04-14-2021, 12:21 PM | #1 |
Rep 1,912
E-Sys on M1 Mac!
04-15-2021, 06:43 AM | #2 |
Rep 19
Drives: BMW 320d Luxury Line
Pretty nice! I'm assuming this has been done using Parallels
04-15-2021, 02:03 PM | #3 |
Rep 1,912
04-19-2021, 03:35 PM | #4 |
Rep 160
Wooow, like to hear some more info. So you’ve installed the ARM version of Windows 10 and apparently E-sys and ISTA just work on that? Which versions did you use? Any things else to note?
I already kind of accepted that this wasn’t going to work for at least the near future, but this is promising. |
04-23-2021, 02:56 PM | #5 | |
Rep 1,912
11-14-2021, 10:34 PM | #6 | |
Rep 455
Current: 2022 ///M3 San Marino Blue, Comp, xDrive, Fjord Blue/Black --plus-- 2022 ///M440i Gran Coupe, Aventurin Red, Cognac Vernasca
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey |
04-10-2022, 10:45 AM | #8 |
Rep 24
Hey Nickco43 - I'm trying to get this working on my laptop as well, but running into issues with making esys launcher believe it isn't running on a VM. Can you share how you worked around that?
04-19-2022, 01:57 AM | #9 |
Rep 74
I'm also very interested in this. I am trying to get my M1 Pro setup at the moment. I have Windows ARM installed, but any time I try to run ISTA it seems to result in a fault code for kernelbase.dll and the ISTAGUI.exe fails crashes.
04-29-2022, 08:13 AM | #11 | |
Rep 37
Windows ARM ist installed too and kernelbase.dll having problems. Maybe someone can help us? |
06-03-2022, 09:13 PM | #13 |
Rep 74
I managed to get it all running in the end. Everything related to ISTA appears to be working fine. Haven't had a need for E-sys just yet, but it did install fine.
The main thing was to ensure that .net was enabled and that the emulation subsystem was enabled. once that was done, everything went smoothly. |
06-04-2022, 03:08 PM | #14 |
Rep 39
Does anyone actually have an E-Sys launcher working on their M1-A64 Win11 VM using Parallels? I have E-Sys 3.27.1 installed, just not having any luck with Launcher PRO v2.8.2_162b (it fails to launch E-Sys).
Any other alternatives? |
06-05-2022, 09:29 AM | #16 |
Rep 160
07-21-2022, 04:32 PM | #17 |
Rep 7
I'm also stuck at the licensing screen. It doesn't display any key, and there doesn't seem to be any way to enter the key (which I assume is normal for this screen, blocks me from going any further).
07-22-2022, 12:33 PM | #19 |
Rep 3,055
None of good solutions works on VM
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
04-10-2023, 02:19 AM | #20 |
Rep 6
Does anyone knows will Launcher PRO 5.2.4 or any other new launcher like ESysUltra work on Parallels Desktop? I have MacOS Ventura + Parallels Desktop and E-Sys 22.10
