09-13-2021, 10:52 AM | #1 |
Rep 121
My factory warranty finally ended in August on my 2017 340i xDrive. I've been itching to tune the car as this will be my first tune. I'm a newbie in this area for sure. This is my 3rd BMW, I've had a 2011 335i and a 2014 428i but never messed with tunes or performance modifications of any sort. Most of my modifications have been comeplety exterior or aesthetic (M performance parts, wheels, interior, etc.)
I do not have any modifications such as an intake or down pipe so I was leaning towards doing a Bootmod3 Stage 1 / 93 Octane map. I would like to confirm with others who ran a similar platform did so without any modifications. I have Shell V-Power 93 Octane here and that is all I use so I think I should be fine doing the 93 over the 91 map. My car has 28k miles, should I also change spark plugs before tuning? Any input is greatly appreciated.
?17 Black Sapphire Metallic 340i
09-13-2021, 01:07 PM | #2 |
Rep 85
Someone is selling a BM3 tune for $400. Grab that and you're good to go. If you want to be really conservative use the 91 tune. Either way it will be a different car. Can't hurt to change the plugs, depends how many miles are on them.
Scorp10114.00 |
09-13-2021, 04:07 PM | #3 | |
Novice
303
Rep 695
Scorp10114.00 |
09-13-2021, 07:06 PM | #4 | |
Rep 148
Agreed. I am running the 91 oct maps with 93 oct fuel and it's pretty good. I tried E30 for fun, and well, it's definitely addicting. The power is insane. Ultimately, I feel safer with 91 oct map. Just make sure to log whatever maps you run at wide open throttle (WOT) so you know how the engine is behaving. You don't want to just choose the 93 oct map with 93 oct fuel thinking it will run perfectly, a lot of the time it won't. |
Scorp10114.00 |
09-14-2021, 09:57 AM | #5 |
Rep 3,368
I personally think stage 2 with an AA catted DP is the sweet spot. Emissions compliant in 49 states and the map is so much smoother than stage 1. Stage one was nice, but too much power upfront and I did not like the idea of running additional boost on the stock pipe. Sold the stock pipe to pay for the AA pipe.
09-14-2021, 01:22 PM | #6 |
Rep 51
I'm similar to you, 2016 340i RWD without any mods except for a BM3 tune. Stage 2 93 and 93+ tunes all logged clean (I'm UK based running 99 Ron fuel) and I've been running them for 10k miles without issue.
Don't be scared to try the stage 2 tunes out without mods, as long as everything logs fine you'll have no issue. Logging is the most important thing |
Scorp10114.00 |
09-14-2021, 07:35 PM | #7 |
Rep 148
I also run 91 oct map with 200 cell dp and afe closed air instake. I just recently installed BMS WMI so will be switching to the 93 oct map. Always play it safe with timing and boost. Check the "log review" thread in this sub forum to check the max boost and max timing at 6kish RPM. That will tell you show you which boost values are targeted and timings are targeted for each tune. For me, I'd stick with stage 1 91 oct or stage 2 91 oct, or E30 maps (higher timing on each). They don't go crazy boost, but instead rely more on timing. Use E85 added to your tank to get there or WMI.
Scorp10114.00 |
09-15-2021, 07:18 AM | #8 | |
Rep 223
MTTH232.50 |
09-15-2021, 04:53 PM | #9 |
Rep 51
Yeah just load and go, I've had no issues at all. In my experience, the factory cat appears to be high enough flow to accommodate the extra pressure and heat resulting from the stage 2 maps
09-15-2021, 07:48 PM | #10 | |
Rep 298
I would suggest 94201 NGK Plugs gapped to 0.022" for your car (also good for Stage 2 and Stage 2+). Best of luck!!
17 BMW 340iX / DAW UF/ DS2 HPFP
Scorp10114.00 |
09-17-2021, 09:37 AM | #11 |
Rep 190,777
Stage 1 does not require any modifications
Stage2 requires high flow catted or catless downpipe
Scorp10114.00 |
09-17-2021, 09:49 PM | #13 |
Rep 205
Make sure your DME can be flash tuned if you're trying to go with bootmod3 (ie. It hasn't had recent software updates from bmw, etc.). I figured my car's production date was too old (2017) so I'd be fine, but mine has to be bench unlocked first before a flash tune. If you go with bm3, you can always reach out to their support and send them your cars info to make sure it's flashable before you buy the license.
You can wear your battery down by attempting to flash several times. |
Scorp10114.00 |
09-19-2021, 05:11 PM | #14 |
Rep 4,876
09-20-2021, 03:08 AM | #15 | |
Rep 51
I'm sure everyone agrees that the stage 1 tunes are suitable for the factory DP, so the question is why would the stage 1 93+ tune targeting nearly 20psi boost and an AFR of 12.2 at it's richest be ok for the factory DP https://www.bootmod3.net/log?id=60ec...729b1c1c2892c8 ... but the stage 2 93 targeting 17psi boost with similar AFR's to stage 1 not be suitable for the factory DP? https://www.bootmod3.net/log?id=60d8...90c65df0b121b1 That just doesn't make sense. That said, if it melts and fails then I'll part with the money I would have spent and buy a sports cat. But 10k miles in, I'm still on the original cat, enjoying the car with stage 2, and I'm circa £1,000 better off. Last edited by Scott340; 09-20-2021 at 05:40 AM.. |
09-20-2021, 08:32 AM | #16 |
Rep 4,876
Stock isn't high flow... period... It's a dual catalysis design which is restrictive.
If it was high flow, why would ANYONE replace it? As for the targeted boost values, that depends heavily on other factors (IAT's, ECT's, etc). |
09-20-2021, 02:10 PM | #17 |
Rep 91
Then you got yourself a free catless
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E40 Mix Stage 2+ Tune | FX-150 HPFP
09-20-2021, 02:15 PM | #18 |
Rep 51
A DP is only as restrictive as its most restrictive element, in the case of the stock DP that would be the primary 600 cell monolith. A dual natured designed isn't the primary factor in a DP's level of restriction.
People could replace it for all number of different reasons - a louder exhaust, feel it gives a quicker spool, because a tuning shop told them they needed to etc... Either way people's motives for buying one doesn't have any impact on whether or not it can handle the added stress caused by a stage 2 tune. Yep a number of factors effect boost load, but please try it yourself, there is no doubt all other things being equal that the Stage 1 93+ map targets more boost than the Stage 2 93 map. If the stock DP is fine with Stage 1 93+, it would be with Stage 2 as well... Unless I'm missing something? I don't doubt that my stock DP will be taking more punishment than a sports cat, but it's still holding up fine. Hey if it ever does burn out, I'll only be running on the secondary 400 cell monolith - OEM sports cat!! jk! Last edited by Scott340; 09-20-2021 at 02:23 PM.. |
09-20-2021, 03:01 PM | #20 |
Rep 122
Personally I would be more worried about the effect of excessive back pressure/heat on everything upstream of the downpipe…
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
09-20-2021, 04:11 PM | #21 |
Rep 223
I didn't even realize there was a stage 1 93+. now i'm more confused.
so what is the difference between stage 1 93 (or 93+) and stage 2 91. i could have sworn I read somewhere that the power delivery on stage 2 was more linear. stage 1 gives alot up front and then it seems to tail off a bit. |
09-20-2021, 04:22 PM | #22 | |
Rep 148
