos with lowbeams |
02-28-2016, 07:19 PM | #4 |
Rep 1,481
US- or EU-spec car? Adaptive or non-adaptive LEDs?
With the FLE ECUs, changing the brightness of a LED module (e.g., DRL) is no longer a matter of changing the Werte value of a predefined parameter to desired intensity (as it should be clear from the OP), so you have to take into account how the rest of the ECU is coded.
2015 Mineral Grey ///M4 6MT
03-01-2016, 01:19 PM | #5 |
Rep 1,436
It's already 01, 01, 01, 01, 01, 01, 04, 01, 01, 01
what should I do !!
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
03-01-2016, 02:15 PM | #6 | |
Rep 1,481
It is really impossible to tell what setting will give you 100% intensity for the position lights without looking at the way the entire ECU is coded (which varies depending on factors such as your location and whether you have adaptive or non-adaptive LEDs). If you want to know the right setting for your car, post the NCD file for your FLE ECU.
03-01-2016, 03:42 PM | #7 | |
Rep 1,436
It's F20 120i not F30 so maybe that's why it's different I have coded to 05 and they were completely off lol how can i get this NCD ?
03-01-2016, 03:54 PM | #8 | |
Rep 1,481
Assuming that you have not coded any other car after the 120i, the relevant NCD is the file named CAFD_000024C3_xxx_xxx_xxx.ncd in your C:\Data\CAF directory.
03-02-2016, 04:34 AM | #9 |
Rep 1,436
is it that specific file because i code a lot of cars
03-02-2016, 04:44 AM | #10 |
Rep 1,436
03-02-2016, 09:36 AM | #11 |
Rep 1,481
The file has to be from the specific car you want to code, otherwise the settings will be different, defeating the purpose.
robbiestapes30.00 |
03-03-2016, 02:40 PM | #13 | |
Rep 1,481
If so, the easiest way to change the halo rings to 100% when used as position lights is to set POLI1_Idx, POLI2_Idx and POLI3_Idx in both FLEs to 00, 00, 00, 05, 00, 00, 04, 00, 00, 00. To change them to 60% instead, set POLI1_Idx, POLI2_Idx and POLI3_Idx in both FLEs to 00, 00, 00, 05, 00, 00, 0F, 00, 00, 00 and then code LmmIdx15_Intensity = 3C LmmIdx15_Priority = 03 (edit the Werte values directly) in both FLEs.
03-03-2016, 05:12 PM | #14 | ||
Member
55
Rep 249
03-24-2016, 06:52 PM | #16 |
Rep 1,986
By default - aren't they set to 100% during the day, and when headlights are on can be changed to 100% by modifying:
MAPPING_STANDL_V_L_PWM_LEVEL_1 MAPPING_STANDL_V_R_PWM_LEVEL_1 I am new to coding so just trying to understand. |
03-25-2016, 09:02 AM | #17 |
Rep 548
Drives: 2011 E90 M3 ZCP
Does anyone know if the main LED headlights are set to 100% by default on a US spec car?
This info is great so far! |
03-29-2016, 03:45 PM | #19 |
Rep 14
04-01-2016, 04:16 PM | #20 | ||
Member
55
Rep 249
Tried couple of intensities, and settled on LmmIdx15_Intensity = 32 ( 50% when headlights are on). Very happy and thanks for the help. |
04-02-2016, 11:35 AM | #21 |
Rep 5,316
Drives: G80 M3 6MT
You shouldn't do this, it makes the rings look washed out at night, there is a reason they dim when your low beams are on.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
