07-03-2020, 04:25 AM | #3081 | |
Rep 350
That looks very smart!! Love the battery percentage number too
Current - BMW 320D LCI M SPORT
Previous - BMW 320i XDrive M SPORT |
07-03-2020, 04:44 AM | #3082 |
Rep 289
This is how waze looks:
https://i.postimg.cc/4yHwyP2S/20200703-113311.jpg https://i.postimg.cc/GLcNx1sX/20200703-113241.jpg And Spotify: https://i.postimg.cc/Syy0KqRy/20200703-093943.jpg |
x-m4n148.00 |
07-03-2020, 05:00 AM | #3083 | |
Rep 43
Which values in the xml have you guys been playing with specifically and what effect have they been having? Just curious more than anything. |
07-03-2020, 05:02 AM | #3084 | ||
Rep 132
Drives: M4 6 Spd, X6 G06 30d, G22 420i
~ Sapphire Black M4 G82 Manual
~ Mineral White Metallic X6 G06 30d M Sport ~ Sapphire Black 420i G22 M Sport #savethemanuals |
07-03-2020, 05:48 AM | #3085 | |
Rep 350
My andream unit is working well now. The only thing im missing is wireless charging due to the heat issue. Is anyone wirelessly charging and not having overheating issues? If so, what setup do you have in your F30?
07-03-2020, 05:49 AM | #3086 | |
Rep 843
No advantage to using it wired, other than charging, I just did this as I don't want the MMI usb hanging down under the trim as it has been, or located in the glovebox. This keeps it looking factory installed and you need access to the usb for software updates. |
07-03-2020, 05:50 AM | #3087 | ||
Rep 132
07-03-2020, 05:52 AM | #3088 | ||
Rep 1,325
Any difference in audio quality from using USB compared to wireless that you've noticed? Thanks for the reply |
07-03-2020, 05:59 AM | #3089 | |
Rep 843
I have never tried using it wired, so can't comment on that. |
07-03-2020, 06:31 AM | #3090 | |
Rep 350
I have an anker wireless charger in my arm rest, and after about a 45min drive, the carplay interface locked up and was un-usable. I thought i might get one of the wireless chargers that goes in the front near the cup holder, but others have said don't bother as it happens with that aswell So basically carplay + wireless charging = no go for an longer trips over 40mins. Really annoying.
07-03-2020, 07:11 AM | #3091 |
Rep 3
07-03-2020, 07:35 AM | #3092 | ||
Rep 132
07-03-2020, 07:49 AM | #3093 | |
Rep 78
https://www.aliexpress.com/item/33053361226.html I needed a long drill bit to drill through the rubber grommet from the engine bay to the cabin to route the cable and then it was quite easy from there to route it to the MMI box. There are a few videos on Youtube that show some more detail but it was much easier than fitting the rear camera :-) |
07-03-2020, 08:38 AM | #3094 |
Rep 131
A couple of questions if anyone can help. I have the Andream box for an NBT system and just updated to the lasted MCU and Software versions. All seems ok but i have lost the use of the 'menu' button on the controller. was really useful for going back to the home menu on carplay.
Other questions 1. How do you get the voice command button to work only for Siri. mine still tries to use the BMW system even when I've disconnected my phone from the bluetooth. is this a dip switch setting. I'm using the same mic so kept the switch 8 to off? 2. is there any way to skip tracks or do you have to be in the 'now playing' area? |
07-03-2020, 10:29 AM | #3095 | |
Rep 350
HOLD down the voice button for Siri. Tap it for BMW voice. No way to deactivate as its in the idrive not your phone. You can skip tracks by using the < > arrows on the radio panel when in other apps like waze, or with the controller if you are on the spotify / now playing screen
07-03-2020, 10:32 AM | #3096 |
Rep 350
No matter what iphone unfortunately, or so i have been told. Its due to the heat produced by wireless charging and car play. Both generate heat and together it crashes your phone after about 40mins.
REALLY annoying as i wanted to just drop my phone in and away i go. Now i have to keep a crappy lightening cable in the armrest for emergencies
07-03-2020, 10:38 AM | #3097 | |
Rep 21
This one has a wireless option. Has anyone tried it? Thinking about front camera install
2016 F82 MW/SO 6MT
07-03-2020, 10:40 AM | #3098 | |
Rep 21
Lots of heat and battery drain while on carplay. In fact, when wired, the battery will just stay at the same percentage (not charge up)
2016 F82 MW/SO 6MT
07-03-2020, 10:49 AM | #3099 |
Rep 350
That sucks!! On my daily drive (40mins) the battery doesn’t drain too badly about 8% for that drive. I can live with it and charge on my desk at work but I wanted to keep the battery level the same ideally. Gone from wireless charging and waze on my phone with no issues to waze on CarPlay and no ability to wireless charge. I like CarPlay enough to put up with it, I just never knew about the issue before I went ahead and got the box. I discovered it when going for an hours drive it started to chug and then someone phoned me and the whole thing locked up. I thought it was the box but now I realise it was most likely my phone crashing due to the heat. After about 20 mins it was workin again. It is very common across all brands using any CarPlay and wireless charging
07-03-2020, 11:40 AM | #3100 |
Rep 25
Drives: 2012 E92 330d
Does anyone know of a unit that's definitely compatible with NBT Evo units? I've seen a few but would rather go with a tried and true unit.
07-03-2020, 01:02 PM | #3101 |
Rep 212
Any test results using Carplay with iOS 14?
I've always have the struggle to search for contacts using letters and take long time to do it. Are you able to see the scroll bar when you are on contacts page? |
07-03-2020, 01:02 PM | #3102 | ||
Rep 1,325
andream, android, android auto, apple, carplay, mmi, retrofit |
