03-24-2022, 10:18 AM | #23 |
Rep 7,597
1bad14-F3030.50 |
03-24-2022, 05:46 PM | #24 | |
Rep 10,346
"Drive more, worry less. "
04-04-2022, 12:32 PM | #25 |
Rep 75
Did mine at 87k and plan to do it again at 120k. Running Redline D6 ATF. Already have the fluid and the new pan/filter from FCP Euro.
Can it go longer? Others have proven it can, but I drive my car hard and it is an easy maintenance item to do. Fresh fluid is ALWAYS better than older fluid that has degraded over time with heat.
2014 335i - BM3 Stage 2+ Race Gas, VRSF Catless DP, Race IC, CP, Muffler Delete, xHP Stage 3, NGK 97506, Eldor Coils, Turner Motorsport intake with BMS filter, BMS Oil Catch Can, Red Line fluids.
06-08-2022, 07:16 PM | #26 |
M340i
392
Rep 967
Drives: BMW M340i
Anybody got a link to a diy on changing the pan and fluid? Fcp euro sells a trans fluid kit. I saw their diy video but they mentioned using a pump or something. It looks like you have to be specific on how much fluid you put back.
06-08-2022, 10:38 PM | #27 |
Rep 7,597
You will need to follow the ISTA procedure, monitor temps, etc. Aside from youtube videos using ISTA is a good idea
06-29-2022, 12:36 AM | #28 |
Rep 9
I changed my trans fluid at 200 000 km as a precaution. I didn't feel any change in shifting but it was a relief even though it is 'life time fluid'. I am now at 263 000 km with no issues. The sooner you change it the better I guess. I plan on doing the coolant as well even though that is also 'life time fluid'.
07-02-2022, 03:43 PM | #29 |
Rep 25
ZF does recommend fluid changes, the interval depends on your trans. I did mine around 30 or 35K, and will likely continue this pattern. But for the sake of clarity I have a lift in the garage which makes this endeavor much easier.
The tools necessary are simple but a couple investments are necessary. A code reader designed for BMW is necessary given you add fluid till it drips, then start it and wait for fluid temps to reach 50C, then follow the same procedure. A simple fluid transfer device will make your life easier if not necessary,I recommend Motive, and you will find other uses for it once you have one. Have fun with this! But I’m one of those fools that enjoy this kind of crap. |
07-06-2022, 09:54 AM | #30 |
Rep 4
Drives: BMW 435i Xdrive
I had my F32 N55 tranny fluid changed and a new pan ($) at an Indy Shop yesterday. It was at 110 km. The mechanic did note the fluid was dirty. Now, what about those transfer case fluids?
07-06-2022, 09:56 AM | #31 |
Rep 277
How much did they charge you in total?
If you aint first, your last.
