BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 starts then stalls
      03-20-2016, 02:45 AM   #1
jaaf
Drives: 18' X5M
1993 MAZDA RX-7  [0.00]
2012 BMW 335i  [0.00]
Unhappy N55 starts then stalls
What's up fellas, I'm new to the f30 club...just picked up a 2012 335i (completely stock) a few days ago and am running into an issue with it not running lol. The car starts (sometimes struggles but eventually turns on every time) and runs smooth for a few seconds without me doing anything with the throttle..once the idle tries to drop/settle it goes crazy and runs very rough. She eventually turns off after struggling to stay on.
I would greatly appreciate any insight or help.
I've recorded a video to further illustration the situation:
Codes I'm getting are:
P006c
P0420
P0303
P0301
P0300
P0882
I buddy of mine is saying that it might be one of the fuel pumps which seems to make sense... I'm going to replace the coil packs and spark plugs within the next week to see if it does anything...
      03-20-2016, 10:42 AM   #2
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
P006c
P0420
P0303
P0301
P0300
P0882
So, you bought it like that or did it run great when you bought it? And where did you buy it. I would go back to the seller...a few days and the car does not even run. Not acceptable.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      03-20-2016, 11:47 AM   #3
jaaf
Drives: 18' X5M
I bought it from an auction, got it for a good deal, knowingly that it had an issue.. Just ddnt know what that issue was exactly. I don't regret purchasing the car, it's considered a project for me right now... figured I'd ask the group here and see if I can get any help.
      03-20-2016, 01:20 PM   #4
fscuderia23
fscuderia23's Avatar
114
Drives: 2014 F30 335i EBII + PPK/MPE
maybe fuel pump? when my LPFP went out it did more or less the same thing
      03-20-2016, 01:39 PM   #5
jaaf
Drives: 18' X5M
Hmm ok, thanks for the insight! 👍
      03-20-2016, 11:46 PM   #6
michaeljr1186
michaeljr1186's Avatar
Drives: F30 335i
yea looks like fuel pump to me.
      03-21-2016, 01:45 PM   #7
jaaf
Drives: 18' X5M
Thanks! So more likely to the low pressure pump? It does have a longer crank duration sometimes which sounds like the high pressure pump according to other posts.
      03-21-2016, 06:27 PM   #8
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Check fuel pressure sensor as well
SOLD: 2012 335i Mineral Gray
      03-22-2016, 09:11 PM   #9
jaaf
Drives: 18' X5M
any idea on how to do that? lol
      03-22-2016, 10:03 PM   #10
stxf30
stxf30's Avatar
Drives: '13 F30 335i MSport
Bro these cars are complex. Without the right diagnostic tools you'll waste too much $ replacing parts that might not be bad. Just take it to an Indy for a diagnostic. You'll pay for 1hr of shop time for them to pinpoint the issue and then just replace the part yourself. Good luck brother.
2013 GSM 335i MSport
      03-23-2016, 02:25 AM   #11
jaaf
Drives: 18' X5M
Thanks my man.. That's what my next step will be after I change the coils and plugs. 👌👍
      03-23-2016, 08:19 AM   #12
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
Random thought, maybe previous user had a tune on it and after removing the tune didn't tightly connect all the wiring harness connections?
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      03-23-2016, 09:25 AM   #13
shivaswrath
Drives: 2012 335i
that's a BMW thing - they would have to run pressure diagnostics and determine that.
      03-23-2016, 12:37 PM   #14
jaaf
Drives: 18' X5M
Def possible..ill have a look at all the connections once I put in my new coils and plugs.. Then off to the dealership for just a diagnostic test if things still don't work correctly.
Thanks guys
      03-24-2016, 09:18 AM   #15
jaaf
Drives: 18' X5M
Here's another clip:
      03-24-2016, 11:46 PM   #16
jaaf
Drives: 18' X5M
Update: ordered plugs and coils... Coils arrived early so I installed them just to see what happens. Car started and ran a little longer than usual about (8-10min)..but eventually shut down like before. Idle was really low and rough. I'll post a vid soon!
      03-25-2016, 01:51 AM   #17
jaaf
Drives: 18' X5M
Started up and ran for a good while...bad ticking sound and low/rough idle...eventually stalled again.
      03-25-2016, 10:43 AM   #18
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
+1 on taking it to a shop for proper diagnosis..
Mike
      03-25-2016, 11:03 AM   #19
G30 B58
Pace Car Driver
1548
Drives: '22 AW G30 B58 M-Sport
Mike
Nah, just keep replacing parts and let it run like sh!t. Eventually OP will need a battery too.
At least drain the fuel and replace with known good fuel.
      03-25-2016, 03:26 PM   #20
jaaf
Drives: 18' X5M
Getting it towed to BMW of Ontario, Ca right now. I'll give an update as soon as they can diagnose the issue(s) as this could possibly help anyone in the future with similar problems.
      03-25-2016, 04:36 PM   #21
Zel335
Zel335's Avatar
82
Drives: 2012 335I Sport
Ticking is often the injectors and is a normal sound on di cars.
But agree with your choice to see what is up.
      03-29-2016, 12:24 PM   #22
jaaf
Drives: 18' X5M
BMW called...HPFP and "possibly the maf". So they are going to replaced the pump first and see if we are good to go afterwards.
335i, hpfp, n55, stalls, starts
