08-14-2020, 10:26 PM | #4203 | |
Rep 1,703
Drives: 22 X3MC MBB - C-17 Globemaster
Do Android Auto for Idrive then, worth a looksee... https://f80.bimmerpost.com/forums/sh....php?t=1738137 https://github.com/hufman/AndroidAutoIdrive |
08-15-2020, 09:54 AM | #4204 | |
Rep 77
I was able to adjust my cars EQ settings and the audio is even better than before. The 3.5mm to the centre console is not a huge issue, the cable is very easy to hide and I believe that having it plugged in is worth it in order to have carplay. |
08-15-2020, 09:58 AM | #4205 |
Rep 16
Problem: MCU won't update and stuck
Hello @ all,
1. I read most of this thread and it's amazing how active you guys are and try to help each other. Kudos to you!!! 2. Sry für hijacking your F30 forum because I drive an E81 3. My problem.... I drive an E81 120i, Made 2009, Navi CIC Prof with 8,8 screen and I have installed a MMI vom ROAD TOP. I tried to update the SOFTWARE AND MCU with the latest build from the first page of this thread (ROAD TOP CIC). SOFTWARE updated fine but I can't flash the MCU. It's stuck at this screen "USER UPDATE MCU, WAIT DO NOT POWER OFF". I kept the running for 30 min with this screen but nothing happened. I then forced the MMI to restart with the 5 sec BACK BUTTON press. MCU Version is still the old version. Anyone an idea on how I can solve this? |
08-15-2020, 12:02 PM | #4206 |
Rep 1,454
Upgraded my Andream to B v1.0.2 and that fixed the scrolling lag completely. Makes the user experience a lot better.
Question: it seems it wasn't able to take the MCU 20.06 update. I have the Gemini-update.bin and the MCU .bin on the root of my flash drive. Was I flashing the wrong version? Can the B units take the 20.06 MCU update? Thanks!
2022 CT4-V Blackwing 6-speed
08-15-2020, 12:13 PM | #4207 | |
Rep 52
08-15-2020, 12:24 PM | #4208 | |
Rep 10
After updating, restart unit by pressing back button for 5 sec. |
08-15-2020, 12:33 PM | #4209 |
Rep 43
Sound quality?
Most of this thread seems to focus on functionality and software. I'm wondering about the sound quality of these boxes? Some say it's great, others say it's terrible so I'm not sure what to make of it. This is a key consideration for me.
What's the sound quality as compared to a direct BT connection to iDrive? I'm trying to avoid flat-sounding audio with no bass or treble extension. I have the Logic7 system, which is capable of great sound given a great input. Looking to hear primarily from those who also have Logic7, since the base stereo doesn't sound as good to begin with (I had it in my previous car) so quality differences would be masked. Thanks! |
08-15-2020, 12:43 PM | #4210 |
Rep 9
No one :'( ?
08-15-2020, 12:48 PM | #4211 | |
Rep 44
I had originally tried using an old iPhone for NBT aux input which was also an audio improvement, but the BMW apps integration was flakey on a good day |
propernorf15.50 |
08-15-2020, 02:31 PM | #4213 | |
Rep 9
Yes indeed i figured it out today Before seeing your message , this what the right guess, thx Now i have the info working, only switch songs from my wheel in CarPlay are not working (the rest is working good) If i can get the next/previous button from my wheel working this kit would ne perfect Any idea? |
08-15-2020, 03:12 PM | #4214 |
Rep 108
You can stream audio via bluetooth if you like with your phone and then you'll be able to change songs/select song BUT you have to disable wheel in the mmi settings, or you'll have conflict as the wheel is used to navigate through the MMI too. AND you will loose sound from apps like waze etc, as your phone is streaming to the car directly and you'll be in Bluetooth mode. |
08-15-2020, 04:02 PM | #4215 | |
Rep 43
-cinergi |
08-15-2020, 05:17 PM | #4216 | ||
Rep 55
For now it just seems good for audio integration apps. interesting project and I hope they're able to get navigation integration ironed out |
x-m4n148.00 |
08-15-2020, 05:27 PM | #4217 | |
Rep 9
The button right/left (in the dash near the numbers of the radio) can actually skip music when I am in CarPlay (next, or previous), I ll use those for now in my last car (f30 2014) I have swished the screen for a 10" android unit (Andrem) and even in aux mod with the same wheel (M sport) I had the possibility to switch music and play/pause with the wheel buttons, may be with the CarPlay box it work differently thank you anyway |
08-15-2020, 05:41 PM | #4218 | |
Rep 108
As I said you can stream via bluetooth (so change track with wheel) & use carplay |
08-15-2020, 05:47 PM | #4219 | |
Rep 9
When I m in music (not CarPlay mode), I could see the titles in the cluster when I scroll, then I choose one by pressing the button in the wheel when I m in CarPlay mode, when I press the left/right buttons in the dash, the music changes but nothing happens in the cluster. For now, the best solution is the buttons in the dash, it works, not the best solution but I ll live with that . with my last car (f30) and android unit , the wheel were working good, but I did not had the extended cluster, si I had error shown in the cluster when I switch with the wheel buttons, but it was working well and switch/play/pause were ok) Now the only missing thing is play/pause with button in CarPlay, without switching the app to music and press pause manually (for example I m in Waze, and I want to pause music), now I use mute button ) |
08-15-2020, 11:27 PM | #4220 |
Rep 766
With the v2.0.B0.mod firmware, you can also use the idrive DOUBLE TILT right/left gesture to skip/prev songs.
08-16-2020, 01:50 AM | #4221 |
Rep 108
andream, android, android auto, apple, carplay, mmi, retrofit |
