07-01-2022, 10:12 AM | #1 |
dad bod
386
Rep 382
Replacing injectors after failure — any advice for removing excess fuel?
2015 335i xDrive here w/ 70k miles. Went WOT the other night, misfired and went into limp mode with smoke/extreme fuel smell so I immediately shut down and got it towed to the dealer.
Injector #4 failed, #5 and #6 on their way out. Dealer calls me and says it’ll be $4409 to replace all 6. Hell no! Towed back to my place, I’m planning on tackling it myself now. Doing plugs, coils, oil, coolant, and oil filter housing gasket while I’m at it. Bought all the tools I needed and the scanner for coding and a rental since I’m saving so much money lol. My question is, since 1 (or more) cylinders were flooded with unburnt gas, what’s the best way to get it out without risking hydrolock? I’ve only dealt with this once a long time ago in my CRX, I just pulled the fuse for the pump and cranked it until it died, but this being a DI (and the most sophisticated car I’ve ever owned), I wanted to ask here first. Any tips/advice would be greatly appreciated!
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
07-01-2022, 10:28 AM | #2 |
1296
Rep 3,529
It really shouldn't be a problem but you can literally pull the plugs and use a little hand pump with a flexible hose to pump put any fuel that has collected. If the cylinder really was full of fuel that would be the easiest way. Also change the oil immediately after getting it running again.
07-01-2022, 11:28 AM | #3 |
Rep 5,366
How in the hell could replacing 6 injectors cost $4500? The BMW EU6 injectors (made by Bosch) are ~$350/ea or you can be the same non-BMW branded Bosch injector for $90. Even with buying the BMW injectors and the injector seals, the parts costs would around $2,200. It would literally take a tech an hour to remove and replace the six injectors but I'm sure book time is something like .75 hours each so figure $1,200 in labor. So where is the remaining $1,000? I just just get how BMW dealers charge so much and how their pricing is so wildly variable amongst their dealerships. Book time estimates are supposed to even the playing field but this doesn't seem to apply to BMW dealers.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
07-01-2022, 12:54 PM | #4 | |
Rep 7,591
F32Fleet3566.00 |
07-01-2022, 12:58 PM | #5 |
1296
Rep 3,529
It absolutely has, hence the oil change immediately after getting it to run. The problem is a lot of that fuel just will get dumped put the exhaust if you do that. Bad for the turbo and etc...
07-01-2022, 01:22 PM | #6 | ||
dad bod
386
Rep 382
So if I: -pull plugs -suck up as much as I can with the pump -turn the engine over -install new injectors -install oil filter housing gasket -change oil -install new coils+plugs …is that the best order to do things? |
07-01-2022, 01:28 PM | #7 | |
dad bod
386
Rep 382
07-01-2022, 05:16 PM | #9 | |
Rep 5,391
07-01-2022, 05:34 PM | #10 | |
Rep 1,597
07-01-2022, 05:50 PM | #11 | |
Rep 7,591
07-01-2022, 07:18 PM | #13 | |
Rep 10,346
Prime the oil pump before you restart the car. https://www.google.com/url?sa=t&sour...Z31cOuwN8uzkC9
"Drive more, worry less. "
07-02-2022, 08:08 AM | #15 | |
Rep 5,391
What's even more brutal is that you can pay through the nose and not even get a high level tech. At my local dealership is that they assign techs in the order that cars come in to the service dept, not by their experience level/training with the task to be done. I don't take my car in if it's something simple yet I can get someone inexperienced who mostly does oil changes. Paying an ridiculous rate for someone to learn on the job. |
07-02-2022, 08:06 PM | #16 | |
Rep 10,346
07-04-2022, 08:54 AM | #17 |
dad bod
386
Rep 382
Thanks for the help everyone. 3 injectors down, 3 to go. A bit of advice for anyone who needs to do this in the future: don’t cheap out on the injector puller/installer tool…
I found one on Amazon for $30 that had mostly positive reviews, but it’s absolute garbage and the only reason I haven’t finished. The threads for the injectors are super rough and it’s impossible to thread in two injectors at the same time without damaging threads. The (PLASTIC) spacers collapsed before even reaching 8nm of torque, I had to make my own spacers out of some spare metal pipe I had laying around, and after chasing the threads on the tool 3x, decided I can only do one injector at a time. /rant Just buy the $200 one and save yourself the headache. |
07-12-2022, 10:13 AM | #18 |
dad bod
386
Rep 382
Injectors have been done for about a week and I’ve driven it a few times since, but the idle is pretty rough on cold starts. It improves once the engine is warmed up but I can tell it’s still slightly inconsistent.
Just put in fresh fuel and some techron, but I’m wondering if I should do a walnut blasting. Any ideas? |
07-12-2022, 11:09 AM | #19 | |
1296
Rep 3,529
johnung4525.00 |
07-12-2022, 11:42 AM | #20 | |
Rep 7,591
07-16-2022, 11:58 AM | #21 |
dad bod
386
Rep 382
Never got around to trying it, but the good news is the idle cleared up after going for a longer highway drive and has been buttery smooth since.
On another note, my timing seems all over the place, especially at higher RPM. This log was done with a full tank of Shell V-Power 93. I did NGK 97506's gapped to .020 per Cary Jordan's recommendation for his E30 tune I'm running. Haven't had a chance to log with that tune yet -- wondering if running that plug/gap combo with 93 could be part of the issue? Unless I'm missing something, everything else in the log looks good, other than the stock turbo running out of breath. https://datazap.me/u/bemdubya/4th-5t....69&tmax=24.53
07-16-2022, 01:06 PM | #22 | |
Rep 7,591
