07-29-2021, 07:25 PM | #2 |
Rep 4,327
OEM diameter is 26". 295/40/18 is 27.3" is too tall and with slight poke will rub the fenderwell lip. it's also changing gearing at the pavement, as well as adding weight and rolling resistance.
widest i've seen in rear is 295/30/19(26") at ET45. depending on actual diameter and girth of the specific brand and model of tire, you could probably fit 295/35/18(26.1") at ET45 as well however imo 285/35/18 is the widest practical size in the rear at ET42ish. you can browse through and query the Wheel and Tire technical subforum for more info and response. https://f30.bimmerpost.com/forums/fo...play.php?f=423 |
07-29-2021, 07:30 PM | #3 | |
Rep 6
07-29-2021, 07:46 PM | #4 | |
Rep 4,327
https://f30.bimmerpost.com/forums/sh...d.php?t=909786 |
07-29-2021, 07:55 PM | #5 | ||
Rep 6
07-29-2021, 09:53 PM | #6 |
Rep 16,080
07-30-2021, 02:13 AM | #7 | |
Rep 4,327
i suggest 275/35/18. you will have to lower to reduce fenderwell gap and have at least -2 degrees camber, to avoid rubbing during compression and turning full lock. here is an example. https://f30.bimmerpost.com/forums/sh....php?t=1340277 if you don't lower, it may have somewhat of a "toy car" appearance due to large fenderwell gaps and poking tires. |
07-30-2021, 10:34 AM | #8 | ||
Rep 6
Thank you for answering cause nobody is helping on the other forums |
07-30-2021, 11:10 AM | #9 | |
Rep 4,327
if you have not ordered the wheels yet, then change the rear wheel size to 18x10.5 ET40. 285/35/18 will fit on this setup. 18x9 ET30 with 255/40/18(26") front 18x10.5 ET40 with 285/35/18(25.9") rear this will be perfect staggered wheel and tire size combo for you. |
B58_Ant0.00 |
07-30-2021, 11:12 AM | #10 | ||
Rep 6
08-02-2021, 06:40 PM | #12 |
Rep 6,238
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Why are you even here other than to be an asshole? What part of ending the thread with “I appreciate the help” did you not understand?
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
06-30-2022, 05:31 PM | #13 | ||
Rep 9
